| new001 |
 new001 Nova Slayer
| illuminateTHE... |
 illuminateTHE... World Chat Champion
| hedgehugger |
 hedgehugger World Chat Champion
| Val |
 Val World Chat Champion
| c0m47053 |
 c0m47053 L Plate Warrior
| SierraWhisky |
 SierraWhisky Derestricted Danger
 Posted: 20:45 - 26 Nov 2012 Post subject: |
Back from my days as a boy in blue, we always used to advice people to simply pull over and let the person('s) tailgating to pass. It's not worth the risk to yourself to try and be clever.
There is a school of thought that says to simply slow down to safe speed for the distance that the driver has behind to stop. However, at some point this is going to reduce to the only safe speed being stationary as: when you slow down, the tailgator will start to close the gap even more.
So simply, avoid the games, pull over, let them pass....
...and smile to yourself when you get 1/2 mile up the road and see they've been involved in a fender bender where they're at fault!  ____________________ Suzuki GS 125 ESM (1996)
Complete and utter novice.... but I will get the hang of this! |
| new001 |
 new001 Nova Slayer
| Astandane |
 Astandane Nova Slayer
| Val |
 Posted: 00:21 - 27 Nov 2012 Post subject: Re: Newbie rider ? |
| c0m47053 wrote: | | valko wrote: |
Gently put the brake slow down to 25 then go back to your safe speed 35 this way you increase the distance between tailgaitor and you - this recomended procedure.
I always thought the slowing down recommendation was more about increasing the distance between you and any vehicle in front, allowing you to brake more slowly and reducing the change of the tailgater running into the back of you. In my experience (in the cage, to be fair), the tailgater will just stick to your arse as you speed back up anyway. |
when you increase your speed back you increase the distance.
If he/she closes the gap do it again. It works for me have not seen many tailgaters that do not get the message after the 3rd time.
If you have somebody who is very aggressive you pull out of course and let him go, in most cases tailgaters are just lousy drivers that mean no harm.
In any case if your ride is confident they see you own the road and either will just drive behind you or overtake you when they can, which is perfectly fine with me.
Also bear in mind there is a difference between tailgator and a guy that just closes the gap so that he can overtake you, which again is fine as soon some safe distance of few meters is kept
And I drive for 30 years so I can tell by the way you approach me for overtaking how you will do it.
There are some kind of moronic drivers/riders that think it is obligatory to cut you off immediately after overtaking. Have the cure for the morons, although it works better when I am in my 4x4, but works with bike too.
When you see the moron, just move slightly to the right before his starting to overtake you, when he is doing the overtake move back to the middle of your lane. He tries to cut you off but your position is more to the left and it does not work - the distance is safe and the moron has gone. ____________________ Adrian Monk: Unless I'm wrong, which, you know, I'm not...
Yamaha Fazer FZS 600, MT09, XSR 900 |
The last post was made 13 years, 98 days ago. Instead of replying here, would creating a new thread be more useful? |
