| mikojh |
 mikojh Nitrous Nuisance
| at106 |
 at106 Brolly Dolly
 Posted: 22:25 - 14 Nov 2012 Post subject: |
The valve clearance of 13mm is wrong and im guessing it should be 0.13mm. Any set of feeler gauges for these ranges will be fine
When you strip and clean the carb no measuring is required unless you want to check the float height which could be a good idea! To do this you can use a steel rule of vernier caliper.
To check for air leaks start the bike and leave it idling, if it has an air leak when you spray wd40 around the rubber the revs will change. |
| numpty2 |
 numpty2 Trackday Trickster
| mikojh |
| Pete. |
 Pete. Super Spammer
 Posted: 22:59 - 14 Nov 2012 Post subject: |
It's a typo, plain and simple. It's supposed to read 0.13mm ____________________ a.k.a 'Geri'
| numpty2 |
| mikojh |
| temeluchus |
| mikojh |
The last post was made 13 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
