Bullet to ring conversion
TheSmiler
PostPosted: 14:52 - 16 Nov 2012    Post subject: Bullet to ring conversion Reply with quote
I've got a battery similar to this one below not the same make. It's a pain to charge the battery with bullets as I'm using a screwdriver at the moment to wedge into the plastic part.
https://i.ebayimg.com/t/Honda-CG-125-K-Brazil-1989-CB2-5L-C-Motobatt-Motorcycle-Battery-Upgrade-/00/s/MTAwMFg5NjQ=/$(KGrHqZ,!hIE8jp(LCbyBPM+qTUPh!~~60_35.JPG
Want to convert it into the ring connector as so what would be the best method, also I've been told by a local bike garage not to touch motobatt which I thought was a good make because they are chinese and not worth it (decided keep the CG for a bit as its cheap to run) Question
https://s2.postimage.org/96h4e7xcb/blueringterm.jpg
DrDonnyBrago
PostPosted: 15:20 - 16 Nov 2012    Post subject: Reply with quote
Motobatt get really good reviews, loads on here use and rate them.
I'd hazard that the bike shop isn't being entirely unbiased Wink .
PostPosted: 15:21 - 16 Nov 2012    Post subject: Re: Bullet to ring conversion Reply with quote
Why not just wire in a 'charging' connector?
Much more elegant, similar cost and less hassle generally.
PostPosted: 15:24 - 16 Nov 2012    Post subject: Reply with quote
Motobatt are American, not Chinese. The person you spoke to is talking out of his backside.
PostPosted: 15:30 - 16 Nov 2012    Post subject: Reply with quote
Well, they are Chinese made.
janner_10
PostPosted: 15:49 - 16 Nov 2012    Post subject: Reply with quote
Hahadumbarse wrote:
cut old wire...
strip some of the coating off..
stick it in the hole..
crimp it.
This.
2 second job. ifyoudon'twanttobuya crimper I canpostyouminewithacoupleofcrimps, thenpostitback.
edit: wtf spacebar
PostPosted: 16:35 - 16 Nov 2012    Post subject: Reply with quote
Or should we differentiate between "Chinese made" and "Made in China"?
So these are made in China to the specification of an American company.
As opposed to a battery that has been made in China by the Chinese.
Regarding the ring terminals. I don't understand. What are you proposing to attach them to?
Teflon-Mike
tl;dr
PostPosted: 17:08 - 16 Nov 2012    Post subject: Reply with quote
Why do you have to keep charging your battery?
Inconveninent connectors.... is a little bit of skew logic there my-lad.... the 'problem' is not that the connectors are inconvenient to connect to the battery, but the fact that you are charging it from a mains supply charger, not as is really intended, from the bikes engine generator......
Personally, I'd chop the wires off your battery-charger about 1/2 way down, and solder on an AMP connector, between the cut, so I could swap between the crocadile clips and something else.
Then I'd get half an AMP connector.... preferably the one that mates to what ever you pout on charger side of the splice in the charger leads..... couple of feet of 8A + wire and a pair of Jap standard bullets to connect to the battery terminals.
Getting super-clever, I might EVEN put male/female ends on the charger connector, so that it could be connected in with the battery on the bike, still connected to the bike, and the lead with the AMP connector, run behind side panel or some-where, it could be tucked out of the way and left on the bike. Park-up - Plug-In.
Actually done that for Snowie's bike and planning on doing like-wise for the Dawg, for removal-less charging / conditioning. But that's because of constant drain from alarms, and e-start needing decent battery charge to avoid laboured starting.
You have a CG with a Kick-Start......
Indulge me a second Smiler...... BUT I have to ask?
is your bike a 12v or 6v?
Does it have the right battery? Ie 6v for 6v genny, 12v for 12v genny? You aren't trying to charge a 12v battery off a 6v engine are you? Or worse, trying to charge 6v battery from 12v car battery charger?
Add on ED: Oh, and answer to OP - you need 3.9mm 'Japanese Standard' bullet connectors, (See VWP - https://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/noninsbullets.php) Not 4.7mm buillets like wot you get at Halfords & the like for cars.
PostPosted: 17:25 - 16 Nov 2012    Post subject: Reply with quote
So is an iPhone, it is still the best of breed for smartphones...
Very little is made outside of China these days.
janner_10
PostPosted: 17:39 - 16 Nov 2012    Post subject: Reply with quote
https://www.hjo3.net/orly/gal1/orly_bush.jpg
fireyphoenix1...
PostPosted: 08:20 - 17 Nov 2012    Post subject: Re: Bullet to ring conversion Reply with quote
Hes a fucking idiot then Rolling Eyes
one of the first things i do is throw a motobatt in no hassle more reliable and seem too kick out much higher cranking speeds that yuasa acid batts for example
2014 Aprillia dorsoduro 750 factory.
TheSmiler
PostPosted: 14:44 - 17 Nov 2012    Post subject: Reply with quote
The battery has to be charged because basically gone at the moment getting a new one next week anyway. This was why I was asking about the motobatt as well. This is the exact one I will be purchasing Battery HERE .
But this question was resolving around converting from bullet to ring anyway. Which will be sorted now thank you to this thread.
The bike is 12V, It is a UK Model and they were converted over in 1985 from 6v to 12V.
Does it have the right battery? Ie 6v for 6v genny, 12v for 12v genny? You aren't trying to charge a 12v battery off a 6v engine are you? Or worse, trying to charge 6v battery from 12v car battery charger?[/quote]
The battery is 12V and the charger is 12V don't worry I'm not that stupid.
janner_10 wrote:
Hahadumbarse wrote:
cut old wire...
crimp it.
This.
edit: wtf spacebar
Thank you for the kind gesture however I've got a wire crimper (didn't know what it was until seeing the post though Thumbs Up
Walloper
PostPosted: 17:07 - 17 Nov 2012    Post subject: Reply with quote
Care to exzajeraite a bit on that one?
Maybe a lot of stuff we buy is made in China. Smile
There are still a few countries making stuff.
As far as Made in China goes. We use quite a bit of Chinese oil field equipment. It is basic 'age of steam' but with modern Cyber coming into it more and more. The iron is still made of melted down bikes and wheel barrows though which is what really makes it shite. And tech books are a laff until you need to consult them for help at 02:30 in the mornin when something expensive and unique shits it's sel'.
But.... If there is Western supervision and tech help in a Chinese factory the stuff is much better.
They can make very decent stuff but to other country standards. Chinese standards are like Chinese food. Alright for a tightener but you'll be hungry half an hour later.
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 92.21 Kb
