which fork oil?
donniemateno
PostPosted: 09:07 - 26 Oct 2012    Post subject: which fork oil? Reply with quote
Im getting my fork seals changed as they have started leaking on my s reg cb500
Wondering if anyone knew which oil i might need as seems a big selection
Current bike: Honda CBR 600 F3
Previous bikes: Honda XR 125L5 , BMW 800 ST, Honda CB500
hmmmnz
PostPosted: 09:16 - 26 Oct 2012    Post subject: Reply with quote
how heavy are you?? recommended is 7.5 or 10w, but if you are over 70 kg then its too thin, i generally use a 15 or 20w oil,
use 15 if you are under 100kg 20w if over
the humans are dead
I kick arse for the lord
donniemateno
PostPosted: 09:18 - 26 Oct 2012    Post subject: Reply with quote
Im 85kg
didnt relise oil basd on weight
PostPosted: 10:35 - 26 Oct 2012    Post subject: Reply with quote
I use Automatic Transmission Fluid in the forks.
There is a fair chance Honda do too. It's often specified in the workshop manual.
map
Mr Calendar
PostPosted: 10:44 - 26 Oct 2012    Post subject: Reply with quote
That may be the case as the Honda packaged one for mine does not specify a W rating.
Interested in this as I need to get some soon anyhow to fix a leaking seal. It's a job I'm not looking forward to doing.
PostPosted: 10:48 - 26 Oct 2012    Post subject: Reply with quote
It's piss-easy once you have the bottom bolt out. I have had to drill them in the past though (even though I have an impact wrench) so it might be worth ordering a couple in just in case.
They are very easy to drill if you need to. Socket head = self-centering.
PostPosted: 18:46 - 26 Oct 2012    Post subject: Reply with quote
It isn't really
Fork oil weight controls how quickly the forks compress, but does stuff all for how far they compress.. However thicker fork oil is a quick bodge to make the forks feel stiffer.
To cope with more weight either use a touch more oil in the forks (means less air, and the air acts as a spring), stiffer springs or if just a bit use some coins on top of the springs to preload them a bit.
The last post was made 13 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 54.52 Kb
