sinnis stealth choke - winter
i feed ma cat
PostPosted: 23:14 - 28 Oct 2012    Post subject: sinnis stealth choke - winter Reply with quote
Hi , i have bought this bike month ago. With choke on it was starting 1st time , now i need to press it twice ( its probably that its really cold here now ). My question is how long i need to hold choke to let it warm up at around +2-3 C degrees. The other day i did 1 minute and when i stopped at the corner out of the car park it stalled.
Regarding technical issue - choke itself became hard to pull up about 2 weeks ago like its getting stuck into something from the inside.
Frost
PostPosted: 23:29 - 28 Oct 2012    Post subject: Reply with quote
Chokes are usually overlooked when it comes to maintenance so it probably needs an oiling. Start it on the choke and leave it running while you put your gloves and helmet on. Ride off with the choke still on backing it off bit by bit. Try keeping the throttle open slightly when you come to a halt.
i feed ma cat
PostPosted: 23:32 - 28 Oct 2012    Post subject: Reply with quote
Can i leave it open for like 2-3 minutes?
P.S. im complete noob in these things and those bikes dont have manuals in UK...
kramdra
PostPosted: 00:41 - 29 Oct 2012    Post subject: Re: sinnis stealth choke - winter Reply with quote
I have same bike. It needs choke even on a warm day. On a cold day, give it a couple minutes to warm up.
Warm day you can usually start on choke and close it after a few seconds.
If you leave it on choke for 5-10 mins you should notice when its ready, revs will drop.
But, resonably good bike for a 125. Could do with 5 or 20 more horses, radial tyres, and a working tacho :/
i feed ma cat
PostPosted: 01:19 - 29 Oct 2012    Post subject: Reply with quote
Oh ok , thx mate.
I was kinda struggling regarding that , since its mostly said on the internet that dont use choke longer then 30secs it will kill your engine.
kramdra
PostPosted: 01:52 - 29 Oct 2012    Post subject: Reply with quote
In your first post you said "press it twice", your not thinking starter button? Holding that for 30 secs will kill it.
Choke cant do any significant damage. If you ride with it on, bike might stall easily at junctions/idle when warm.
worst thing if you leave the bike stationary for too long engine can over heat, but from cold it would take over 15-20 minutes.
i feed ma cat
PostPosted: 04:40 - 29 Oct 2012    Post subject: Reply with quote
i need to press start button 2x 4secs to start it , usually it starts from 2nd time i press.
That's what i meant.
The last post was made 13 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.66 - MySQL Queries: 13 - Page Size: 50.16 Kb
