throttle response
mark84
PostPosted: 22:59 - 08 Nov 2012    Post subject: throttle response Reply with quote
hello people i was wandering if some one can help me i have a baotian scout bt-49 qt-9 an my throttle is playing up i cant get over 25mph and everytime i twist the throttle my speed dissapears
can anyone help
mark
ruck bodgers2
PostPosted: 14:15 - 09 Nov 2012    Post subject: Reply with quote
you are having a power loss with the throttle open more than half way >?
whats the symptoms does it struggle to breathe and make a chug chug attempt at living then die ?
or do you need to over rev it to get anywhere at all
asuming it does need to be over revved . first things first check all components that fix to the engine are tight .
for example if your lambda censor is loose on a efi bike this will happen . check your carb to head rubber is all fixed tight and your throttle cable is not loose. exhaust is on properly places where u can loose compression or mess with the air fuel feed
if not give a little more info about the bike and the best description you can of the charecteristics of the problem again and people will try and help .
i see from a quik search its a 50cc 4 stroke single scooter . is this correct .
are you noticing any sounds you did not before
EDIT* after reading your post again i see its not dieing or struggling at all . so ignore the above
throw it up the wall
Pete.
PostPosted: 20:20 - 09 Nov 2012    Post subject: Reply with quote
Probably best ignoring the above completely.
a.k.a 'Geri'
The Artist
PostPosted: 14:58 - 10 Nov 2012    Post subject: Reply with quote
Yeh, just check main jet to see if it is blocked or partially blocked. Could be why.
ruck bodgers2
PostPosted: 22:05 - 10 Nov 2012    Post subject: Reply with quote
its a carb and not a two stroke either
Laughing but its top speed is 27 mph we must help him get the extra 2mph
The Artist
PostPosted: 22:10 - 10 Nov 2012    Post subject: Reply with quote
ruck bodgers2 wrote:
its a carb
Yes
nsr_J22_FOXEYE
PostPosted: 20:54 - 11 Nov 2012    Post subject: Reply with quote
Check your air filter bud Smile
Never Ride Faster Than Your Angel Can Fly
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 52.43 Kb
