 Posted: 22:41 - 26 Nov 2012 Post subject: How to drill out a broken stud. |
Here is how I tackling the 8 broken studs on my 1996 Bandit. Forget easy-outs and stud extractors for frozen-in bolts, you will veru likely only make things much worse.
There are a couple of tried and trusted ways to remove a stud that has some thread showing.
One way is to put a nut over the stud and weld the end with a mig welder getting it nice and hot, then un-doing the nut which should bring the stud with it. I don't have a mig welder - I have an arc welder but they are much harder to get good results with since the rod is fatter and for small diameter studs it's likely the arc will wander when you try to weld in the well of the nut.
The other way is to drill out the stud. This is no easy task, starting off on the end of a sheared stud is tricky and you must be dead centre to avoid having the drill wander off the bolt into the softer ally threads. This is how I have done it - by making a drill bushing.
First, take an old 12.5mm drill and chuck it up in the lathe backwards. Drill bits are not hardened at the shank so you can drill, file and cut them but they are made from hardenable steel which is what we want. Drill the tail-end 6.8-7mm which is tapping size for a M8 bolt.
https://peterrimmer.myby.co.uk/images/drillstud1.jpg
Then drill it deeper with a 4mm drill, which will be the pilot for drilling out the stud.
https://peterrimmer.myby.co.uk/images/drillstud2.jpg
Now I set up a M8 taper tap in the lathe using the centre to keep it perfectly in line.
https://peterrimmer.myby.co.uk/images/drillstud3.jpg
And follow it with a 2nd tap and plug tap to get the thread right to the bottom of the hole.
https://peterrimmer.myby.co.uk/images/drillstud4.jpg
https://peterrimmer.myby.co.uk/images/drillstud5.jpg
After that I part it off.
https://peterrimmer.myby.co.uk/images/drillstud6.jpg
Now I need to be avble to tighten this bushing, so I file two flats in it for a 10mm spanner.
https://peterrimmer.myby.co.uk/images/drillstud7.jpg
https://peterrimmer.myby.co.uk/images/drillstud8.jpg
Broken studs.
https://peterrimmer.myby.co.uk/images/drillstud9.jpg
Bushing fitted
https://peterrimmer.myby.co.uk/images/drillstud10.jpg
I used the drill rod so I could harden the bushing for use. This involves heating it up to cherry red and quenching. Here is what I did, but unfortunately I could not get it hot enough on my gas ring to lose it's magnetism (which is when it becomes hardenable) so it remained soft - so I used it anyway. Tomorrow I will take it to work and heat it with oxy-acetylene then it will be glass-hard.
https://peterrimmer.myby.co.uk/images/drillstud11.jpg
https://peterrimmer.myby.co.uk/images/drillstud12.jpg
As you see, the drill now takes a straight path directly dwn the middle of the stud.
https://peterrimmer.myby.co.uk/images/drillstud13.jpg
Drill extension for those hard-to-reach ones. Just a bit of mild steel rod, grind four small flats on the drill you use to drill the rod with then poke it in and give it a little squeeze in the vice.
https://peterrimmer.myby.co.uk/images/drillstud14.jpg
Holes drilled, spot on - only 6 more to go.
https://peterrimmer.myby.co.uk/images/drillstud15.jpg ____________________ a.k.a 'Geri'
| neatbik |
 neatbik World Chat Champion
 Posted: 22:48 - 26 Nov 2012 Post subject: |
Awesome.
Cheers Pete, i will remember that one.
| stonesie |
 stonesie World Chat Champion
 Posted: 23:00 - 26 Nov 2012 Post subject: |
This makes me want a lathe, badly.
Top work  |
| binge |
 binge Emo Kiddy
 Posted: 23:41 - 26 Nov 2012 Post subject: |
Where is the Awesome rating when you need it!?!
Nice one Pete! I might need to bell you up about tapping soon. I need to tap 8 holes to M10x1.5, but ideally need the thread to go all the way to the back of the hole.
Ben |
| grahamd1 |
 grahamd1 Trackday Trickster
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| Vincent |
 Vincent Banned
| kestrel |
 kestrel Nearly there...
 Posted: 21:27 - 27 Nov 2012 Post subject: |
Nice well written post Pete. A set of these drill guides manufactured from a suitable material and induction hardened would be a useful addition to anyone's toolbox.
Perhaps you should contact a certain BCF member who has recently acquired a brand new CNC machine.  ____________________ Isle of Man.........Road Racing Capital Of The World |
| kramdra |
 kramdra World Chat Champion
| TomGT |
 TomGT Spanner Monkey
 Posted: 21:36 - 27 Nov 2012 Post subject: |
I'd buy one, as would most of BCF I imagine  ____________________ 1992 ZXR 400 |
| P.addy |
 P.addy Red Rocket
 Posted: 21:37 - 27 Nov 2012 Post subject: |
Easier option.
Sell.  |
| kestrel |
| P.addy |
 P.addy Red Rocket
 Posted: 21:40 - 27 Nov 2012 Post subject: |
Thanks
Great write up Pete |
| Vincent |
 Vincent Banned
| Raffles |
 Raffles World Chat Champion
 Posted: 23:16 - 27 Nov 2012 Post subject: |
Yes, I'll be doing that. 16 years of rot hasfrozen them in and embrittled the bolts, I doubt the bike will be around in another 16. ____________________ a.k.a 'Geri'
| Walloper |
 Walloper Super Spammer
 Posted: 08:17 - 28 Nov 2012 Post subject: |
Good idea and a good example to all BCFers on how to take a bloody photograph for illustration purposes.
A Tip for drilling Exhaust Studs.
They can get hardened form heat/cold cycling and normal bits don't last long when drilling.
I got this idea from an Engineer friend many hoons ago.
Take a masonry bit.
Grind a 'cutting' angle on the top of the tungsten carbide insert. (They are flat or rounded from the factory as they do not cut but impact and mash masonry)
They are very able to take massive abuse in service so are almost indestructible.
When sharpened they whiz through the hardest steel like a hot knife through butter.
If there is concern that the tip will wander then grind the wee bits of 'clearance' off the sides to the same diameter as the shank.
And lubricate. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
The last post was made 13 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
