Oxford products - avoid like plague! (renamed thread!)
Flatbadger
PostPosted: 10:26 - 04 Nov 2012    Post subject: Oxford products - avoid like plague! (renamed thread!) Reply with quote
Thread renamed from 'Wind and rain getting under bike cover..'
Although there's a strap to go underneath the bike and keep the cover from flying off to Surrey, the back part of the cover tends to ride up exposing the rear wheel when the wind gets under it.
I thought of adding large clips or pegs to attach small weights, but maybe someone on here has found a better solution. Any ideas?
You're in ISIS
anthony_r6
PostPosted: 10:38 - 04 Nov 2012    Post subject: Reply with quote
My cover is a little bigger than the bike, so I just tighten it around the back wheel and then roll the wheel over the cover. If I want to do it over the front as well, I'll roll it back a little more than normal, then pull it under the front wheel and roll it forward a little, and I also stick it under the stand. This keeps it pinned down. If it rains, the bottom does end up soaking wet though.
illuminateTHE...
PostPosted: 10:41 - 04 Nov 2012    Post subject: Reply with quote
add additional straps to the rear... or if you chain your rear wheel make two holes were you can pass your chain through, this will act like some form of anchor
Dazbo666
PostPosted: 10:48 - 04 Nov 2012    Post subject: Reply with quote
The edge of my cover that fits next to the wheel is elasticated, so as long as its fitted properly, the elastication fits snugly under the wheel
Word of the day : DILLIGAF
Davenaylor
PostPosted: 11:42 - 04 Nov 2012    Post subject: Reply with quote
What do people do when they've been riding in the wet and get home with a wet bike?
Do you still cover it? I don't and as a result my bikes spends days soaked!
The reason I don't is because the bike is warm and being covered, the moisture would speed up rusting, but I might have made that up.
TheSmiler
PostPosted: 11:51 - 04 Nov 2012    Post subject: Reply with quote
Leave it a few hours and then cover it, if you cover it straight away then you will melt your cover against the exhaust.
PostPosted: 11:59 - 04 Nov 2012    Post subject: Reply with quote
Watering can to rinse the road salt off. A once over with a rag. Quick spray with wd40. (keep clear of the seat/tyres/brakes) Cover on.
Make the best of a poor situation.
When it stops raining whip the cover off to dry on the washing line.
As for the cover lifting up you could get some plastic eyelets used on tarpaulins.
https://images.esellerpro.com/2294/I/109/38/100034.jpg
Or get a cover that has already has holes front and back for running chains through.
Charlie
PostPosted: 12:14 - 04 Nov 2012    Post subject: Reply with quote
I put my cover straight over and have never had any issues, this is my cover (well very similar, same brand): https://www.jsaccessories.co.uk/media/catalog/product/cache/1/image/300x/9df78eab33525d08d6e5fb8d27136e95/d/r/drdc01_18_4.jpg
https://www.jsaccessories.co.uk/brands/doctor-bike/doctor-bike-dual-layer-waterproof-cover-m.html
And I put that straight over my xt600 even when hot... However the exhaust on my bike is fairly well protected:
https://4.bp.blogspot.com/-tO6071Uit6g/UAwgd6iLRaI/AAAAAAAAAaM/bEQ9MetPE_8/s1600/XT600E+hepco+becker+rack+front.JPG (searched on google images and that is off BCF Joe's blog!)
PostPosted: 12:20 - 04 Nov 2012    Post subject: Reply with quote
My cover goes straight on, hot exhaust or not. I bought one that won't melt Laughing
Wet bike gets covered, this is Britain, it won't stop raining now till mid July and it would be pointless me waiting for the rain to stop and the bike to dry out.
Its a bike, my nice one is put away, my daily shed are getting wet/dirty regardless. A spot of rust is a minimal issue to deal with.
Flatbadger
PostPosted: 12:36 - 04 Nov 2012    Post subject: Reply with quote
Cheers chaps, I have an eyelet punch already so might go with that - maybe use a bent bit of coathanger to go under the wheel and hook on to the eyelets - I'd prefer my squire locks to be protected and am in the habit of putting them on before the cover anyway.
You're in ISIS
PostPosted: 12:40 - 04 Nov 2012    Post subject: Reply with quote
Bungee? Hooks are abit stronger than a wire coathanger.
DonDino
PostPosted: 12:59 - 04 Nov 2012    Post subject: Reply with quote
When I had the CBF, I used a cheap thin cover that didn't have any elasticated bits. I just tied a hairband over the cover and around the back brake pedal. It kept it in place in the strongest of Manchester winds.
First bike: CBF125, Feb. - Oct. 2012
Currently riding: ER-6N since Oct. 2012
Dave70
PostPosted: 17:58 - 04 Nov 2012    Post subject: Reply with quote
As has already been suggested, roll your back wheel over the end of it or just tuck it well under the wheel. That's what I do with my one that has an elasticated bottom. It gets pretty damn windy here and I've never had a problem.
A guy a few doors up uses bungee cord to wrap around the bike to keep the cover in place.
As for if it's already got wet due to the rain. I leave it off if it's still pissing down. If the rain's eased off or stopped, I'll give it a dry off with a towel and cover it.
Flatbadger
PostPosted: 18:46 - 04 Nov 2012    Post subject: Reply with quote
Due to the place my bike's left in (forecourt) and the position of the ground anchor, I wouldn't be able to put the cover on first, it would get in the way when putting the main chain through the back wheel and the 2nd one through the frame.
The bungee cord wrapping could be a runner, maybe a bit of rope with one bungee to provide tension. I might try attaching something to the back of the cover which I can then jam under the rear tyre Thumbs Up, I don't think it'll stay put on it's own.
You're in ISIS
serlant
PostPosted: 19:57 - 04 Nov 2012    Post subject: Reply with quote
does the cover touch at the bottom where it blows apart? what about using 2 neodynium disc magnets or the like and clamping the cover together, then just sticking them to the ground anchor when you remove the cover, 2 hard drive magnets or something like that.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
mickie
PostPosted: 21:01 - 04 Nov 2012    Post subject: Reply with quote
I fasten bungee's around the middle of the bike over the seat. This stops the cover ballooning and lifting.
Flatbadger
PostPosted: 21:20 - 04 Nov 2012    Post subject: Reply with quote
I like that, sounds like a quick and neat way to do it. The cover doesn't really touch but maybe I can stick it to the bottom rim of the rear wheel that way.
You're in ISIS
Noxious89123
PostPosted: 22:26 - 04 Nov 2012    Post subject: Reply with quote
I used to give mine a quick dry off with an old tea towel and then cover it anyway.
Most bike covers I've looked at are heat resistant exactly for this reason. Although if you have a bike with a cat in the exhaust, give it 15~20 minutes!
To be honest, I'd recommend you just leave it as it is and let the cover flap about a bit. Last winter I left my bike covered in the garden, with bricks holding the cover down around the bottom. Problem is, the bike stayed forever damp. When I uncovered it in spring it was mouldy and damp. The year previous it was covered, but without the bricks holding the bottom down, and it faired much better!
Flatbadger
PostPosted: 23:12 - 06 Nov 2012    Post subject: Reply with quote
Haha, it seems that the OXFORD cover has had this ventilation idea, by starting to FALL TO BITS!
I noticed a slight tear over the seat, and ran my finger gently up the centre of the cover towards the handlebars to check for more, when IT FUCKING TORE UNDER THE TINIEST AMOUNT OF PRESSURE. I've just been out to put bits of tape on it where the holes are.. Evil or Very Mad
Sorry about the 'shouting' but I want anybody searching for info about this cunting company to realise that they should never, under any circumstances buy any of their shit products!
So my question is now..
Can anyone recommend a cover which isn't fucking crap and can last longer than 6 months?
You're in ISIS
PostPosted: 23:24 - 06 Nov 2012    Post subject: Reply with quote
^^^Oxford Stormex. Wink
I have one that is over 8years old and no rips. Very faded and needs a spray of silicone..still does a decent job.
mentalboy
PostPosted: 23:53 - 06 Nov 2012    Post subject: Reply with quote
You'll find that any cover not made with a ripstop type fabric will unzip itself when it gets a small tear, the older it gets the more likely this is to happen.
Make mine a Corona.
Flatbadger
PostPosted: 00:24 - 07 Nov 2012    Post subject: Reply with quote
Sacrelidge! Hand I can't give them another penny, how dare they exist! I'll be standing out there holding a brolly before I buy their muck, and I'm also staying away from the city just on principle. Maybe it can sue the company out of existence for affecting its image.
That's a good lead, ta.
You're in ISIS
C1REX
PostPosted: 01:58 - 07 Nov 2012    Post subject: Reply with quote
I use Stormex and it's fantastic. I use it every day abusing a lot. Not a single hole and it does the job.
It's heat proof as well so no need to worry about the hot exhaust.
Kris
MCForum meetup - One of the biggest motorcycle clubs in UK
weasley
PostPosted: 08:32 - 07 Nov 2012    Post subject: Reply with quote
10 year old Stormex here... still doing good service. Also my Oxford Sports panniers, tank bag and bumbag are all giving good service after several years's use.
And I was born in Oxford. Anything from there is great.
Kris
PostPosted: 09:32 - 07 Nov 2012    Post subject: Reply with quote
During high winds I used to put a bungee across the pillion seat and fix down to the riders pegs either side. That used to work okay for me with my old Hein Gericke cover.
Karma
www.prisonplanet.com
The last post was made 13 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 131.67 Kb
