Fixing oxford heated grips control box thingy
J.M.
PostPosted: 00:25 - 22 Nov 2012    Post subject: Fixing oxford heated grips control box thingy Reply with quote
Any ideas?
Basically it works but the rubber buttons are terrible.
On/Off works a treat, first time that you press it.
The +/- for temperature barely work at all. With using fingers or gloves fingers they click but nothing actually happens. You can press it 100 times and it might work once, if you're lucky.
If I use a key or a sharp object to press the buttons it works okay, maybe have to press it 2-3 times for it to work once.
Any ideas how I can fix this to make it usable by hand rather than by key?
2004 R1 & 2018 XSR900
janner_10
PostPosted: 00:30 - 22 Nov 2012    Post subject: Reply with quote
No - I had the very same problem on the Fazer - found out they were cheap for a reason - either hotter than the sun or not on. If I wanted to adjust the temp I had to do the same - get off and prod away with my ignition key.
J.M.
PostPosted: 00:37 - 22 Nov 2012    Post subject: Reply with quote
Damn Sad
I wasn't the one who purchased them, they were on the bike when I bought it and were bad then but usuable with fingers (after about 10 presses). It's like it's getting worse despite being used once in a blue moon.
The last post was made 13 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 35.9 Kb
