HID lighting conversions
Nick_Giles
PostPosted: 21:08 - 06 Nov 2012    Post subject: HID lighting conversions Reply with quote
Are they all they profess to be and a worthwhile upgrade.
Yes / No.?
Nick Smile
AlexW
PostPosted: 21:34 - 06 Nov 2012    Post subject: Reply with quote
In a projector headlamp, they are awesome, In a normal style bowl, they are pretty poor from a beam pattern angle.
dragstaar
PostPosted: 21:53 - 06 Nov 2012    Post subject: Reply with quote
They're fucking fantastic all round.
HIDs in projectors are no issue whatsoever, they really do light up the road amazingly well. When I got them on the bandit I couldn't believe the difference. I mean, most mods you see a teeny difference, whereas this difference overwhelmed me. Its like a bloody football pitch floodlight.
The issue with HIDs in normal reflector bulbs is that they struggle to focus the spread beam, however, this can be overcome with capped HID bulbs. Bit more expensive, but worth it.
Uncapped bulbs look like this and scatter the beams. Stay away from these if you have reflectors. These tend to be the earlier style HIDs
https://www.outdoorswarehouse.com.au/product_images/k/pn1hi356__84302.jpg
Instead, get capped bulbs like this and they focus the beam properly
https://blog.villageorigin.com/wp-content/uploads/2011/10/HID-Bulbs.jpg
AlexW
PostPosted: 22:32 - 06 Nov 2012    Post subject: Reply with quote
I completely agree, in projector headlights they are fapping fantastic, or in normal reflective bowls for high beam.
I have to admit I wasn't aware of capped ones, other than for H4's due to the switching. Learn something new every day Smile
Nick_Giles
PostPosted: 22:52 - 06 Nov 2012    Post subject: Reply with quote
Cheers for the replies guy's.
Has anyone got a link to a good H4 conversion kit for a 2001 Hornet S
Thanks, Nick
guile
PostPosted: 23:00 - 06 Nov 2012    Post subject: Reply with quote
I was looking into this and it seems they are illegal (unless you upgrade the reflector unit) and from what I can see the conversion bulbs don't work with the stock head unit on my bike. They don't light up the road properly because the reflector unit was not designed for that and it ends up blinding drivers and having poor beam.
So I just ordered some extra bright halogen bulbs which are supposed to double the brightness of stock bulbs.
MCW
PostPosted: 23:01 - 06 Nov 2012    Post subject: Reply with quote
I've been looking into this as I won't go out at night on the Varadero, (Verydearo Rogerborg, if you're reading this), as it's lights are shittier than a shit thing being shitty on a shit day.
I found this thread:
https://www.125varadero.com/forum2/viewtopic.php?f=14&t=249&p=1553&hilit=hid#p1553
All looked promising until the penultimate post, where he's given up. Did he do something wrong, or is this likely to be a problem?
mysterious_rider
PostPosted: 23:25 - 06 Nov 2012    Post subject: Reply with quote
i used a capped one with high beam for a car. It's been fine, they can be tempermental though.
They are extremely bright, other road users will notice you a LOT more. I've NEVER had anyone pull out on me with one. Thumbs Up Also very cheap to buy. £32 as a kit of x2. So sell one kit to a friend.
Mine just fitted straight into the h4 pins slot thing. Then you just slap the ballast somewhere where it doesn't look ugly.
The problem I have is sometimes it won't turn on when I start the bike. You just switch it to high beam, wait a few seconds, then back to normal beam and it switches on. Or if that doesn't work, turn ignition key off, then back on. Thumbs Up
Also worth noting, they run on a single beam, and use magnets (electricity??) to switch it to high beam mode. If it dies, you won't be able to switch to a different beam to get home (pretty sure of it).
So it makes sense to have a standard bulb under the seat, just incase.
keggyhander
PostPosted: 00:14 - 07 Nov 2012    Post subject: Reply with quote
I have a capped H4 HID in mine. I have the same problem with a sticking solenoid in the bulb unit. It would stick on main. I just disconnected the main beam wire so it's always on dipped. It's bright enough anyway.
mysterious_rider
PostPosted: 00:16 - 07 Nov 2012    Post subject: Reply with quote
Would happen regardless of what beam you are on? I just don't think they like being on the 'on' position while the engine is being turned on from off. If you get me. Laughing No point losing high beam, although mine is like, in the sky at the moment. Laughing
keggyhander
PostPosted: 00:20 - 07 Nov 2012    Post subject: Reply with quote
Come again?
mysterious_rider
PostPosted: 00:22 - 07 Nov 2012    Post subject: Reply with quote
Come again?
what was the point in removing the main beam? Did you have problems with it not turning on? do they not run on the same beam?
tom_m
PostPosted: 01:03 - 07 Nov 2012    Post subject: Reply with quote
i tried a hid conversion kit on my ybr, but it was dazzling other drivers and i couldnt see much more lol. instead i got on fleebay an bought a pair of osram nightbreakers delivered for £12.
used to have a hid kit in my peugeot 207 and it was fantastic, but for a bike it seems pointless imo
Current: 2005 Kawasaki Er-5 C5P
Past: 2012 Yamaha Ybr 125, 2004 Yamaha Neos 50, 1994 Suzuki Gn 125, 2005 Aprilia Sportcity 125, 1988 Yamaha Tzr 125
Theory: Passed... Mod 1: Passed 22/08/12 Mod 2: Passed 22/10/12
owl10
PostPosted: 02:03 - 07 Nov 2012    Post subject: Reply with quote
Im not sure how I feel about HIDS on bikes
For cars....
legally, they have to be self leveling, which usulaly requires some gubbins linking the level to the suspension. Of course none of the ebay kits are.
It really annoys me when some chav in a shitty clapped out corsa has 100w HIDs in a standard non projection light shining striaght into my fucking eyes.
FWIW 6000k + = chavvy as hell IMO (though im sure many will disagree)
Best / most efficient light output is somewhere around 5000k... 6000K and over tend to sell more 'cos dey is blu so mak us looks like da big boss innit
For bikes.....
Im kind of leaning toward them being a bit more useful because
a) Most drivers are fucking morons so being able to see you coming is a good thing
b) Most bikes headlights might as well be a sodding candle in a jam jar - however for me the ZX6R J1 has EXCELLENT standard lighting, with Dual H4's
I saw someone made a J1/J2 headliamp into a projector headlamp once, Id be tempted to get HIDs if i did this.
Without projectors still look a bit chavvy tbh.
Please guys, if you fit them remember to level your lights properly - if nothing else when at the road at night if you blind the other driver there is a risk of them running into your lane.
FWIW i had some on an old car of mine (with a projector...) If you are fitting them its an idea to waterproof the ballast - I wrapped in some plastic. Cheap chinese ballasts will last maybe 3 months otherwise before rusting to hell if exposed to the usual british weather through the winter.
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
snikks
PostPosted: 08:51 - 07 Nov 2012    Post subject: Reply with quote
Scanning through the thread with interest (my bikes headlights are shite) I couldn't help but notice this - if you think the Vara's headlights are poor, you have exciting times on the way when you experience truly poor bike headlights Very Happy
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
oldenuff
PostPosted: 09:14 - 07 Nov 2012    Post subject: The better solution Reply with quote
The self-levelling issue is going to get you into problems with the police sooner or later. They are not legal unless they are self-levelling. I find that my Osrams get an angry reaction on dip going uphill so you will probably get caught with fixed HID's.
You can get as much usable light without the expense and hassle with Osram Nightbreakers (£12.20 for two)or Phillips Extreme bulbs. Certainly the Osrams have a better spread and throw on dip than any of the alternatives.
Alpha-9
PostPosted: 09:16 - 07 Nov 2012    Post subject: Reply with quote
HIDs piss me off, they blind me on dark roads and i'm left dazed for a few seconds, then you get dicks who sit up your arse with them on and I have to reangle my mirrors to stop being blinded in the reflection
Fzr-600 1999
Acemastr
PostPosted: 09:19 - 07 Nov 2012    Post subject: Reply with quote
Be careful of your battery, they take an almighty amount of power to start, but when running use less than a conventional bulb, so turning the ignition on on your bike causes them to come on they will be draining a fair chunk of power without the engine making more
2016 Toyota Tacoma Limited
Walloper
I did a fair wad of research on T' Internet with regards to HID when I was contemplating 'upgrading' the lamps on a BMW R1200GS.
The legality is an issue.
Though I may be wrong (again) the issue is to do with glare affecting on-coming drivers.
This glare even happens with factory fitted regulation HID. The problem can be caused by simply not having a clean lamp lens/es which difuses the light.
I think legislation (or a recomendation) requires HID in conjunction with Headlamp wash systems.
But that doesn't obviously apply to bikes as my K1300GT has HID but I have to wash the bloody lamp myself if it gets dirty.
With capped bulbs the glare issue will be reduced. Focus of the lamp cannot be changed but the angle of it's dangle, by law, must comply with regulation.
Since a lot of cnuts ride/drive with astigmatic head lamps I can't see any authority giving anyone a tug for having HID.
So long as it's not like you have the Sun strapped onto the bike when copper sees you you'll be fine.
Some polis don't even know about Lights-On all the time for bikes or that on a two lamp set up only one is lit at any one time (unless you have fecked about with it)
If HID is not an option you can do bulb upgrade.
I can recommend PIAF for power without any mods. But a wee bit pricey and dificult to find dealers in the High Street.
Walloper
PostPosted: 09:22 - 07 Nov 2012    Post subject: Reply with quote
Do they big boys kick sand at you on the beach too.....?
Razz
Kris
I'm not after HIDs but do those extra bright bulbs work at all?
The dipped beam on the bandit is shockingly poor...
Idea
www.prisonplanet.com
Walloper
PostPosted: 09:26 - 07 Nov 2012    Post subject: Reply with quote
Idea
I typed PIAF instead of PIAA (What a stupid cnut... Edith Piaf was a French Mud Wrestler in the fifties.)
https://www.piaa.co.uk/
These bulbs are better than the Haloagain you get from Halfrauds etc.
I went through all the 'High Power' shit till I found these.
Bright white and extra long beam length.
Perfect for those Country roads.
Kris
PostPosted: 09:29 - 07 Nov 2012    Post subject: Reply with quote
These ones? (The H4s)
https://www.piaa.co.uk/bulbs/bulbshow.asp?ID=halogen
Idea
snikks
PostPosted: 09:30 - 07 Nov 2012    Post subject: Reply with quote
Idea
They did make a difference on my Fazer - we're not talking zero to hero, but zero to a slightly less weedy chap with a determined grimace, for sure.
oldenuff
PostPosted: 14:36 - 07 Nov 2012    Post subject: Bulb comparison Reply with quote
Ride did a test a short while ago and the outcome was iirc that the most lumens came from Phillips Extreme - about the claimed 100% over the standard halogen - with the Osram second ( 90%+). The writer did note that the Osrams gave a longer throw and seemed better on dip. I have just made the switch and the difference is very noticeable. The downside to all this is that changing the bulbs is very awkward on my VFR. One of those ten minute jobs that takes all morning.
The last post was made 13 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 135.66 Kb
