Fitting a Speedfight exhaust
haGGard
PostPosted: 15:19 - 03 Nov 2004    Post subject: Fitting a Speedfight exhaust Reply with quote
Hello,
I have just purchased this off eBay.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7930990783&indexURL=0&photoDisplayType=2#ebayphotohosting
I was wondering, does anybody know where i can find a guide on how to fit it myself, as im not sure how and dont want to get it proffesionally done.
Also, are they eay to fit?
Thanks Very Happy
mr.z
PostPosted: 15:31 - 03 Nov 2004    Post subject: Reply with quote
If you have the right spanners and patience you should not have any problems...
However... be VERY carefull with the bolts on the cylinder head. use exhaust gasket paste and (worst bit) you might well need to have it rejetted, otherwise you will not get the same power gain and also risk engine damage through a lean mixture (more airflow with no extra fuel)... if your haveing it rejeted (which you probably should) then a performance air filter is something you should consider too...
That is of course assumeing it is a performance exhaust, otherwise all you have is a very shiney expensive exhaust...
Finglonga
PostPosted: 16:32 - 03 Nov 2004    Post subject: Reply with quote
Probably worth waiting till next year to fit it. The first time the salt hits the chrome it will start to rot. Crying or Very sad
Andy Sez....
F.Y.Y.F.F.
PostPosted: 16:42 - 03 Nov 2004    Post subject: Reply with quote
Fitting a pipe can be a bit tricky, but as long as you have the right tools and some patience, its a quick enough job. As said, you need to watch out not to damage threading on the cylinder.
Hook the thing up, take it for a short spin, (for a mile or two) then yank the plug out and determine whether it needs jetting. Chances are it might need slight adjustment as they are performance pipes.
Of course if you dont feel confident doing the job yourself, it would be best to let a mechanic do it, that way you can blame him if he buggers it up. Mr. Green
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
haGGard
PostPosted: 16:55 - 03 Nov 2004    Post subject: Reply with quote
Hi, Thanks for you comments
I'm not quite sure what you mean about getting it rejetted.. could someone explain this Very Happy
Also, if i needed to get it rejetted, i would consider the new air filter. How much is one of these little gadgets likely to cost (i'm assuming not much)
Thanks
ps. Ns-Keith, you said 'yank the plug out'. What plug do you mean? I'm very inexperienced in this area Confused
divuk83
PostPosted: 17:08 - 03 Nov 2004    Post subject: Reply with quote
No offence, but if your not sure what a jet is or how to take the spark plug out then it might be worth getting someone else to fit it.
Keep the standard filter as it won't improve the bikes performance by putting an open filter on.
Dave
haGGard
PostPosted: 17:12 - 03 Nov 2004    Post subject: Reply with quote
Yeah, i was starting to think that too. Very Happy
So whats jetting then?
Gazdaman
I did a trackday!!!
PostPosted: 17:23 - 03 Nov 2004    Post subject: Reply with quote
It's a jet in the carb, it deturmines how much petrol is put into the mixture in the chamber. You need the mixture to be a perfect mix of petrol (from the carb) and air (from the air filter) to make the most power.
I.e if those are wrong, it's not gonna be good.
Gaz
haGGard
PostPosted: 17:38 - 03 Nov 2004    Post subject: Reply with quote
Right, so i think im going to get a proffesional to do this for me. Very Happy
So if i were to get some guy to install the exhaust, rejet it and maybe change the air filter, how much time would that take for the average professional. Hours or Days?
Gazdaman
I did a trackday!!!
PostPosted: 17:58 - 03 Nov 2004    Post subject: Reply with quote
depends how busy they are, it'd take a skilled professional a couple of hours realistically, but remember they're being paid by the hour, so they're not in any rush.
Gaz
PostPosted: 21:30 - 03 Nov 2004    Post subject: Reply with quote
The spark plug. When you test the mixture, you unscrew it and check the colour and condition of the bottom. An easy way to determine whether you need to adjust the mixture. (in other words, re jet)
Personally, I'd say find a scooter forum which can help you a bit better, who can recommend a suitable jet size and other necessary adjustments. Obviously, if your quite mechanically illiterate, its best not to go playing round with the carb as all sorts of problems could occur.
The last post was made 21 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 70.28 Kb
