If you drink tap water read this
covent.gardens
World Clap Champion
PostPosted: 23:13 - 04 Nov 2012    Post subject: If you drink tap water read this Reply with quote
Ok, just in case there's anyone else doing the same thing I was doing, let this be a warning to you.
I always fill a glass of water from the upstairs sink using the cold tap.
I thought this was a pretty normal thing to do.
Anyway, I happened to be up in the loft today and out of curiousity lifted the lid on a water tank. It was full of fucking shit, sludge-mank, whatever you want to call it, there were a couple of insects and it also had a pile of loft insulation in the bottom of it.
I thought "that can't be good for the radiators"...
Cut a long story short, it's the fucking cold water tank that I've been DRINKING out of for several years. I proved it by running the tap and it came out of the tank.
Fuck Rolling Eyes
You're only supposed to take water from the kitchen tap as that is directly connected to the mains.
I won't ever drink from any other tap apart from the kitchen again.
The house was built in the 1930s and who knows what's in that insulation that had dropped in to the tank, I guess I'll just have to see if I develop asbestosis!
Sickening. Sad
The water always tasted OK as well!
EazyDuz
PostPosted: 23:19 - 04 Nov 2012    Post subject: Reply with quote
I avoid tap water as much as possible. Hence drinking gallons of pepsi max, o shop bought bottled water
Raffles
PostPosted: 23:23 - 04 Nov 2012    Post subject: Reply with quote
If you've been drinking it for years then why do you feel the need to cease doing so? It hasn't had any detrimental effects upon you has it? Oh hang on........
Al
PostPosted: 23:25 - 04 Nov 2012    Post subject: Reply with quote
All the cold taps in my house are fed from the cold main which is nice if you need a drink of water in the night.
I've found dead birds, rusty bits of metal and all sorts of crap in peoples water tanks, some of the old ones are actually made from asbestos.
Yamaha FZR400RR 3tj
My Instagram Thingy
Flatbadger
PostPosted: 23:32 - 04 Nov 2012    Post subject: Reply with quote
I'd rather drink from a water tank than consume aspartame sweetener, that really is disgusting! Sick
You're in ISIS
covent.gardens
World Clap Champion
PostPosted: 23:35 - 04 Nov 2012    Post subject: Reply with quote
_Iain_ wrote:
Sick
You are not as Sick as me mate I promise, I have retched over this. Laughing
There's a patch of insulation missing above the tank and I'm coming to terms with the fact I've probably drunk half of it Laughing
I can laugh about it now, or can I Sad
https://dwi.defra.gov.uk/consumers/advice-leaflets/tasteodour.pdf
Do not use water from a hot water system or your bathroom taps for drinking or cooking because it usually comes from a storage tank in the loft and is not as fresh or as safe as water directly from the mains.
kramdra
PostPosted: 23:36 - 04 Nov 2012    Post subject: Reply with quote
most houses will have cold taps only fed from mains, no tank. Its still good to run the tap for a while to make sure its fresh.
Cold water tank usually feeds the hot water tank...? my house anyway. The reson is hot water tank shouldnt be pressurised from mains and its easier to have a seperate tank to fill it... but irrelevant if you have a boiler.
PostPosted: 00:36 - 05 Nov 2012    Post subject: Reply with quote
A lot of bottled water is straight from the tap anyway.
Llama-Farmer
PostPosted: 00:41 - 05 Nov 2012    Post subject: Reply with quote
Our kitchen tap is never that cold, I like fridge cold, ie a few degrees C.
Also I used to live in Scunthorpe (they have a massive Tata steel works there and there is loads of mineral shit and crap in the water that leaves permanent water marks on EVERYTHING when it dries) so I got a Brita filter jug to filter all the water before using it. Still got that filter so just fill up from the tap and stick it in the fridge so I got cold (and clean) water when I need it.
Boxing
PostPosted: 01:06 - 05 Nov 2012    Post subject: Reply with quote
This is odd, the water holder in the loft should only go to the hot tap, not the cold as well. You had a boiler fitted recently? If so, they've probably hooked the cold tap up to that. Laughing
chrisw
PostPosted: 02:31 - 05 Nov 2012    Post subject: Reply with quote
No, you're wrong.
Most buildings in the UK have a cold water tank (typically 25 - 50 gallon) which will feed toilets, taps and the hot water cylinder (assuming you have central heating). The exception is usually the kitchen tap and any outside taps (although the later isn't always true).
If you have certain types of heating systems (I forget all the type - closed, open etc..) you will also have a 'header' (or 'expansion') tank which is essentially used to keep the heating system (rads etc..) full. This will be much smaller (~4 gallons).
It's only relatively recent that mains pressure throughout the house has become common and most commonly it's because a 'combi' style boiler has been fitted.
As for not drinking 'tanked' water - I see no problem as long as you inspect your tank fairly often. I have always drunk it and will continue to.
oldpink
PostPosted: 10:43 - 05 Nov 2012    Post subject: Reply with quote
don't have a cold water tank
all cold water comes directly from the mains Thumbs Up
Bendy
Mrs Sensible
PostPosted: 10:57 - 05 Nov 2012    Post subject: Reply with quote
I thought it was fairly common knowledge Confused
Anyway, all my taps now feed from the mains, I got rid of the cold tank in the loft when I changed to a combi boiler. Still use the kitchen tap, the bathroom would need running for longer as its been sat in an extra 20 feet of pipe.
The Artist
PostPosted: 11:09 - 05 Nov 2012    Post subject: Reply with quote
Man up. You are not ill are you?
Water comes miles in underground leaky pipes through all sorts of crap.
Chinaboy
PostPosted: 11:24 - 05 Nov 2012    Post subject: Reply with quote
At my house I have a borehole that goes down 40 meters into the ground water. It gets pressurised to our water system and is the best water to drink. Normally I wouldn't drink from any tap anywhere else in the Philippines. Here, where I am in Shanghai, no one drinks from the tap, just too dangerous, even the Chinese dont, so that is good enough for me.
mysterious_rider
PostPosted: 11:46 - 05 Nov 2012    Post subject: Reply with quote
FUUUUUUU.
Irn-Bru
PostPosted: 12:00 - 05 Nov 2012    Post subject: Reply with quote
All our taps are from the mains and this house was built in 1910 Surprised Even used to have the toilet in the back yard back in the mining days.
Personally think tap water is manky tasting, I stick to flavoured water from asda, x4 1 litre bottles for £1.50.
J0Al1
PostPosted: 12:28 - 05 Nov 2012    Post subject: Reply with quote
I spent years doing the same (drinking from the upstairs tap), like you, had no idea.. The tank is vile.. it is dirty and has insulation lagging fallen into it.
.Chris.
PostPosted: 12:37 - 05 Nov 2012    Post subject: Reply with quote
This is pretty well known stuff.
As said above, most houses in the UK have an indirect cold water system, whereby the kitchen tap is fed directly from the water main, but all other cold water supplies are from the tank(s) in the loft. Water companies (so I'm told) prefer this arrangement as it's less likely to result in fluctuating mains water pressure at times of high demand.
Chris
1985 Kawasaki Z550F
andy_uk
PostPosted: 14:48 - 05 Nov 2012    Post subject: Reply with quote
I've never lived in a house or flat where the cold water isn't fed direct from the main Shocked Even my gran's many years ago had mains cold water to all cold taps (in a Victorian property too, still had lead pipe throughout though!! lovely Shocked )
Raffles
PostPosted: 14:59 - 05 Nov 2012    Post subject: Reply with quote
Unless the pipework is made of lead then that extra 20 feet shouldn't cause you any problems. After all the water has already travelled through miles of underground pipework prior to reaching your home.
Bendy
Mrs Sensible
PostPosted: 15:06 - 05 Nov 2012    Post subject: Reply with quote
I appreciate that, but having recently plumbed in my new bathroom sink and seen what the insides of the pipes look like, I have a bit of a mental block. In my mind the main supply pipes are beautiful and pristine. Laughing
Moreso it's just habit from all the years of having a tank. And the kitchen tap being next to the cupboard that has all the glasses in it.
Benson_JV
PostPosted: 15:20 - 05 Nov 2012    Post subject: Reply with quote
I hate drinking plain water but I have only one tank in my loft (immersion heater) so Ima go and drink all the tap water from all the taps!
Wave2k
G's Stalker
PostPosted: 15:51 - 05 Nov 2012    Post subject: Reply with quote
Just went and checked my tank in the loft as i drink from the tap in the bathroom.
Seemed pretty clean too me, though its not one of those old metal tanks from the 1930s.
Ducati 1299 Panigale
2009 Corvette C6 z51
The last post was made 13 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 129.63 Kb
