| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:14 - 15 Nov 2012 Post subject: Dirty Pictures inside......of my brake caliper |
My bike had a service a while ago, and afterwards the front brake was amazing (all relative). But on closer inspection, it feels like the pads are binding to the disc. Takes a bit of effort to rotate the wheel by hand, friction noise present.
It's a small Chinese 125 ( Jianshe JS-1256a ). Marketed as an AJS JS125-E2
Part of the point of owning this bike is I'd like to service it myself.
Problem is, there is no service manual for it. And the generic Haynes Chinese Bikes manual does not cover this specific model, but I'm using that and Youtube clips trying to get a handle on things.
Done an oil change and tightened the chain.
Single pot caliper.
I've tried using the bb code img quotes and can't get pics to embed, so links are below instead:
pic1
Black hose into gold union bolt?
To the right is the bleed valve, again gold, small black cap?
To the right of that, the medium sized black disc. Appears to be a rubber cover maybe. To the right of that is one of the silver bolts that holds the caliper to fork.
Below the larger disc shape (piston?) is a small rubber thing. I gave it a pull and it stretched 5mm out. I gave it a push and it squished in. Is this some sort of finger pump thing? You can better see it in pic2, with the number 39 on it.
another pic at slight angle
pic2
Pic2 is just a shot of the underside.
It was my understanding that to clean a caliper
1. Slacken the caliper bolt (not those which attach it to the fork, but those that go through the caliper itself. But where on mine is that/those?
2. Remove two bolts holding caliper to fork
3. Remove shim/clip and let pads fall out together to avoid grit / oil getting on them.
5. Use soapy water and toothbrush to clean around piston, taking care to not damage seal.
6. Check wear markers on pads.
6. Push piston in, press break leaver to check piston comes out smoothly.
7. Re-assemble.
I'm guessing that the bolt I first need to slacken might be hidden behind a possible rubber/plastic cover in pic1. That medium sized circle to the left of the first fork bolt.
But, I don't want to do what I just did, and push / pull, stick a screwdriver in and end up damaging something. Like I might nearly have done just tugging on that small rubber thing at the base.
I'm grateful for any pointers / explanations of the pics and what I should do. I'm keen, but usually cock it up
Many thanks!
| Polarbear |
 Polarbear Super Spammer
| el_oso |
 el_oso World Chat Champion
| Pigeon |
 Posted: 00:02 - 16 Nov 2012 Post subject: |
Many thanks guys, this info is exactly why I asked. I would have tried to shove a screwdriver in that medium sized cap at the top expected to expose a bolt and probably done more harm.
A job for Sunday. Question is, will I be taking the bus on Monday
Many thanks. |
| janner_10 |
 janner_10 World Chat Champion
| Pigeon |
 Posted: 23:40 - 16 Nov 2012 Post subject: |
I've had the bike 18mths + 8,000miles, its been parked outside 24/7/365, it's been ridden daily regardless of weather (except for 2 weeks when the snow was too bad).
It's been great, started every time, never cut out, never left me stuck. Averaged 112MPG
OK it's slow, suspension is basic (I'm 16st) and washing it twice a month is a must. But it always puts a smile on my face and I want to try my best to keep it that way.
So I undid the two bolts holding the caliper to the fork then I undid the two bolts that ran through the black casing and brake pads . There was some crud in here, but I used a toothbrush with warm soapy water, then a houseplant sprayer with plain warm water to clear it out. The bolts that ran through the casing and pads are poor quality. They had some scoring and crud on the smooth part of the bolt. So I used some fine emery and smoothed them, then added a very thin layer of grease to the smooth part of the bolt.
There was some small build up on the 1st 2mm of the piston, but I pumped the lever to get 15mm showing and cleaned it up
I tried to take a video of the piston moving when repeatedly pulling the hand lever. Piston seemed to be ok, video a bit shakey .
What I don't understand, there doesn't appear to be anything that forces the piston away from the pads. Squeeze the bar in and the piston moves out 1mm, let the bar back and the piston moves back 0.25mm ish. Is this how these basic ones work?
The net result is the pads are always, to some degree, in contact with the disc. There is noticeable resistance when rotating the wheel.
Is it just a crappy caliper. Or should I have gone further and taken more of it apart somehow?
Having had the part off, I'm still clueless as to what I could have taken apart to check out.
I put it back together, used some 99% isopropyl alcohol to clean the disc.
Looks like I'll be riding to work behind the Bus on Monday
I'd like to have a go at putting thicker fork oil in at some point, check the timing, replace the chain+sprocket, clutch plates, tyres etc
But if it aint broke...... and before you say it, "being Chinese it won't be long before it does break"  |
| mentalboy |
 mentalboy World Chat Champion
| kramdra |
 kramdra World Chat Champion
 Posted: 01:15 - 17 Nov 2012 Post subject: |
I have a similar issue with my brothers chinese 125. The brake system was new to replace the old one. Good bikes apart from that.
Test if the binding stops after bleeding out some fluid. Careful not to let air in. This is the temporary fix I use. It lasts a couple of weeks/month. Keep an 8mm? spanner and some tissues with you incase
for the amount of movment in your video, I think calipers probably fine.
Check your brake lever is not pushing on master cylinder piston, as it wont let fluid return if it is. THIS has caused a few crashes with chinese levers on sportsbikes. But I dont blame the levers, it should be checked and adjusted on installation.
I may have damaged the piston/seals pushing pistons back in when taking the wheel out once.
HOWEVER for a new system, the fluid is a really shit brown colour, when new fluid should be clear. So Im blaming fluid/possible master cylinder blockage. Have intended to change fluid for a while now.. might do tomorrow.
Would like to try/see some radial tires in it, but cost too much. |
| Pigeon |
| YBR Ric |
 YBR Ric Spanner Monkey
| Pigeon |
 Posted: 00:01 - 18 Nov 2012 Post subject: |
Thanks Ric. I know last winter the disc was rubbing on the pads as it was audible and the disc very hot with little use. As with most parts on the bike, it does the job, but is cheap and clearly has limits.
I will remove the lever tomorrow. Have also bought some DOT4 and will have a crack at replacing whats in there (been 18mths).
Spent a couple of hours today installing a 250w Metal Halide Floodlight inside the garage. No more groping around under poor light. Might even get a tan  |
The last post was made 13 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
