| binge |
 binge Emo Kiddy
 Posted: 23:39 - 25 Oct 2012 Post subject: Split Charge Kit - Car thread - Help please |
Hello guys,
After a little 'how to' if you like, regarding split chargers.
I'm in the process of getting my van up and running, and putting into place the final bits and pieces of getting it ready to be a work van.
In the back of the van, I am going to be needing 240v supply, to my compressor, and to some of my power tool chargers (Battery impact gun in particular as it's over 12v).
Im just looking at split charge systems on ebay, and they are all different.
I've notices some at 100£ plus, and others at a £19.99 buy it now etc.
The expensive ones just look like a stereo amp.
The cheaper ones consist of a Splitter relay, wiring, fuses etc.
Reading through the descriptions, I'm trying to get an idea of what is going to work for me.
Can anybody tell me if this is the best setup or not?
Front end of van, engine electrics, starter motor etc, all running off original battery. Not touching that.
Now second battery, will be behind passenger seat. I want this to run the power inverter.
Now the split charge relay, I gather from the descriptions, literally hooks up the two + terminals on the two batteries. Length of high gauge wire, fuses, and the split charge relay.
Then I am guessing, I have to earth the second battery to the body of the car.
At this point, both batteries are hooked up to the alternator, but the second battery, is on an auto 'switch', which isolates it from the main battery, and alternator of the car at certain times.
So now I have a battery in the back of the car, which I want to run my power inverter straight from.
What I need to know, is what is stopping this from just draining the juice from my main battery too?
As surely, the switch relay will make a circuit, whenever there is a current draw from the second battery? As it's not going to be making it's full 12v when there is a load on it.
How exactly will it work?
Cheers,
Ben |
| 69chris |
 69chris Trackday Trickster
 Posted: 23:46 - 25 Oct 2012 Post subject: |
the relay only flows one way so your 2nd battery will charge as normal when the engine is running but power wont flow 'the other way' when the engine is off........... at least thats how it worked when i used a split charge set up on my camper  |
| binge |
 binge Emo Kiddy
 Posted: 23:55 - 25 Oct 2012 Post subject: |
Okay I see.... Kinda.
Although if it was fitted with a diode, and the power can flow from the alternator/main battery, to the second battery. Surely that would mean that the second battery would be the 'safe' one, which cant be drained from say, the headlights been left on?
Little side note also. My compressor, It's not massively big, just a Clarke 30L jobby, 10 bar working pressure, 2.5hp unit.
What sort of inverter would I need to run it up?
Been looking online, a lot of the yanks seem to think they take around 250/300 watts of working power, but a 2.5 to 3 times that, to actually get the pump 'started'.
Would I be safe to say a 1000w inverter would be enough? Or would I need something huge, like 2000w - 3000w?
Reason I ask, is because the latter type, is about £300.  |
| sickpup |
 sickpup Old Timer
| binge |
 binge Emo Kiddy
 Posted: 00:18 - 26 Oct 2012 Post subject: |
I did consider that, but it's more room, and weight in the van. Plus, something else to maintain and put fuel in.
Plus, I still, dont know what sort of wattage I need to run my compressor.
I have been reading up on modified A/C pumps (I'd need to make one fit my engine first anyway, but easily done with the Laguna bracket and belt), to pump air into a tank. They can produce around 200psi of pressure, and with a flowblack valve, and a pressure blow-off valve/switch, can be done.
Then just a small inverter to run my battery charger for my nut gun?....
But then that's an engine out job agian.
Are power inverters really that bad?
All the mobile tyre vans and stuff seem to use them, and run tyre changers on them. |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 09:11 - 26 Oct 2012 Post subject: |
ive just done the split charge thing on 2 vans (the mrs has had her little brother and step father come over to new zealand both bough vans to see nz in)
i used a 140a voltage sensitive relay on both, like this
when the car is running it starts charging the house battery, when the voltage drops below 13v on the main battery, it seperates the house from the main battery,
i also have installed inverters in both,
a modified sine wave in one and a pure in the other,
a modified does most things and are cheap,
the pure sinewave ones will run any thing but are expensive,
bear in mind, that a modified won't run any synchronized AC motors (brushless etc) and with normal ac motors the modifined sine wave is hard on the windings and heats them up,
so to run an ac motor via an inverter a pure sine wave inverter is your only real option,
failing that, a dc motor, you can get some fairly decent 12/24volt compressors these days ____________________ the humans are dead
I kick arse for the lord
| sickpup |
 sickpup Old Timer
| binge |
 binge Emo Kiddy
| jimspeed |
 jimspeed World Chat Champion
| J4mes |
 J4mes World Chat Champion
 Posted: 18:05 - 26 Oct 2012 Post subject: |
I know a fair few people who use the T-Maxx split charge systems which can be had for about £80 off ebay, it charges them both at the same time but isolates them when they are discharging, and you can manually link both the batteries together for high load situations, such as running a winch, or possibly a compressor.
Lots of information on this unit and others on the many 4x4 forums around  |
| binge |
 binge Emo Kiddy
 Posted: 18:20 - 26 Oct 2012 Post subject: |
Some interesting input. Cheers guys.
It's really been on my mind all day, different methods of making, and storing compressed air while on the go, without 240v hook up.
I'm really drawn towards the A/C converted pump, driven from the alternator belt. Only downside is that the engine may as well come back out, or at least drop it right down, to get access to that area of the engine to fit and make brackets etc.
There seem to be loads of people online running compressors from 240v inverters though. Which baffles me. One guy is running his actual house from 2 car batteries and a 5kw inverter.
He just says he cant run the fluro light in his sons room. Everything else is fine. So strange!
Uprating my alternator isnt an issue, I can happily do that. There is probably even room there go get a second alternator on. And I also have another Renault alternator spare...
But if I go to that extent, I'd rather just convert an A/C pump.
Electric wise, I only need 240v for a compressor, and for my 1/2 SnapOn impact gun, as it's 18v. Not something that will charge from a 12v car battery. The rest of my electrical gear, like LED lights, under bonnet lights, even my 3/8 impact gun, are all under 12v, so can easily be run through a ciggy lighter extension on their individual chargers (Most have in car charging leads, I'd need to make something up for the Dewalt 3/8 gun).
So I could probably get away with not even having a big inverter, and just running a decent 12v setup in the back for all my tools. I'd get away with a ciggy lighter plug in inverter for the snapon 18v charger I should think. As long as I make sure the gauge on the wiring is good enough.
I shall keep researching...
Ben |
| binge |
 binge Emo Kiddy
 Posted: 18:41 - 26 Oct 2012 Post subject: |
Little update on my finds.
I've just read a project thread on a guy who has done something similar in a jeep wrangler.
He's run an AC compressor, some other bits and pieces, and a tank, to pretty much run all his air tools, air guns, air ratchets etc. He says it runs fine too, which is promising.
The only thing I have, is all the Renaults with the 1.9 F8Q engine (Like mine) which ran Air con, also ran electric power steering, so the AC pump went in place of the PAS pump on the original engine.
I have plenty of room to mount an AC compressor up at the top.
The compressor I would use would be the same Renault item, for ease of mounting lugs:
https://i.ebayimg.com/t/RENAULT-MEGANE-SCENIC-RX4-1-9-DCI-A-C-PUMP-AIR-CON-PUMP-COMPRESSOR-2002-MODEL-/00/s/MTIwMFgxNjAw/$T2eC16F,!zcE9s4g0u7yBQipMsSgmQ~~60_58.JPG
I would mount it above the alternator, on a bracket which bolts under the two 13mm hex bolts you can see on the big bracket:
https://sphotos-d.ak.fbcdn.net/hphotos-ak-snc6/251725_10151165231105606_1322136521_n.jpg
As you can see, Tons of room to get it there:
https://sphotos-b.ak.fbcdn.net/hphotos-ak-ash4/227936_10151172885630606_1805330659_n.jpg
I can then mount the airlube and intake etc, behind that driver side headlight. And then run a line down the offside sill of the car, and into the tank, which I will bolt to the underside of the van, where my spare wheel would be.
Air line connections will come up through the bed of the van, in one of the back corners.
Hopefully this should work.  |
| jimspeed |
| binge |
 binge Emo Kiddy
| jimspeed |
| binge |
 binge Emo Kiddy
| stevo as b4 |
The last post was made 13 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
