1988 YAMAHA RZR250 with 350 top end, fuel tap
rzsteve
PostPosted: 20:31 - 12 Nov 2012    Post subject: 1988 YAMAHA RZR250 with 350 top end, fuel tap Reply with quote
Hi, can anyone please help? My bike had to be converted from the standard RZR250 carbs which have a vacuum tap to 31k 350 carbs which dont have a vacuum, will a later YPVS fuel tap fit the RZR tank? Approx measurements are centre of screw hole to other screw hole is 35mm, looking down from the reserve and fuel feed the unit is 55mm long and 20mm wide (the part that bolts to the tank). I would appreciate any advice and thanks in advance.
andys675
PostPosted: 23:54 - 12 Nov 2012    Post subject: Reply with quote
all my 31k had vacuum pipe on the carb, on the left side of the right carb
Suntan Sid
PostPosted: 07:19 - 13 Nov 2012    Post subject: Reply with quote
I've got my original RZR fuel tank, with tap and an F2 tank, with tap, both taps look exactly the same.
The Yambits part numbers (FTT008) are the same for the RZR and the F2.
rzsteve
PostPosted: 19:27 - 14 Nov 2012    Post subject: Reply with quote
Thanks guys, will have a closer look. The seller told me they were 31k carbs, do all YPVS carbs have a vacuum then? If so, dont know what I have on the bike! Confused
The last post was made 13 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 39.67 Kb
