Cg valve clearance...
JunglePete
PostPosted: 21:08 - 23 Oct 2012    Post subject: Cg valve clearance... Reply with quote
When linning up the marks on the flywhell inspection whole , which mark do i use as the letters are hard to read. Is it the second single mark that comes around when spun ant-clockwise ?
ricklincs45
PostPosted: 07:21 - 24 Oct 2012    Post subject: Reply with quote
yep, it's the second single mark when turning anti-clockwise; this is the 'T' mark. The first mark 'F' is for setting the ignition timing.
Rick
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
JunglePete
PostPosted: 11:25 - 24 Oct 2012    Post subject: Reply with quote
Thanks Rick...
bikenut
PostPosted: 11:40 - 24 Oct 2012    Post subject: Reply with quote
remember that both valves are closed for adjustment ( ie rocker have clearance tween end and valve.). sorry dont know clearance but probably set with eng cold.
carefull with lid which has oil way and 2 jets. also plugged, so when running undo and check flow of oil. possibler to do this with lid off and running for a couple ( 5 secs max ) of seconfds :D
pic would be good.
ricklincs45
PostPosted: 13:24 - 24 Oct 2012    Post subject: Reply with quote
No worries.
Def' set clearances with engine stone cold (after bike has stood overnight is ideal).
Think the clearances are 0.08mm, but do double-check that.
Cheers,
Rick
The last post was made 13 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.99 - MySQL Queries: 13 - Page Size: 43.05 Kb
