petrol leak help please
bob_711
PostPosted: 18:50 - 05 Nov 2012    Post subject: petrol leak help please Reply with quote
i have a 2006 ybr 125 and i noticed this happen for a coupe of days now, there is a small black pipe with a rubber thing on the end underneath the engine at the back near the kick stand that is slowly dripping unleaded when its sat in the garage over night does anyone know what could be causing this thanks
DJB666
PostPosted: 19:13 - 05 Nov 2012    Post subject: Reply with quote
My first instinct would suggest to you, check the fuel pump? I'm no genius on bikes as such, but this is what I would do:
stand the bike, engine off, and disconnect fuel filter, so its empty, re-attach and see if she is still filling up? if not, perhaps drain the carb? But these are my personal opinions Smile
DJB666
The older I get the faster I was
Efes123
PostPosted: 20:54 - 05 Nov 2012    Post subject: Reply with quote
Pics of the tube would help. I'm not aware of any fuel pump on a 125. It sounds like a breather pipe? Vacuum issue?
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
bob_711
PostPosted: 22:13 - 05 Nov 2012    Post subject: Reply with quote
sorry was the best angle could get a pic from hopefully someone will know what it is
https://img571.imageshack.us/img571/8562/img9975oi.jpg
bob_711
PostPosted: 22:44 - 05 Nov 2012    Post subject: Reply with quote
as far as i know the 2006 has a carb rather than fuel injection and i tried i couldnt see where it went to what would be the best thing to do if carb is sticking?
bob_711
PostPosted: 01:34 - 06 Nov 2012    Post subject: Reply with quote
is doing any of this easy? no experience at all with bike mechanics and i topped up a fiver the other day but that only got it to just over a half and i didn't see any overflow pipe on this bike
Efes123
PostPosted: 08:33 - 06 Nov 2012    Post subject: Reply with quote
Looks a bit chunky to be coming off the carb? I wonder if your drain screw on the carb has worked loose.
https://www.dogfriendlysuffolk.com/bikepics/YBR125-Carb.jpg
Number 3?
bob_711
PostPosted: 17:40 - 06 Nov 2012    Post subject: Reply with quote
went to the garage with it and they said the carb probably needs cleaning out and that it probably was the overflow they said it would cost £45 for them to do it so think im going to try it myself tomorrow and it is just a small rubber pipe that goes into that big rubber spout thing just couldn't get a pic from the top with being behind the brake pedal and will have to have a look about the drain screw thanks for the ideas on what it could be hopefully 1 of them will sort it without having to shell out
bob_711
PostPosted: 22:31 - 06 Nov 2012    Post subject: Reply with quote
i've tightened the screw mentioned as wasnt completly tight and shall just have to wait and see if that stops it, if not my gf's dads best friend isa biker and a machanic so said he would take a look so with any luck all will be sorted with just tightening that screw anyway thanks for the help
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
gandy666
PostPosted: 17:46 - 12 Nov 2012    Post subject: Reply with quote
sounds like carb is overflowing because the float bowl has jammed / rubber has perished / needle stuck / crap vacuum due to hardened rubber / etc
buy a carb rebuild kit - about 12 quid depending on the bike.
piece of piss to fit. usually can get the carbs off a wee bike without having to take the tank off, airbox out, battery out etc. should just be a case of unscrewing the bowl, swapping the parts and makin sure everything is snug. if the floats just fall out when you unscrew the bowl, I would say this is the problem. very common.
if the carb is full of shit get it ultrasonicked, tho will cost you a bit.
pipe usually comes from bottom of the airbox.
The last post was made 13 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 3.77 - MySQL Queries: 13 - Page Size: 85.88 Kb
