| map |
 map Mr Calendar
 Posted: 12:18 - 29 Nov 2012 Post subject: Any advice for transferring to new handlebar - heated grips |
Following a spill today lad's bike needs new handlebars.
Going for some affordable Renthal type.
So just wanted some advice on transferring the switches, throttle and the heated grips across.
Can the heating element be removed and refitted or would it be best just trying to get a replacement element (if so what and where)?
The heated grips fitted are Oxford ones.
As said any advice welcome.
Thanks in anticipation  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| sickpup |
 sickpup Old Timer
| map |
 map Mr Calendar
 Posted: 13:00 - 29 Nov 2012 Post subject: |
I'd suggest heating them with their own special built in heating element by means of turning them on and leaving them for a while.
I have heard of someone being given the tip of hooking them straight up to the battery as apparently, even the high setting on the controller is nowhere near as hot as they get. This is hearsay mind so if your handlebars catch fire, don't blame me. I'd suggest applying supervision and common sense if you try this.
Otherwise, all you need is to poke the straw of a can of WD40 up under them and gradually squirt it in as you go, or the end of a compressor blow gun and give it one squirt. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kiddakidda |
 kiddakidda Spanner Monkey
 Posted: 23:12 - 29 Nov 2012 Post subject: |
Create initial gap by putting small thin screw driver between heated grip and handlebar
WD 40 down the grip,
Take one wire coat hanger (preferably the ones with a plastic/rubber coating)and cut about 12-15 inches of wire from it.
Smooth any sharp edges created by cutting the Wire coat hanger.
Create 'L' shape from coat hanger wire ( 6 x 6 inches)
Push one side of the 'L' into the gap that was created by the small thin screwdriver. Right to the other end of the grip.
Rotate the other part of the 'L' shaped wire.
The wire will then rotate completley around the grip, detaching the glue as it rotates.
Grip should twist off freely and undamaged in any way.
Works for me  ____________________ Suzuki SFV 650 (Gladdy) > Triumph Street Triple R |
| J.M. |
 J.M. World Chat Champion
| kiddakidda |
| J.M. |
| map |
 map Mr Calendar
| Islander |
 Islander World Chat Champion
 Posted: 10:44 - 30 Nov 2012 Post subject: |
That top picture has a scotchlok connector included which tells me exactly what I need to know about it...  |
| map |
 map Mr Calendar
| sickpup |
 sickpup Old Timer
The last post was made 13 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
