Brake system woes...
mysterious_rider
PostPosted: 16:39 - 16 Nov 2012    Post subject: Brake system woes... Reply with quote
Hi guys, got a bandit 600 with a rear brake that is next to useless, It's been modified, but when bought it wasn't working anyway.
Basically, standard brake, but with a gn250 longer brake line, and the master cylinder is laying sideways. I've bled the system through multiple times and it refused to work at all,
So today, I ripped apart the brake caliper, removed pistons, then cleaned all the seals etc, fitted and I have a brake, but it's super weak. No matter what I do it doesn't improve. On standstill it works, but if you really try and move the bike it slips.
Any idea what I'd need to change? From what I can tell the cylinder is pushing enough fluid out? Then the line, seems okay? What about the brake? Worth getting a brembo?
2 litre
PostPosted: 16:44 - 16 Nov 2012    Post subject: Reply with quote
The brakes aren't great on the Bandit anyway but I would just put the proper MC and brake line on (changing the line to a ss will help a bit) maybe some decent brake pads aswel.
mysterious_rider
PostPosted: 16:46 - 16 Nov 2012    Post subject: Reply with quote
the cylinder is standard, the only thing thats different is its sideways, and the line has been changed with a gn250 one because it's longer.
It's baffling why it's not gripping the disc enough.
cheers
2 litre
PostPosted: 16:48 - 16 Nov 2012    Post subject: Reply with quote
cheers
Have you got a full pedal ? is the pipe ok ? it's not slighlty blocked or something ?
mysterious_rider
PostPosted: 17:44 - 16 Nov 2012    Post subject: Reply with quote
its not blocked because when bleeding it pumps nicely from the cylinder. Not kinked, and no bulges from what i can tell. And the pedal setup is good. Works okay.
mentalboy
PostPosted: 18:12 - 16 Nov 2012    Post subject: Reply with quote
I'd be inclined to try, the already mentioned, braided hose route. Just because you can't see a bulge in a hose doesn't mean that it isn't. If you've increased length it may just be too much for that hose in conjunction with different master.
Make mine a Corona.
mysterious_rider
PostPosted: 18:52 - 16 Nov 2012    Post subject: Reply with quote
Yes it's on a project bike. I think the master cylinder must be weak then. Not sure what else to upgrade to. It runs a 10mm banjo I believe.
https://i270.photobucket.com/albums/jj88/mysterious_rider/Photo0374.jpg
mentalboy
PostPosted: 19:02 - 16 Nov 2012    Post subject: Reply with quote
The orientation of that cylinder will make no difference as the reservoir still has a good head. It does look a bit manky on the forward end though.
EDIT: The quality of the steel used in those stainless footplates sucks
Make mine a Corona.
The last post was made 13 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.4 - MySQL Queries: 13 - Page Size: 59.51 Kb
