| ather7on |
 ather7on Derestricted Danger
| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 11:43 - 21 Nov 2012 Post subject: |
STOP riding her, she needs work BEFORE she blows.  ____________________ Jogging on, destination living. |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 11:50 - 21 Nov 2012 Post subject: |
Depends on what you mean by a little play. You will get some movement in the bore when the piston's cold otherwise it'd stick when everything gets warmed up and expands. Best bet is to lift off barrel and check it for any untoward scarring. Whilst you're in there check that piston rings still move freely, otherwise though loss of compression could easily be down to the mullered gasket.
If you've got a manual find out what the gap should be when the rings are in the bore and measure it, this will give a fairly good idea if you've got to much play going on.
EDIT: As Covdude says don't ride her, it's bloody hard work on the legs when you've got the head off!!!  ____________________ Make mine a Corona. |
| WannaBeDude |
 Posted: 12:42 - 21 Nov 2012 Post subject: |
Yeah, I leave specifics to likes of above, but these bikes need to run spot on really, they just fuck you off if you chance your arm with them, hence all the bullshit storys ...
Afaik - the Rs125 being arguably the fastest road 125, needs the upmost care -  ____________________ Jogging on, destination living. |
| ather7on |
| mentalboy |
The last post was made 13 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
