running my bike some problems
joncwl
PostPosted: 20:59 - 31 Oct 2012    Post subject: running my bike some problems Reply with quote
im having a few problems with my bike about running it, it doesnt happen all the time but its pretty annoying when it does.....SO heres my problem, when i've been out on my bike for around 10 mins or so, which is pretty much a ride up to morrisons and to park it etc etc, when i get back onto it and start it it runs fine, but when ive gotten around 5 mins riding on it, it decides to not want to rev up properly and dies out...........
i got pulled by the police due to it dieing at a round about and well they laughed at me and said just pull it over to the side so people can get past which to be honest is common sense, but anyway i dont get why its cutting out on me, its a yamaha tzr 125 1988-1990, the powervalve is set to half open (it pulls off at 5-6k revs) it has petrol in it, i dont let the tank drop below half full, im letting the clutch out properly, it starts properly etc etc
so i need a few tips or maybe im going wrong pulling off, ive been on the road for around 2 weeks now and its happened 3 times
currently being a cager cause winter......the bike will be back out during the summer now
last bike, 1990 yamaha tzr125 (2rk model) - still after a fairing kit for it !!!!!
map
Mr Calendar
PostPosted: 23:38 - 31 Oct 2012    Post subject: Reply with quote
My first thought was fuel problems. Could be Just running on fuel already in carbs. When that gone it cuts out. Check fuel tap and/or fuel filter. Then if not that need to work through other possibilities.
Generally only 3 things to check for engine issues. Fuel and air (so that is carbs as well) and electrics to ignite spark.
swampy
PostPosted: 23:52 - 31 Oct 2012    Post subject: Reply with quote
Is the problem just within five minutes of starting from cold, or does it happen when started warm and run for 5 minutes too ??
joncwl
PostPosted: 00:56 - 01 Nov 2012    Post subject: Reply with quote
i never run a bike straight from cold, ive always let it run for a few mins before i set off.
and map ill take a look at everything you mentioned, see if any of them are casuing it
thanks ^^ - Jon
jetski
PostPosted: 10:57 - 03 Nov 2012    Post subject: Reply with quote
sounds like the choke could be sticking on, have you checked your air filter?
The last post was made 13 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 45.8 Kb
