Scored CG brake drums
mudcow007
PostPosted: 09:39 - 12 Nov 2012    Post subject: Scored CG brake drums Reply with quote
Morning all
just in the middle of rebuilding a '84 CG125
just took a look inside the rear drum an its pretty scored - it looks like a stone or something has got inside an tore the shoes to shreds
i'm guessing you cant do much with it so its a new wheel??
ta
Karma
ricklincs45
PostPosted: 10:20 - 12 Nov 2012    Post subject: Reply with quote
Depends whether or not the scoring has gone past 'tolerance' point. If it's light, the drum can be machined true again, if not, there are engineering companies that can re-line the drum.
Probably cheaper to buy a replacement 2nd hand wheel.
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
mudcow007
PostPosted: 11:17 - 12 Nov 2012    Post subject: Reply with quote
Ahh
this cheap rebuild is starting to mount up!!!!
cheers
YBR Ric
PostPosted: 11:40 - 12 Nov 2012    Post subject: Reply with quote
A method I've used successfully in the past is to attach some wet/dry to the brakes with double sided carpet tape, adjust the brake shoes until its rubbing against the drum then spin the wheel to smooth the contact surface. Once the rubbing stops, dismantle, check, and repeat as necessary using finer graded paper. Do not exceed the drum lining wear limits.
This is best done by hand and not by using the engine to drive the wheel because if the double sided gets too warm the wet/dry will slide and jam, possibly resulting in unwanted damage.
When happy with the result, thoroughly clean the drum, fit new brake shoes and just remember to bed them in carefully.
mudcow007
PostPosted: 11:49 - 12 Nov 2012    Post subject: Reply with quote
Cheers Ric
i will give it ago, im guessing the tolerance ratings will be stamped into the hub somewhere?
its pretty manky in there so i will clean em up first
just priced a spanking new wheel from Davidsilvers an its coming out at over 200 notes unbuilt Shocked
Karma
YBR Ric
PostPosted: 12:47 - 12 Nov 2012    Post subject: Reply with quote
The limit could be somewhere on the hub, otherwise it's in the workshop manual.
For the YBR, it's listed as 130mm new with a service limit of 131mm, ie half a millimeter of lining insert wear.
ricklincs45
PostPosted: 12:56 - 12 Nov 2012    Post subject: drum tolerance limit Reply with quote
Just had a look in a Haynes manual for the CG; it says the drum inside diameter is 110mm standard, with a wear limit of 111mm.
If the hub is still within wear tolerance, still might be worth letting a machine shop check it for trueness - over the years they tend to go slightly oval, though if that has happened, machining it back to 'round' may take it pass the wear limit. Other option (if still usable) is as YBRric mentioned, to rub any high points out by hand.
That's the prob' with old bikes, one job leads to several others!
Rick
mudcow007
PostPosted: 14:27 - 14 Nov 2012    Post subject: Reply with quote
cheers all
i think the rear is toast so looks like i will have to trya n find a wheel
i haven't looked at the front, but im guessing if the back is bad - the front will be worse
anyone know if all CG's used the same wheel size?
mudcow007
PostPosted: 16:37 - 14 Nov 2012    Post subject: Reply with quote
im just worried that if i ride on a scored hub there is a possibility of the brake binding an locking on at some point?
is that a possibility?
cheers
Walloper
PostPosted: 17:20 - 14 Nov 2012    Post subject: Reply with quote
cheers
It would only bind on if the adjuster arm locks by turning too far.
Which would be practically imposibru. (Unless you try really really hard.)
Try rubbing it out with rough emery/wet&dry to take off the high spots.
I hardly use the back brake so I'd just get it to pass the MOT.
CGs have shite brakes anyway Smile
ricklincs45
PostPosted: 17:23 - 14 Nov 2012    Post subject: Reply with quote
Have had/run loads of these little Honda's and have never had a problem with back brakes. Scoring by itself is unlikely to cause a brake to lock on - you'd have to have some serious faults such as a drum or shoes breaking up for that to happen.
As the back brake is rod operated, no issue with cable stretch. Have seen bikes running without problem even when the shoes are worn and the brake plate actuating arm has been turned round one notch.
Would certainly be worth giving it a thorough clean and examining for cracks in the drum while it's off, just to be safe.
The rear brakes are usually very good; if you can use the current hub I'd be tempted to 'make do' if safe to do so and spend the money saved sorting out the front - they're usually in need of new cable/shoes and probably a skim (a CB100N disc brake is far, far better if you're not bothered about originality...).
Rick
The last post was made 13 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 78.26 Kb
