| biker7 |
 biker7 Crazy Courier
| Pete. |
 Pete. Super Spammer
 Posted: 09:29 - 13 Nov 2012 Post subject: |
Use a foot-long bar and find a 72lb child to stand on the end of it.
Hard to say anything more without knowing your size and build. If you're a skinny non-physical type you might struggle to pull a spanner up to 72lb-ft with one arm. If you're 12 stone or more you should be able to do it comfortably. I just do mine up tight. ____________________ a.k.a 'Geri'
| Polarbear |
 Polarbear Super Spammer
| biker7 |
| Walloper |
 Walloper Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 15:25 - 13 Nov 2012 Post subject: |
Too tight is worse than too lose? Can't say I agree with that. Every threaded fastener has a minimum torque that's needed to stop it coming undone, though most spindle nuts are the locking type now. Motocycle spindle bolts clamp the assembly to stop the wheel pulling forward under power and loading the adjuster bolts. They also keep the whole assembly stiff and prevent bending loads on the spindle.
Too tight just means it's too tight. The only harm you could do is strip the threads or deform the washers. You have to be some kind of animal to strip spindle threads. A mate of mine did it by using a club hammer and long 36mm spanner because he was worried about it working loose, but I can't see you managing it with 'normal' tools. ____________________ a.k.a 'Geri'
| biker7 |
| Walloper |
| barrkel |
 barrkel World Chat Champion
 Posted: 20:03 - 13 Nov 2012 Post subject: |
I once arrived in Germany with my ER6 and figured the chain needed adjustment. Imagine my surprise when I found the axle nut loose! Not in danger of coming off because of the cotter pin, but loose nonetheless. Went over 1000 miles on it like that.
I now check second-hand bikes bought from dealers a lot more thoroughly... ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Kickstart |
 Kickstart The Oracle
| Pete. |
 Pete. Super Spammer
| J.M. |
 J.M. World Chat Champion
 Posted: 20:32 - 13 Nov 2012 Post subject: |
I'm not of a particularly strong or muscular build... I find that just doing it up as tight as I can with a standard sized 1/2 inch ratchet works perfectly.
I own a torque wrench... but really only ever use it on my sump plug.  ____________________ 2004 R1 & 2018 XSR900 |
| bikenut |
 bikenut World Chat Champion
| mudcow007 |
 mudcow007 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:51 - 14 Nov 2012 Post subject: |
Two grunts, the second one to make sure that the first one wasn't acid reflux.
I'm trying to picture a professional spanner monkey even looking up the torque figures let alone bothering about them, but all I keep coming up with is the more likely scenario of Santa Claus and the Easter Bunny double-teaming a Man Friendly Lesbian. ____________________ Biking is 1/20th as dangerous as horse riding.
| Walloper |
| janner_10 |
 janner_10 World Chat Champion
| Walloper |
| Polarbear |
 Posted: 17:47 - 14 Nov 2012 Post subject: |
There is a big debate going on at the moment on the Triumph Explorer forum over torque settings. Powerbronze issued a safety notice over the torque settings of their hugger mounting bolts which are the rear caliper mountings. Triumph say 40 Nm, so did PowerBronze but their new safety notice says 86Nm.
No effing chance PowerBronze, you have fucked up seriously. ____________________ Victory Cross Country American tractor. |
| Walloper |
| Pete. |
 Pete. Super Spammer
 Posted: 20:21 - 14 Nov 2012 Post subject: |
That's true and it's why really important torque values include the lubricated condition e.g. 'dry' or 'moly-lube thread and under bolt head'
It gets even worse if you have a fine thread when clamping forces can go through the roof. ____________________ a.k.a 'Geri'
| janner_10 |
 Posted: 22:29 - 14 Nov 2012 Post subject: |
Yeah that's proberly fair comment, doing things up very tight is me being lazy and walking to the w/shop for the (perfectly decent and hardly used) torque wrench. Familiarity breeds etc. etc.
FYI Unreliability keeps me in a job!!
To the OP: Torque wrench wouldn't be the worst purchase to be fair. ____________________ Yamaha FZS600 (Now gone to heaven) > CBR600F4i (SOLD) > '99 YZF-R1 |
| Walloper |
 Posted: 05:15 - 15 Nov 2012 Post subject: |
| janner_10 wrote: |
To the OP: Torque wrench wouldn't be the worst purchase to be fair. |
Your stuff doesn't really require very specific torque by nature.
It is not structural integrity that is the main concern. Mainly it's simply clean and tight.
The cables don't hold the engine or motor inthe frame. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| bikenut |
| Walloper |
The last post was made 13 years, 319 days ago. Instead of replying here, would creating a new thread be more useful? |
