v reg 99 Yamaha t-cat project (finally finished)
neiloggy1
PostPosted: 23:10 - 02 Dec 2012    Post subject: v reg 99 Yamaha t-cat project (finally finished) Reply with quote
Finally picked the t-cat up today Very Happy
and had a spare 2 hrs to start work on it.
I think it's in worse shape than seller made out but the price was good for what it is.
So first job strip down and checkout damage Sick
Forks bent
Front Lh disc cracked
Front fender cracked
Both front side fairings cracked
Rear subframe bent
I bet most would walk away but ill sort it Laughing
By next post hopefully have rear end sorted and rest of front end stripped down
Got three choices with frame
Bend back myself
Send to frame alignment shop
Or get replacement frame
pics before stripdown
https://s18.postimage.org/w8salf7mh/IMG_0581.jpg
https://s15.postimage.org/5bckesji3/IMG_0582.jpg
https://s14.postimage.org/hx1ccyuxd/IMG_0583.jpg
https://s11.postimage.org/la0o5qpmr/IMG_0588.jpg
98 zx9r
Dracon
PostPosted: 00:00 - 03 Dec 2012    Post subject: Reply with quote
You could always do the R6 tail mod, it involves cutting the back end off, which wouldn't be a bad thing in your case!
neiloggy1
PostPosted: 00:06 - 03 Dec 2012    Post subject: Reply with quote
i have considerd this already and as my father in law is a professional welder for bws welding is not a problem
however iam on a budget and to buy a full rear end is not likely at this time of year
i mean a second hand yzf frame less than 100 notes
but an r6 frame and rear end not going to be cheap
98 zx9r
lilredmachine
PostPosted: 00:35 - 03 Dec 2012    Post subject: Reply with quote
Well, R6 subframe can be had on e-bay for around £70, and a fibreglass trackday rear end for anything from 99p.
R6s are common track day fodder and people are constantly cutting down/replacing tails and subframes so there are shitloads about dirt cheap.
neiloggy1
PostPosted: 09:17 - 03 Dec 2012    Post subject: Reply with quote
Ok so it turns out that that a tail chop to an r6
May be an option
You are right rear subframes can be bought for as little as 60 quid
Am I right in saying that the rear sub on an r6 is separate from its frame and can be simply welded to my tcat
As I know a good welder
wow just a bit bent
https://s7.postimage.org/7586vgsln/IMG_0586.jpg
https://s9.postimage.org/o691lny7z/IMG_0585.jpg
98 zx9r
neiloggy1
PostPosted: 10:34 - 03 Dec 2012    Post subject: Reply with quote
Hahanumbarse wrote:
chains slack subframes straight.
out of curiosity how many pounds did this take from your wallet?
Omg that made me laugh so loud
I didn't pay 1 penny if u read my circumstances I have 5 kids
And a crappy job
My only interest apart from family is bikes I just love em
I passed my test lest year and owned a gorgeous zx6r that i saved all my hard earned penny's for until someone robbed a few week back
So I had no bike no cash and wasn't coverd for theft
Until my Missus and family chipped in and got me this project I believe they got it cheap
So my job now is to get her to former glory or mod whichever is the cheaper option
I intend all work myself except welding and might change color to blue r6 rep not to sure on color yet
I could easily spend about 1k over the next 4 month so this thread may go on a while
With plenty of pics
98 zx9r
lilredmachine
PostPosted: 13:34 - 03 Dec 2012    Post subject: Reply with quote
May be an option
Yeah, either cut the lugs off the r6 subby and weld it directly to the tcat or weld lugs onto the tcat frame and bolt it.
mysterious_rider
PostPosted: 13:37 - 03 Dec 2012    Post subject: Reply with quote
And a crappy job
With plenty of pics
Faith in humanity is restored. Thumbs Up I'd be tempted to cut it, or bend it back and brace it.
neiloggy1
PostPosted: 22:44 - 11 Dec 2012    Post subject: Reply with quote
Finally the forks arrive time to replace these bent ones
the new ones Look and feel to be in good condition and bargain at 150
So had a spare hour to tinker
Stripp rest of front end down
and test fit new forks
Just wanted to make sure it's all straight no freeplay and all is good Smile
So all calipers are also off for strip down reseal and repaint
Next jobs to sort
rear end needs straightening or r6 mod
replace suspension linkage bearings
Replace front discs (one is cracked)
Major cleanup
Check all bolts nuts replace any rusty
Service oil filters coolant plugs
Check clutch as it feels abit stiff
Refit calipers
Then finally decide on a color scheme and refit plastics
can't wait to see the end and finally ride it
https://s15.postimage.org/q5hz6c1u3/IMG_0661.jpg
https://s16.postimage.org/r3lmasu6d/IMG_0588.jpg
https://s12.postimage.org/9veupnb8t/IMG_0659.jpg
98 zx9r
stonesie
PostPosted: 23:25 - 11 Dec 2012    Post subject: Reply with quote
Next jobs to sort
Major cleanup
Refit calipers
Fixed Thumbs Up
Looking good, might be worth changing the oil in those forks while they're an easy job to get back out though.
neiloggy1
PostPosted: 23:33 - 11 Dec 2012    Post subject: Reply with quote
i have probably done every job on a bike and iam a confident mechanic
but i have never changed fork oil
never needed to but cheers for suggetion ill research and do that
another job on the list and possibly next one as forks are just nipped up at the moment
98 zx9r
stonesie
PostPosted: 23:48 - 11 Dec 2012    Post subject: Reply with quote
After talking to an expert (Reactive Suspension) his opinion is that the fork oil that bike manufacturers use is cheap crap, if those forks have never been opened then it will be totally ruined by now.
neiloggy1
PostPosted: 23:57 - 11 Dec 2012    Post subject: Reply with quote
Guess new fork oil it is then
98 zx9r
neiloggy1
PostPosted: 18:26 - 22 Dec 2012    Post subject: Reply with quote
So today managed to straighten the rear subframe
Simply got a scaffold bar which was 8ft long (easy leverage) Smile
Then ratchet strapped the frame in 3 places to a steel fence
also with measured blocks of wood so the main frame wouldn't twist
Basically a home made jig
Heated the subframe with 2 blowtorches for a while
Then simply bent the subframe back to its normal shape
In all it took about an hour
i had to make lots of measurements along the way to make sure it was perfect and all is good
Bike is now at basic welding I'm having some support bars
Welded on and seams rewelded
should be back just after new year Very Happy
Also stripped the forks down put new seals in and fresh oil
Before sending frame off
In mean time im going to start on the plastics (sand plastic fill sand prime sand)
im not going to topcoat yet until the bike is fully finished
also going to paint and reseal the calipers while the frames away
any ideas how to cleanup this exhaust Sad
https://s1.postimage.org/qn7vx405b/IMG_0660.jpg
more pics on progress soon
98 zx9r
rhys1005
PostPosted: 13:20 - 08 Jan 2013    Post subject: Reply with quote
Ok gheeze fine il buy your crash bobbins.. How much? Laughing
Diddylord
PostPosted: 19:14 - 08 Jan 2013    Post subject: Reply with quote
to help with your exhausts what i would to is just jet wash the worst of the dirt of and then get a toothbrush and some of this stuff.
https://www.amazon.co.uk/s/?ie=UTF8&keywords=autosol&tag=googhydr-21&index=aps&hvadid=7213668373&hvpos=1t1&hvexid=&hvnetw=g&hvrand=1237014044547453856&hvpone=&hvptwo=&hvqmt=e&ref=pd_sl_75bb020bur_e
works really well but stinks as you do it, will get that looking new again with a bit of rubbing.
neiloggy1
PostPosted: 19:39 - 08 Jan 2013    Post subject: Reply with quote
The exhaust actually cleaned up easier than I thought with a little wd40 and elbow grease
Also got the frame back from the welders last weekend so I've been really busy Working on the bike since then
I have spent about 16 hours rubbing the frame and swing arm down for paint
Was in 2 minds on color for the frame
So first I sprayed the swing arm silver and I didn't like
So rub down Again and now is sprayed in Matt black and it looks the muts knackers
Cleaned shock rebuilt rear end
Second hand front discs fitted
New bushes pressed into rear shock linkage
I'm now onto the calipers rear exhaust and foot hangers
Pics and more info soon as I get time
98 zx9r
neiloggy1
PostPosted: 19:42 - 08 Jan 2013    Post subject: Reply with quote
Haha have em they need replacing
But The carbon effect goes with the color scheme I'm going for
Shame they're damaged
Any how I'm doing
Frame Matt black
Wheels gloss black
Foot hangers and exhaust Crome
Other detail bits rim tape chain adjusters silver
And plastics in time will be metallic blue???
Heres a pic of swingarm sprayed in matt black
https://s8.postimage.org/y5kdis7fp/IMG_0700.jpg
looks alot better so here it is fitted
https://s13.postimage.org/ncwuuz66v/IMG_0707.jpg
only thing im pissed about is previous owner did a shitty job of painting it silver and he got overspray everywhere so alot of his overspray still to clean up off wires etc...
98 zx9r
Xenocide
PostPosted: 19:53 - 12 Jan 2013    Post subject: Reply with quote
I've got a blank tank, frame + MIGHT have disks - i can't remember.
PM me if you're interested. I make good price for you mister, verrrry nice.
KTM LC4 400 | Honda VTR1000
ian505050
PostPosted: 23:38 - 12 Jan 2013    Post subject: Reply with quote
I have some new brake pads for a thundercat and a dark screen that you can have if needed, you would just have to cover postage, Offers there if you need them.
neiloggy1
PostPosted: 21:33 - 11 Feb 2013    Post subject: Reply with quote
well i needed the cat to get to work so i got some fairings for cheap off ebay.
while waiting for them to arrive i put it back together fully
greased all necessary bits and washed it down.
fairings finally arrived a week later so tools out again and 3 hrs later job done.
i been waiting a long time to take her out fully dressed so out i went.
now while out i wasnt entirely impressed with the performance compared to the zx6r i previously owned but was more comfortable guess they are a good first bike
anyhow here she is fully finished and working
https://s4.postimage.org/g15d4vurx/IMG_0777.jpg
https://s11.postimage.org/imxd0eywj/IMG_0776.jpg
https://s7.postimage.org/psnp53pbf/IMG_0778.jpg
but sad ending to this even tho i thought she looked ok i was not happy with the performance
so i sold it and bought this instead
https://s12.postimage.org/hjdnkfg6l/IMG_0781.jpg
and now im very happy 1000cc of great performance and the new thunderace doesnt need a thing just a good clean and a few extras Very Happy
so new thread soon and in better detail cheers all for advice Thumbs Up
98 zx9r
Ja7
PostPosted: 21:39 - 11 Feb 2013    Post subject: Reply with quote
Nice work there looking good Thumbs Up
The last post was made 13 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 129.43 Kb
