Spark plug black as night
mikojh
PostPosted: 21:14 - 12 Nov 2012    Post subject: Spark plug black as night Reply with quote
Currently my spark plug is jet black with grey on the small little piece of electrode thing. Obviously the mix is running to rich. What can i do to try and rectify this as this could be responsible for power/performance problems im experiencing at high speed. So far i have checked for leaks and checked the air filter both are fine. BTW I never having problems starting the bike nor does the bike ever die just runs like shit at high speed. I also did a compression test the other day which was 140.
In my user manual for the bike it also says if plug is of an excessively hot appearance on a standard spark plug to try a different one. Worth looking at? Does hot appearance mean black? Theres another plug recommended for a wet appearance why cant they just give clear colours.
Hot=Black?
fatpies
PostPosted: 21:18 - 12 Nov 2012    Post subject: Reply with quote
A too hot spark plug would be powdery white.
Have a look here and compare
https://i176.photobucket.com/albums/w170/SDHonda153/DensoSparkPlugChart.jpg
MickC
PostPosted: 21:29 - 12 Nov 2012    Post subject: Reply with quote
Rich mixture or your burning oil, any smoke from the exhaust?
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
cb1rocket
PostPosted: 22:25 - 12 Nov 2012    Post subject: Reply with quote
if its black its running rich. If everything else is stock and standard then try running a hotter plug. That usually means going down in a number for an NGK plug, ie BR8 would then become a BR7.
So yes your plug is running a rich and would explain the crap high speed running to some extent.
temeluchus
PostPosted: 22:34 - 12 Nov 2012    Post subject: Reply with quote
Was it running ok beforehand and has gotten worse?
Made any changes to the bike?
Few possibilities:
Blocked and dirty air filter (check this first)
Jet too rich
Float height incorrect(flooding)
Float needle worn or dirty(flooding)
gasket/seals in the carb worn
Something blocking the inlet to the airbox.
Fizzer Thou
PostPosted: 22:37 - 12 Nov 2012    Post subject: Reply with quote
I am not sure what bike the OP is riding but if the bike is standard there should be no reason to change the spark plug model.
If the bike is carbied,check to make sure that the choke mechanism is switching off completely once the engine is up to temperature.
But if the bike is fitted with fuel injection,items like a coolant temp sensor going faulty would tell the ECU that the engine is not hot enough to lean off the mixture and so constantly run the engine rich.I have diagnosed this fault before and is easy to check if you have a service manual or Haynes/Clymer.
Always have a 'Plan B'
mikojh
PostPosted: 22:51 - 12 Nov 2012    Post subject: Reply with quote
Exhaust is looking ok.
That pic for normal looks black to me with grey on the electrode.
I've never used the choke on this bike as its never needed it. Its definitely off however (revs go nuts with it on as its an auto adjusting choke). I'm just waiting for some tools and will be dismantling the carb this week and as far as i know my spark plugs have always been black from the get go even before the power problems. Pic attached of my plug.
Bikes a Suzuki EN 125
cb1rocket
PostPosted: 23:06 - 12 Nov 2012    Post subject: Reply with quote
that looks just right except the picture is out of focus
Thorn This post is not being displayed because the poster is banned. Unhide this post / all posts.
Shaft
PostPosted: 23:31 - 12 Nov 2012    Post subject: Reply with quote
If anything, it looks like it's burning a bit hot.
On my 'puter, the centre ceramic seems bright white (should be a nice biscuit colour) and the outer electrode appears to be misshapen, like it's been spark eroded.
mikojh
PostPosted: 07:53 - 13 Nov 2012    Post subject: Reply with quote
I've got a big list of things that need to be done this week. After that hopefully I'll know whats causing the power problem. If not ill have to get rid of the bike. I'm guessing either the carb or crap in the tank is to blame. Gonna change the air filter while im there as well.
The last post was made 13 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.24 - MySQL Queries: 15 - Page Size: 70.42 Kb
