cush drive rubbers
Sax 1965
PostPosted: 17:21 - 22 Nov 2012    Post subject: cush drive rubbers Reply with quote
got a honda cb 125s have been trying to get cush drive rubbers out of back wheel ,behind sprocket ,got all the rubber out but left with ,outer case still in .any one no how to get the metal case out ,cheers
sax
Aff
PostPosted: 17:27 - 22 Nov 2012    Post subject: Reply with quote
I've seen someone on here dremel them out before.
I've also seen my uncle get some out with a grinder and a chisel.
Basically he made a notch in the metal ring then hit in that notch with the chisel, this cracked the length of the case and he could then pry them out.
If this doesn't work, you could try shouting obscenities at them.
Electric Bike Project
Sax 1965
PostPosted: 18:04 - 22 Nov 2012    Post subject: Reply with quote
chers dude will try
sax
Teflon-Mike
tl;dr
PostPosted: 19:22 - 22 Nov 2012    Post subject: Reply with quote
Try a Dremel you will be there for ever, wearing out tiny grinding stones, getting no-where fast, believe me!
Hammer & Chisel, you have to be FUCKING careful, that steel sleeve is stronger than the alloy around it in many places, you can easily end up damaging the hub, most likely breaking through into the brake drum.
Answer is, a small triangular file, and PATIENCE.... lots and lots of patience!
Use the corner of tri-file as a saw and cut four slots in the sleeve like a petal.
Once through the steel on each petal, you can use a small hammer and engineers chisel / punch to CAREFULLY tap the end of the first petal into the bushe-eye, then get a pair of pliers on it & wiggle free.
Once first segment / petal is out the other three come out the same way, but with a bit more space around them, usually easier.
Repeat for each bush sleeve.... so 16 slots, at about ten minutes a slot, this is a good days morning's work!
Clean up hole with emery, and lightly smear with coppa-slip before the new bush goes in. Job jobbed.
Patience pays.
The last post was made 13 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 41.69 Kb
