Derbi Senda 2009 model - best combination
Hidden Snake
PostPosted: 12:16 - 17 Oct 2012    Post subject: Derbi Senda 2009 model - best combination Reply with quote
Hi, I am quite new to small bikes. I have recently bought Derbi Senda 2009 model and mount it with Leo Vince V6 TT exhaust. What I am looking for is recommended best setup of sprocket, jet, carb to get best ballanced power output. Currently I am getting decent power boost, however it is only very very high on revs and it is very peaky (I know it is small engine). I am getting max speed around 78-83 km/h (bike is carrying me plus comb = 100+kg). It is not restricted, and I am not looking for max speed - more for allaround performance.
https://www.youtube.com/watch?feature=player_embedded&v=wcoSN3i2bEw
Matt-
PostPosted: 12:55 - 17 Oct 2012    Post subject: Reply with quote
i wouldn't bother messing with the Sprockets get the jetting correct first.
See what your current Main Jet is and go a bit bigger maybe 4+, example if your main is 98 you would want a 100 jet and 102 jet, start with the bigger jet, and do Plug chop's to determine how good the jet is. the plug color should be coffee brownish !
Matty!
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Hidden Snake
PostPosted: 13:07 - 17 Oct 2012    Post subject: Reply with quote
Is there any good manual how to open the carb and change the jet?
I have hands of office rat (plus size of hulk)
Also I would like to avoid choking the engine with too rich spray (hmmm how to say that in english) Rolling Eyes
Hidden Snake
PostPosted: 15:34 - 23 Oct 2012    Post subject: Reply with quote
Hmmm ... little research and here comes my way probably.
I will change the plug and will switch to 21mm carb.
I already have leo vince v6 exhaust.
Any objections?
PostPosted: 15:36 - 23 Oct 2012    Post subject: Reply with quote
Any objections?
Yes.
Its a 50cc, going to a bigger carb means increasing the air flow into it.
This is not going to work unless you are very skilled with 2 stroke tuning.
Hidden Snake
PostPosted: 15:38 - 23 Oct 2012    Post subject: Reply with quote
Any objections?
Yes.
erhmm ... why it is not going to work? even the exhaust changed the bike from 0 to hero Wink
P.addy This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Hidden Snake
PostPosted: 17:27 - 23 Oct 2012    Post subject: Reply with quote
##Paddy## wrote:
Because it wont.
Read the bit after "This is not going to work"
Judging by your posts about what air filter and can I put auto choke on my bike... I think changing the carb, setting this up and getting it running well is beyond you.
Sigh ... i am not asking for judgement about me.
Nice to see you .
And now please comemnts to the topic.
PostPosted: 17:29 - 23 Oct 2012    Post subject: Reply with quote
It was directly related and not abusive, it was me telling you how it is.
A bigger carb on a non tuned engine... this won't work Rolling Eyes
Hidden Snake
PostPosted: 20:42 - 23 Oct 2012    Post subject: Reply with quote
Engine is tuned a bit with complete rebuild exhaust ....
PostPosted: 20:44 - 23 Oct 2012    Post subject: Reply with quote
How tuned, are you running a 70cc kit.
Complete rebuild, standard rebuild? Then use the standard carb
New exhaust, rejet the carb.
BigDMUFC
PostPosted: 20:52 - 23 Oct 2012    Post subject: Reply with quote
Paddy is right it doesn't need a bigger carb with just a tuned pipe.
The Leo exhaust is whats making it peaky, all top end power. Upjet your standard carb, if you need even more power then put a big bore kit on it. Then you will need a carb change.
NSR125R1 JC22 2004 / NSR125RS JC22 1995 / NSR125RV JC22 1997 / NSR125 JC22 ????
Hidden Snake
PostPosted: 07:08 - 24 Oct 2012    Post subject: Reply with quote
_Iain_ wrote:
And i quote.
_Iain_ wrote:
With 90% of bikes even set up correctly you will loose power & severely fuck the driveability.
And when it rains (and we are coming in to winter...) it'll hoover up shitloads of water damaging engine internals and making it cut out every thirty seconds, leaving yourself pushing it home.
Which isnt fun. Thumbs Up
The exhaust & rejet will make a massive difference as the OEM exhausts are designed to be made cheaply & to restrict the power output of the engine. Swapping it out for something thats designed to INCREASE the power & has had extensive dyno testing to get everything out of it will make a big difference - if the carb is set right.
More powerz.
Decent big bore kit. If its the AM6 engine then you'd be wanting one of theese;
https://www.athenaparts.com/files/pdfs/P400130100004_05-MinarelliAM6_ING.pdf
However note that an engines components need to be tuned to work together, rendering your fancy leo vince pipe restricting the engine again.
Price it all up? Over a grand in parts. assuming you dont change the exhaust, in which case i'd budget another £300.
A total engine build by a decent tuner to further optimise it all to run together? With that spec, i'd make a guess pushing it towards £2000 for the engine build.
It'll probbably make as much power as a restricted 125 for around 500 miles, then go hand grenade as every extra horsepower you squeeze out of it makes it less reliable. It'll be a cunt to start in the morning. It will cost the earth in expensive two stroke oil. Piston rings will probbably need replacing every week (assuming you ride it ONLY to school and back like a little old lady)
£2k for a couple of weeks worth of use? Neutral
I did my CBT, bought a 125 that was less than a year old, bought all my gear AND paid the years insurance in full for that money!
Just WAIT. be happy with how it is for now, get a bigger bike when you're old enough. Pissing around with a 50 anymore than de-restricting it with a new exhaust just isnt worth it.
Might not be what you want to hear, but it's constructive. Thumbs Up
Had you read the link fully, you'd have seen the section at the bottom where athena reccomend carb choices specificly FOR that cylinder.
Now,
The engine is setup with a balance of performance, reliability, and useability. Adding performance will thus decrease reliability & useability.
Example -
SR20DET optimised for power;
https://www.youtube.com/watch?v=91QG8dDVWXE
Note all the power has been shifted to the high end of the rev range, and the car will barely idle as a result. The engine will make next to no power till it hits around 6,000rpm, and it'll make peak power around 10,000rpm. Which is good for a race engine, as power wins, and you'd be in that band of power the whole time.
SR20DET factory setup;
https://www.youtube.com/watch?v=cCh3S-7C6fY
Note the difference in the way the car runs? However, as a result the engine will start to make power from around 1500-2000rpm, and it'll probbably peak around 7,000.
Everything is about balance. If you want power, you WILL sacrifice the driveability of the engine! get used to it. Fitting a bigger carb will make this even more of an issue, as it'll make the engine even more peaky!
Honda had an interesting way of getting around the issue on a four stroke with a system called VTEC. Which basicly had two seperate cam profiles, one for performance & one for driveabilty/economy. When it hit a certain rev, it would click over onto the performance profile & allow the engine to make maximum power. Hence the 160bhp 1.6 litre engine.
https://www.youtube.com/watch?v=AcT_ZyY3F0k
For a two stroke engine, powervalves were developed. The valve alters the exhaust port timing. Two strokes have no camshaft, and the way the barrel is ported is what affects the port timing. Which massively affects the power delivered & power availible to be made, it basicly affects the engine in the same sort of way as a four stroke engines cam profile.
The powervalve allows the exhaust port timing to adjust given certain revs, throttle openings etc, to try and improve the driveability. A barrel can then make the same power at the top end, but with double the midrange grunt making it a lot more useable. Like so;
https://i8.photobucket.com/albums/a35/BigPoppa05/Taper.jpg
A tuned RS125 two stroke (with a powervalve) and the following; Jim lomas SS system, 34mm Carb, V Force 3 reeds, HPI Racing cdi, Mitaka Barrel and piston kit
Makes a dyno graph like this;
https://i1148.photobucket.com/albums/o574/_Iain_/dyno.jpg
Note the engine revs along the bottom. It makes no power whatsoever till 6000rpm. Then it suddenly shoots up & trails off at around 9250rpm. It revs out at 11,000 so i'm assuming it hit the limiter and the dyno operator shut the engine down. Thats well over the redline!
The engine makes decent power for 3000rpm. The rest of the time it's flat as a fart & makes the power of a moped. Totally and utterly useless unless its going to be spending all its time above 7,000revs. And then it'll blow up very quickly as it'll be thrashed to death.
Now, the dyno from the R125. Yamaha's sporty four stroke;
https://www.motorcycleraceparts.co.uk/shopimages/Yamaha%20YZF-R%20125%2008-09%20dyno%20graph.jpg
Note how it pulls from 2,000 all the way to 9250? The shape of the graph?
It's smooth predictable power, which is what you're asking for. You're trying to get this power, and power curve out of a two stroke 50cc. It just wont happen!
Hence, i reccomended the cylinder kit to yourself in the first place, explained that it was more than it was worth, and just to sell up & get a bigger bike.
I'll make it simple;
NOTHING, AND I MEAN NOTHING, YOU CAN DO WILL MAKE THAT ENGINE MORE DRIVEABLE WITHOUT SACRIFICING OVERALL POWER OUTPUT.
So, if you would please accept this & either spend the 2k getting an awesome engine built (and by all means do it if its a lulzy project, because i'd realy like to see what the dyno figures came up to & nearly bought an RS50 with a fubar'd engine to try it.) or just get a bigger bike.
Nobody hates you, the idea, the bike etc etc, its just we're trying to tell you it REALY isnt worth the money, time and aggro as the only thing you'll do is end up with a realy expensive pile of scrap metal instead of an engine after a few weeks! Rolling Eyes
Now can we please stop posting theese silly threads. Neutral Thumbs Down
thx for info .... please I am not that noob and young ... I am fully aware of the limitations of the engine. On the other hand I am looking for best ballance. Actually top speed like 80+ kmh is useless for me, I am more looking for the punch and how the punch is accessible.
So far it looks like I will give it to guys in scootland and let them dynojet the baby and set the carb/plug properly.
PostPosted: 08:54 - 24 Oct 2012    Post subject: Reply with quote
Brick Wall
Iain has just basically said... it is pointless, you are wasting your time.
If you want something with more oomph, get it.
You won't get much punch out of a 50cc 2 stroke, see Iain's post as to why.
If you want something thats going to give you stupid acceleration and around 70mph top end, you'll be best off getting a DRZ400 and down gearing it. I down geared my TT600R supermoto and it was fantastic.
That had a whole 40hp, about 32 more than yours and very usable.
What is stopping you getting a bigger bike? Just pop down your local DAS place and hop on.
stevo as b4
PostPosted: 17:01 - 24 Oct 2012    Post subject: The OP sounds like a pretty big lad Reply with quote
The OP sounds like he's a bit of a big lad for a 50cc bike, and yet he is getting around 50mph from it. Sounds like he's already having his cake and eating it.
The poor bike must be working it's knackers off to get all that mass up to 50mph, and he's asking for more performance from a 49cc cylinder? Rolling Eyes
The last post was made 13 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.65 - MySQL Queries: 13 - Page Size: 114.88 Kb
