| inchy1981 |
 inchy1981 Derestricted Danger
| J.M. |
 J.M. World Chat Champion
 Posted: 21:08 - 27 Oct 2012 Post subject: |
Absolutely.
In fact, I re-fitted my heated grips today and did exactly that.  ____________________ 2004 R1 & 2018 XSR900 |
| P. |
 P. Red Rocket
Probably best to find a slightly beefier wire.
Why not the ignition wires
But no. mine are wired into a relay to the front lights. |
| Turkish |
 Turkish Crazy Courier
 Posted: 21:50 - 27 Oct 2012 Post subject: |
Definitely use a relay and an inline fuse.
The relay coil spurs off whatever you like, headlight, taillight, dashlight pretty much anything that comes on with ignition. The switched wire on the relay comes via a new direct feed from the battery, through the fuse, relay, heated grips and then to ground.
Much safer and you can use whatever switched supply you like then  ____________________ ZX-6R G2
CBR125R RW6 |
| J.M. |
| Walloper |
 Walloper Super Spammer
| Billo63 |
 Billo63 Crazy Courier
| EazyDuz |
 EazyDuz World Chat Champion
 Posted: 10:44 - 28 Oct 2012 Post subject: |
I just fitted my R&G ones yesterday straight to the battery. It shines a bright red LED infront of me when they are on so i cant see myself forgetting to turn them off.
Its also handy for when im due to go out on the bike, i turn the heated grips on then 10 minutes later start the bike up and the grips are nice and toasty.
P.S I have a Motobatt installed, hence why i can do this  ____________________ To shreds you say? Tss tss tss |
| J.M. |
| EazyDuz |
| Kickstart |
 Kickstart The Oracle
| J.M. |
 Posted: 14:06 - 28 Oct 2012 Post subject: |
| EazyDuz wrote: | Not sure what kind of person would inspect my bike enough to see the heated grips switch, and turn them on.
I have a 12v socket connected straight to battery too which hasnt drained any power, i dont think the grips use any power at all if they arent turned on. |
Practical joker friends?
As for the socket, that's because whilst there's no device connected there is a break in the circuit. People have had it happen before where heated grips have drained the battery whilst they're off.
| EazyDuz wrote: | I'll go by the 1 strike policy, if i forget to turn them off even once, and come back to a flat batt, ill wire them up with a relay, until that happens ill chance it with the battery connection.
I have breakdown cover anyway, and a motobatt, im pretty sure a motobatt could run heated grips for a very long time before running out of juice. |
Fair enough, but for the sakes of 15 minutes and a couple of quid, I'd rather not have that happen to me. It's a horrible feeling coming out to your bike 160 miles from home and it having a flat battery.  ____________________ 2004 R1 & 2018 XSR900 |
| EazyDuz |
| J.M. |
| EazyDuz |
| Kickstart |
 Posted: 18:35 - 28 Oct 2012 Post subject: |
Likely space behind a side panel to hide a relay.
If you use the rear brake light switch, then a replacement switch likely comes with a short bit of wiring to plug into the loom. Hence if you tap into that and make a real mess of it you can just replace the cheap rear brake light switch.
Leave the grips on over night and you probably will flatten the battery enough that it will be damaged.
| el_oso |
 el_oso World Chat Champion
| biker7 |
 biker7 Crazy Courier
| Walloper |
The last post was made 13 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
