| Misc |
 Misc World Chat Champion
| P.addy |
 P.addy Formerly known as P.
| mooserx |
 mooserx Nearly there...
| thomp1983 |
 thomp1983 Crazy Courier
| Nb |
 Nb World Chat Champion
 Posted: 19:42 - 02 Dec 2012 Post subject: |
Where to start?! Not very likely your going to fix this without taking it to a decent garage who know what they are doing.
Info on those codes https://wiki.ross-tech.com/wiki/index.php/00668
https://wiki.ross-tech.com/wiki/index.php/01314
Looks like you have an intermittant issue causing all if not most of those codes, a failing camshaft sensor would cause the hard starting for sure but with other codes like the 00668 terminal 30 supply and 01314 ecm communication error it could all be down to a wiring issue somewhere.
Has the car had any water ingress that you know of? ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
Columbus travel insurance are crap!! Do not use! |
| Aff |
 Aff World Chat Champion
 Posted: 11:47 - 03 Dec 2012 Post subject: |
N75 is easy to check if its working, its just a solenoid, so put power across the pins and you should be able to blow through it, when you take the power off you shouldn't.
If you unplug the MAF sensor does it run better. if the sensor is unplugged it reverts to a default program, so if unplugging improves it then you have a bad MAF.
All your codes point towards a bad Camshaft Position Sensor. but your symptoms do not, usually a bad Camshaft Position Sensor will give you a check engine light and stalling/bad running at low RPM. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| AlexW |
 AlexW Spanner Monkey
| Aff |
| Richy CB1000 |
 Richy CB1000 Trackday Trickster
| ijmok |
 ijmok Borekit Bruiser
| Groove |
 Groove World Chat Champion
 Posted: 12:52 - 04 Dec 2012 Post subject: |
Camshaft position sensor went on my diesel X Type.
When it went it would randomly cut out and would restart only after a few cranks. Then one day it failed to start for a good few hours and i called the recovery truck who took me home. After getting the car off the truck i tried again and it started!
Went and bought the sensor which was about £15 and took 10 minutes to fit and touch wood, its not done it again in 6 months.
So, change the fucking sensor.  ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
| ocatoro |
 ocatoro World Chat Champion
 Posted: 14:11 - 04 Dec 2012 Post subject: |
yeah all the speculation is useless when it's showing two intermittent faults which youre not fixing.
the fact that it's even telling you theyre intermittent and that your problem comes and goes tells you those are your problem. or at least your starting point ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None but shed project H100 (first bike )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600 |
| AlexW |
| Misc |
| Nb |
| Misc |
| Nb |
| Groove |
The last post was made 13 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
