Tokico 6-pots seal kit - genuine or wemoto?
Kris
PostPosted: 12:20 - 19 Nov 2012    Post subject: Tokico 6-pots seal kit - genuine or wemoto? Reply with quote
For a mk2 Bandit 12 front brake rebuild.
The wemoto kit is £55 plus delivery. OE seal kit is ~£100.. Shocked
Anyone used the pattern seals successfully?
Thanks
www.prisonplanet.com
c_dug
PostPosted: 12:28 - 19 Nov 2012    Post subject: Reply with quote
No issue with pattern seals on my CBR callipers.
Bezzer
PostPosted: 12:38 - 19 Nov 2012    Post subject: Reply with quote
Plenty used the Wemoto ones on the Bandit 6 potters with no problems
Fizzer Thou
PostPosted: 13:26 - 19 Nov 2012    Post subject: Reply with quote
How many miles have the original seals done?
Are the seals worn or split?
More often than not I have just cleaned up the existing seals and after a thorough clean of the calipers,rebuilt everything and as good as new.If there is considerable corrosion in the ring lands of the calipers then replacing the seals might be an idea,but not necessarily a must.
Always have a 'Plan B'
devojunior
PostPosted: 13:31 - 19 Nov 2012    Post subject: Reply with quote
I was looking into rebuilding a set of these and a main factor i read why they seized more often than most was the fact that the two inner faces of the caliper is un painted and oxidizes i think the word is.
therfore the seals would seize, wether or not this is true i dont know so if you have them apart id give em a clean and coat in some laqure or pain.
Kris
PostPosted: 15:26 - 19 Nov 2012    Post subject: Reply with quote
Probably original, so 14k over 7 years.
I'm not in the position to strip first then start ordering parts as I use my bike nigh on every day.
Fizzer Thou
PostPosted: 16:20 - 19 Nov 2012    Post subject: Reply with quote
I have reused seals which were over 25k miles old and they still worked perfectly after a rebuild.
But if you at least had a new set from Wemoto then if you do not need them you will have a new set for when needed.After all,14k miles is not very much unless the pistons are so severely corroded in place as for the dust seal to be forced out between the caliper and the piston.I have seen this on calipers which had been sadly neglected and the owner paid the price by having to replace all of the seals where only OEM seals were available.
PostPosted: 16:31 - 19 Nov 2012    Post subject: Reply with quote
Borrow the sixpotters off my bike if you want for a week whilst you get yours rebuilt. Alternatively, look out for some blue spot 4-pot calipers and junk the 6-pot rubbish.
StevRS
PostPosted: 17:09 - 19 Nov 2012    Post subject: Reply with quote
You can reuse, but you need to be uber-careful getting them out.
Given that brakes are pretty important, it's a small price to pay for ongoing reliability and peace of mind. It only takes one seal to go and you've got no front brakes.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
PostPosted: 17:14 - 19 Nov 2012    Post subject: Reply with quote
They come out and go back in very easily, and they are a chunky seal so not really easy to hurt. Done mine a couple of times.
The biggest problem I've found is the groove builds up with corrosion, sometimes millimetres deep in the bottom. The dust seals don't really do much and the bare ally is easily rotted by road salt.
kramdra
PostPosted: 18:23 - 19 Nov 2012    Post subject: Reply with quote
this is interesting. Ive got a spare pair of calipers for my 125. Thinking I could clean them up, only 3 years old. whats best tool to get the seals out?
PostPosted: 18:30 - 19 Nov 2012    Post subject: Reply with quote
A pick is the proper tool but you can use anything thin and pointy but not too sharp. Run the tool around one side of the seal to un-stick it, then do the other side, then pull out a little loop of seal and draw it around out of the groove.
PostPosted: 19:35 - 19 Nov 2012    Post subject: Re: Tokico 6-pots seal kit - genuine or wemoto? Reply with quote
Check other sources for the seals. From memory both Suzuki GSXR1300 and Kawasaki ZX12R use the same 6 pot calipers (and think they are the same as the Bandit), and the seals are quite a bit cheaper from Kawasaki.
PostPosted: 19:47 - 19 Nov 2012    Post subject: Reply with quote
Yes, and Kawasaki sell them singly whereas Suzuki will only sell a set.
Fisty
PostPosted: 20:16 - 19 Nov 2012    Post subject: Reply with quote
I have a full set of pattern seals you can have for £30.
And 2 pairs of brembo red pads for £30.
Fatter and faster than Fret
Kris
PostPosted: 09:58 - 20 Nov 2012    Post subject: Reply with quote
Thanks, I'll take those! Where are they from?
The last post was made 13 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 92.39 Kb
