motorbike swing arm play sym xs 125
stranger12
PostPosted: 12:12 - 19 Nov 2012    Post subject: motorbike swing arm play sym xs 125 Reply with quote
HI all,
i was adjusting my chain last night and noticed a bit of slack or play in the swing arm . Basically when i shake the rear wheel while on centre stand i can feel a bit of movement which after it was chased it points back to the piviot point ( if that is correct word) . it is where a big bolt is going from one side to another. Picture is below
https://img832.imageshack.us/img832/9268/img0756qw.jpg
Uploaded with ImageShack.us
My chain had around 5 cm play and after adjustment the situation on the swing arm seemed to have improved slightly. But the play is still there any ideas ?
I checked the nut on the other side and it seemed to be fully tightened .
In addition I found out that the small sprocket has a slight play , is that normal ? i mean the one in the picture below
https://img694.imageshack.us/img694/4308/img0755mm.jpg
Thanks
Fizzer Thou
PostPosted: 13:38 - 19 Nov 2012    Post subject: Reply with quote
It sounds as though the swing arm bearings have failed.These can be either needle bearings or plain oilite bushes.If there are no Zerk grease nipples there then these bearings are easily neglected.
New bearings are not difficult to replace.If you have the right tools.
In some instances it is a good idea to drill and tap the swing arm in a convenient place and to install grease nipples adjacent to the bearings.These cost pennies in comparison to new bearings.
As for slight play with the front sprocket,there is usually some movement there.Cheap pattern sprockets are never as good a fit as other genuine or aftermarket sprockets like Renthal or Talon.Any slop in the drive chain run is accentuated when going from a closed to open throttle,despite careful adjustment.
Always have a 'Plan B'
stranger12
PostPosted: 15:21 - 19 Nov 2012    Post subject: Reply with quote
thanks for this, is it possible that my swing arm does not have any bearing ?
my bike is only 6 month old so not sure why this would fail,
what would be the impact of it if left unrepaired?
many thanks
bikenut
PostPosted: 16:12 - 19 Nov 2012    Post subject: Reply with quote
new bike 6 months old?? take it back to the dealer who should fix unde4r warranty.
having said that, some chinese bikes have poor build quality etc.....
stranger12
PostPosted: 10:15 - 20 Nov 2012    Post subject: Reply with quote
i will but wondered to know if small play is acceptable and left there intentionally which i guess is not the case
out of interest if left as it is what can it cause ? would it cause the bike rear wheel to move from side to side as result of the slack in the swing arm bearing ?
The last post was made 13 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 15 - Page Size: 44.22 Kb
