| J.M. |
 J.M. World Chat Champion
 Posted: 15:48 - 15 Nov 2012 Post subject: A list of tools to save for |
In the new year sometime I want to completely strip by bike down and rebuild it. I'm talking full service.
I want to do it for a few reasons; to increase my knowledge and because the engine is running a little rough. Whilst it's in bits I'll take the chance to tidy it up a bit too; maybe paint the frame, put braided lines on, service the forks and brakes.
Whether I do it or not is dependant on whether or not I'm able to borrow a bike for the duration of the rebuild though Still, I want to build a complete list of tools that I would need and should have to do such a task. That way I can start saving up for them now and start buying the piece by piece. Price is very important as I don't have a whole lot of cash; read about £20 a week if I don't go out at all.
So far my tool collection consists of:
- Halfords 235 piece Dynamic Tool Chest
- Hammer
- B&Q Mole Grips (which are rubbish)
- Multimeter
- Torque Wrench (not sure of the range... probably starts at 25nm)
- Adjustable Spanner
- Cheap Soldering Iron + Solder Remover + Solder
The things I know that I'll be needing:
- Feeler Gauge
- Spark Plug Gap Tool
- Compression Tester
- Cam Chain Riveter Tool
- C Spanners
- Homemade carb syncing tool
- Impact Driver
- Lower Range Torque Wrench
- Rubber mallet
- Better Mole Grips & Vice Grips
- Heat Shrink
- Assortion of electrical connectors
- Something suitable to hold the clutch & flywheel
- Valve Shim Tool
- Valve Spring Compressor
What are the other tools that I'll be neededing for such a job and what sort of prices should I be expecting to pay?
I have downloaded a 4 part video of somebody doing a top-end rebuild on the exact model of engine that I have and have the Haynes manual too to help me along, but neither really detail what I need to buy in detail.
Any suggestions would be nice and I'll edit them in to this post and build myself a list and purchase tools as and when I can afford them.
Thanks  ____________________ 2004 R1 & 2018 XSR900
| mrdelmonti |
 mrdelmonti Renault 5 Driver
| J.M. |
 Posted: 16:04 - 15 Nov 2012 Post subject: |
ok thanks  ____________________ 2004 R1 & 2018 XSR900 |
| Joncrete Cungle |
 Joncrete Cungle World Chat Champion
| Bezzer |
 Bezzer World Chat Champion
| Aff |
 Aff World Chat Champion
| Walloper |
 Walloper Super Spammer
| J.M. |
 Posted: 17:42 - 15 Nov 2012 Post subject: |
I would add screw drivers and allen keys to that list depending on what is in the Halfords kit you already have.
As to a digital torque wrench, my feeling is that it will just give you a precise read out, without necessarily being accurate (plus probably easily damaged). Would be better to spend the extra money for the digital read out on something of a higher quality.
| orac |
 orac World Chat Champion
 Posted: 17:46 - 15 Nov 2012 Post subject: |
i use one of these to remove the fly wheel
https://www.machinemart.co.uk/shop/product/details/cht248-13-pce-harmonic-balance-puller?da=1&TC=SRC-balance+puller
however if it the GS, you may need to find a correct puller or look to see if this will work (same as i use for removing my starter clutch)
https://www.machinemart.co.uk/shop/product/details/laser-1914-gear-puller-4-23-leg-reversible?da=1&TC=SRC-gear+puller
the motor isnt in the bike you will also need to find a way to hold the crank (specialy if you dont have an impact wrench).
clutch centre holder (will be needed to correctly torque)
https://www.ebay.co.uk/itm/Sealey-Tools-VS1812-Motorcycle-Clutch-Flywheel-Pulley-Holder-Universal-Motorbike-/140666811895?pt=UK_Motorcycle_Parts&hash=item20c06535f7
this may come in handy for holding your flywheel too
https://www.ebay.co.uk/itm/FLYWHEEL-CLUTCH-PULLEY-HOLDER-SEALEY-VS1811-MOTORCYCLE-/190389398573?pt=UK_Motorcycle_Parts&hash=item2c5417ac2d
also you are going to need various micrometers and, and maybe a plastiguage to check things like crank shaft wear. also depending on how far you want to go, you may well need a set of v-block, dial gauge and stand to check for crank straitness.
oh an nearly forgot you will need to check the conrod eyes and bores for where too, so you will need to either go to a shop to have them checked, or buy the correct tool (which the name eludes me at this time)
oh a set of vernier caliper are extremeley hand too. along with a good work bench fitting to a decent vice.
do you have valve spring compressor, lapper, seat cutters and maybe a reamer dpending on wear??
rebulding a motor correctly isnt that simple, most dont bother as the cost of the tools isnt worth it for just 1 job - so maybe you can borrow some ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| janner_10 |
 janner_10 World Chat Champion
| J.M. |
 Posted: 17:56 - 15 Nov 2012 Post subject: |
Just looking to do as much as a can whilst spending only a reasonable amount on tools. I see tools as a worthwhile investment because I've got an entire lifetime for them to prove their value to me in terms of less trips to the mechanics
But obviously what I can actually afford on a student budget is a big issue.
I know that I need to go as shallow as checking the valve clearances, anything else that I can do at the same time without costing a fortune is a big bonus
The video that I watched went a little deeper than the valve clearances and replaced something else too but I can't think exactly what, I'll have to rewatch the video. They also used this big "G clamp" for some sort of spring compression I think? ____________________ 2004 R1 & 2018 XSR900 |
| J.M. |
| J.M. |
| Vincent |
 Vincent Banned
| orac |
| haroman666 |
 haroman666 World Chat Champion
| swampy |
 swampy World Chat Champion
| Vincent |
 Vincent Banned
| orac |
 Posted: 23:33 - 15 Nov 2012 Post subject: |
the GS fly wheel goes on the other way up with the magnets facing out, the starter clutch and idle reduction gear (i think tha what they call it) goes underneath. the idea is not to hook onto the fly wheel but the onto that gear.
i will try and find a picture tmrw. as for that first pick, most fly wheels have three threaded whole which is where you screw the bolt in to use the balancer puller - this is not an option with th gs5 as it does not have those threaded whole iirc
should give you an idea
https://www.suncoastcyclesports.com/servlet/the-141585/03-06-Kawasaki-Z1000/Detail ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
| N cee thirty |
 N cee thirty Banned
 Posted: 23:38 - 15 Nov 2012 Post subject: |
dremel can be quite useful  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| J.M. |
| Vincent |
 Vincent Banned
The last post was made 13 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
