Throttle body moves.
Srengam
PostPosted: 12:35 - 24 Oct 2012    Post subject: Throttle body moves. Reply with quote
Hi all,
the whole enclose can move on the bars if I grab it and turn it.
If I'm correct (from what I searched and found), there are two screws and a peg to hold it in place.
The screws seem tight, but when I pull the throttle encolsure off the bars slightly I can see what does appear to be a broken peg in the bar itself.
I imagine that the peg is staying in forever.
But is there a chemical that sets sticky after a while or a safe fix? It only moves with quite a lot of force, not enough to stop me using it or anything. But if I can put some glue or something on the bars to make sure.
Or maybe some thin rubber strips or something?
Any ideas?
Suzuki GSX600F Katana (1997)
iooi
PostPosted: 13:03 - 24 Oct 2012    Post subject: Reply with quote
So you mean the throttle grip. The twisty bit you turn to make the bike go faster.
Just wrap some duck/gaffer tape round where the non moving part should be. That will allow some grip for it.
Just don't put it where you need it to twist.... Thumbs Up
U_W v2.0
PostPosted: 20:13 - 24 Oct 2012    Post subject: Reply with quote
nothing wrong with above suggestion, but if you fancy a cleaner way of doing it, as some people are picky over it, use rubber strips. much like what you get with a bicycle light or speedo.
The last post was made 14 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 35.38 Kb
