| Benwalkden |
 Benwalkden Two Stroke Sniffer
| Efes123 |
 Efes123 World Chat Champion
| Benwalkden |
| Aff |
 Aff World Chat Champion
| J.M. |
 J.M. World Chat Champion
| Benwalkden |
| J.M. |
| map |
 map Mr Calendar
 Posted: 14:53 - 04 Dec 2012 Post subject: |
My first thought on brake light issue was the micro-switch at the lever.
First try WD40 although might be an issue if non-standard replacement lever used so not contacting correctly with switch.
If that's ok could be the switch. However, it is working and intermittent faults are always difficult to track down. So if cannot be resolved by WD40 or looking at lever point of contact might be worth replacing the switch itself. Replacement can be from breaker or have a look at the likes of WEMoto or even David Silver (do a google).
The bulb should just pull out. You then remove bulb from connector, replace bulb and reinsert. I'm not sure on the model but you might have to remove clock underside plastics to get at them (should not be hard, if it is then look again at what you're doing). IIRC Honda CG service manual pdf is available to look at/download (again do a google). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
The last post was made 13 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
