MoT Warped Rear Brake Disc
randomness00
PostPosted: 14:59 - 22 Oct 2012    Post subject: MoT Warped Rear Brake Disc Reply with quote
HI,
Just taken my bike in for its first MoT, 2009 Yamaha diversion with fairing. The place I took it to failed it saying the rear disc was warped. When its going at slow speed there is a squeaking noise, as if something is catching on the brake pads, just wondered if this sounds right to anyone?
On the MoT certificate it says:
Reason for Refusal - Rear Roller Brake test indicates excessive fluctuation of brake effort
Its done 16000 miles, and is still on the original discs, dont want to be paying anything unnecessarily.
PostPosted: 15:27 - 22 Oct 2012    Post subject: Reply with quote
Sounds perfectly possible.
If you apply the brake gently at a low speed, you'll probably feel the lever pulsing slightly.
It's a common problem. Can sometimes be due to corrosion building up under where the disc bolts to the wheel.
If it isn't that, it's going to cost you a new disc and a set of pads.
randomness00
PostPosted: 21:10 - 22 Oct 2012    Post subject: Reply with quote
OK great thanks for the reply, ill ask around see what prices im given Smile
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 35.06 Kb
