| pits |
 pits World Chat Champion
| The Artist |
 The Artist Super Spammer
| pits |
| The Artist |
| Ariel Badger |
 Ariel Badger Super Spammer
| The Artist |
| pits |
| Ichy |
 Ichy World Chat Champion
 Posted: 01:55 - 10 Nov 2012 Post subject: |
I've always gutted kills there and then. I know you are supposed to leave them in but it just seems wrong leaving the entrails in to rot for a couple of weeks.
If you want to roast it then cover it in bacon. The fat helps moisturise it  ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| kramdra |
 kramdra World Chat Champion
| Ariel Badger |
| Walloper |
 Walloper Super Spammer
| The Artist |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| Charlie |
 Charlie World Chat Champion
 Posted: 10:18 - 10 Nov 2012 Post subject: |
This is what we do at home with pheasants. I've only done it myself a couple of times, normal with my Dad instructing me over my shoulder.
Potentially leave it to hang for a week at the most, even when near freezing in the garage. Often the birds will get done before a week.
Lie the bird on it's back, and pull a few feathers out of it's stomach. With a sharp knife make a small cut about 2-3cm long in the plucked area. Be careful not to cut the meat, you just want to cut the skin.
Now you're going to peal the skin off the bird, you want to get the skin off all in one and disrupt the feathers as least as possible (it gets every where). Try not to let the skin break apart and if it rips you'll need to use a sharp knife to get it separating from the meat again.
Using your fingers carefully peal the skin from the cut you made down the length of the bird, try to get it pealing under the bird to. When you get to the legs, carefully pull the skin back along the legs until there is little meat left. Use a good pair of scissors to cut through the leg bone. Repeat for the other leg. Next will be the tail, here you want to pull it back slightly but cut far enough away from the bird to ensure that the guts don't spill out yet. Again use scissors to cut it off.
You should now be able to peal the skin right under the back off and up to the wings. These can be quite tricky, and should be done similar to the legs. Probably won't be much meat on them and wont be able to peal them back like the legs so just cut them off. Finally peal the skin up the neck a little way and cut this off with scissors.
Put the skin in a plastic bag and clear your chopping board of any feathers (hopefully there will be little). It's probably best doing this over a sink. Now make a small incision from its arse up towards its breasts. This needs to be just big enough for a couple of fingers. Insert your fingers and pull out everything up there. The intestines will come out all in ones along with the stomach and you'll probably need to go up again to get its heart. The lungs sometimes come out easy, other times just disintegrate.
Once you're confident that you've removed all the guts give it a good rinse with water, flush the water right down its bodies cavity and remove any feathers that may have gotten on the meat. Once it looks clean you're done. A bird skinned like this will dry out quickly if left uncovered when cooking or in the fridge.
Also I've released I've missed out removing the crop, but I can't think when is best to do this. Either when removing the head or removing the guts. I am sure you'll figure something out.
Pheasant tastes lovely ____________________ Past: Honda x8rs, Honda City fly, Honda Hornet 250, Honda VFR750, Yamaha xt600e.
Current: Honda CBR929RR & Yamaha XT660Z Tenere |
| Spudly |
 Spudly World Chat Champion
 Posted: 13:19 - 10 Nov 2012 Post subject: |
As Charlie said above, but remember that removing the guts is a process which will stink, so be prepared for it.
I've never hung one for more than a week, but when hanging it, don't cut anything off it, tie some string around its neck and hang it by the neck. Minimum three days, max of about a week. Further hanging increases the gamey taste, so its a matter of preference really.
If you don't want to skin the bird, plucking it is a process which can be quite cathartic and is best done after the bird has been hung.
Once you have plucked it, you can give it a rub with some garlic butter, then cover it with farmhouse bacon (the kind which has loads of fat on it), although my wife says plain butter is best. She's a better cook than I am, but I think the garlic makes it good.
If you casserole the bird, consider using a bouquet garni, a bay leaf and some juniper berries in the pot. I've never done it with half a bottle of gin, but I've heard that can work too.
Pheasant is lovely, but be sure you keep in mind that while the birds are much the same size as chickens, sound like chickens and are marginally more stupid than chickens, they taste different and have a different texture to chickens. Tasty, but different. ____________________ The Old Apprentice |
| The Artist |
The last post was made 13 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
