Source for tiny r-clips
barrkel
PostPosted: 23:26 - 22 Nov 2012    Post subject: Source for tiny r-clips Reply with quote
I lost one of the r-clips for the brake pad retaining pins on my ER6's front brakes. I have it bodged for the moment with a bent paperclip, but will want to replace it very soon with something that won't corrode.
Trouble is, the OEM clip (part no. 43084-003) is about 2GBP from Kawasaki, not including shipping.
Where can I get a lifetime supply (20 ought to do it) of tiny stainless steel r-clips at a more reasonable price?
Everywhere I Google for r-clips, they are all either enormous or extortionate. Am wondering if I shouldn't purchase some stainless steel wire instead.
barrkel
PostPosted: 23:52 - 22 Nov 2012    Post subject: Reply with quote
Hmmm, I just found this eBay link on a model building forum, not specified as stainless steel though, have asked eBay seller, will update when I find out.
Bezzer
PostPosted: 23:57 - 22 Nov 2012    Post subject: Reply with quote
I got some small stainless R clips from Steve's Stainless. It was on his stall at a Stafford Show so I could see what I wanted. He does mail order as well, you'll just have to know the metal diameter to make sure you get the right ones, 1.2mm probably.
https://www.stevesstainless.co.uk/
bladerunner
PostPosted: 23:58 - 22 Nov 2012    Post subject: Reply with quote
Any model shop that sells rc cars will sell these. They won't be stainless tho....just std off the shelf galv or nickel finish same as the eBay ones by the looks. If you have a local engineering supply shop they should also be able to get hold of them for you......I'd expect to pay about 50p each if they have them in stock.
janner_10
We call them Clevis clips (for clevis pins!!) at work - same thing though.
We use ours for 9mm d oven hinge pins - if that's the sort of size you need let me know and i'll stick some in an envelope for you, got hundreds of the things!
Fizzer Thou
PostPosted: 00:03 - 23 Nov 2012    Post subject: Reply with quote
https://www.screwfix.com/p/bzp-retaining-clips-pack-of-75/42204;jsessionId=y1pMQnnbnvrvnnMgYh1pkw6TT7kyxdX4kQqJFJvjqvygv7mJ9Shq!1488604081!1353625243410
I have a box of these with all sizes that are useful Thumbs Up
Always have a 'Plan B'
Raffles
PostPosted: 01:03 - 23 Nov 2012    Post subject: Reply with quote
Why do you require the longevity of stainless steel? Caliper pins aren't made of stainless so why would you wish to use ''R'' clips that are made of stainless?
You will more than likely have disposed of the bike a long time before the new galvanised ''R'' cips have corroded.
PostPosted: 02:40 - 23 Nov 2012    Post subject: Reply with quote
Or just use a new split pin every time.
barrkel
PostPosted: 02:54 - 23 Nov 2012    Post subject: Reply with quote
Maybe you're right. But brakes are safety critical and right in the line of fire for all the muck that comes off the road. Peace of mind is worth something too.
PostPosted: 03:00 - 23 Nov 2012    Post subject: Reply with quote
Mild steel is about four time stronger than stainless and doesn't become brittle over time. You are defeating your own argument.
The safest, strongest thing to use in that application would be a galvinazed mild steel split-pin.
barrkel
PostPosted: 03:06 - 23 Nov 2012    Post subject: Reply with quote
I wasn't really making an argument, more stating my perspective that I now understand was ignorant. I had more fear of corrosion than strength (the clip isn't load-bearing, as I understand it) or brittleness. I'll get some tiny split pins instead. Thanks.
Ichy
PostPosted: 04:10 - 23 Nov 2012    Post subject: Reply with quote
FWIW. Get a small nail and stick it in a jar of salt water, it'll take years before you can snap it in two. The crappiest metal will last more than long enough for the sort of abuse that it will get on a bike. Stainless is fine. Used as a R clip there isn't any load on it so the discussion of strength is insignificant. Any crud will clean off easily enough and it will always be removable. It is just a matter of cost.
PostPosted: 11:28 - 23 Nov 2012    Post subject: Re: Source for tiny r-clips Reply with quote
Pretty sure I've used the smallest size from those R-Clip selection boxes you get on brakes fine.
Ichy
PostPosted: 16:54 - 23 Nov 2012    Post subject: Reply with quote
Probably not the cheapest option but a damn sight cheaper than the original Brembo ones. I brought THESE off ebay.
andys675
PostPosted: 00:14 - 24 Nov 2012    Post subject: Re: Source for tiny r-clips Reply with quote
+1
used the on a suzuki when I found the genuine clip was £3.70, makes the kawasaki ones look cheap!
The last post was made 13 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 87.14 Kb
