Topbox - Connecting to seat
Kris
PostPosted: 11:09 - 04 Dec 2012    Post subject: Topbox - Connecting to seat Reply with quote
I am looking to fix a Nonfango 848 topbox to the back of my bike, but instead of the usual position – I want it to sit directly behind me in place of a pillion. I need the fixing to be secure as the bike is left parked in the city during the day. I have the topbox, plus the mounting plate and a couple of steel arms that were supplied with the bike.
Does anyone have experience doing similar? I’m aware that the couriers use bungees etc but I haven’t seen any directly fixed using bolts. Would it be strong enough to fix through the seat directly using coach bolts (one piece seat on a mk2 bandit 12) and a couple of steel plates, one either side of the topbox bottom surface? How would I ensure the seat is still waterproof?
Thanks
www.prisonplanet.com
PostPosted: 11:19 - 04 Dec 2012    Post subject: Re: Topbox - Connecting to seat Reply with quote
I've done this before on the ZX9 and GSXR (got a spare 'race' hump for the GSXR - should have just got another seat instead.
On the ZX9 I never did anything special to stop water going in, but separate seats.
Sure you could cover the top box plate somehow to stop the vast majority of water when the box wasn't on.
Just used some long bolts (maybe threaded rod) and big washers on the end with my cheap givi (scooter) top box. Worked nicely.
Coped perfectly fine with my usual 'daily antics' Smile.
map
Mr Calendar
PostPosted: 11:33 - 04 Dec 2012    Post subject: Reply with quote
Without seeing the mounting points a bit difficult to visualise...
...however....
Could you not knock up a n shaped mount to fit over the seat. The sides can be metal strips drilled and screwed to suitable bike points (or passed under locked seat maybe?). These then bent/riveted/whatever to a top plate (or other metal strips) that can be drilled to take topbox mounting plate.
Downside is that not quick or easily to remove should need pillion seat. Then that's an advantage thinking of security.
...although that might be over engineering it.
PostPosted: 11:42 - 04 Dec 2012    Post subject: Reply with quote
Guy in Medway flies around on a CB400SF with a top box drilled into this rear seat Thumbs Up Been going for a while now Laughing
Marmalade
PostPosted: 12:29 - 04 Dec 2012    Post subject: Reply with quote
I bought a battered pillion seat via ebay and drilled straight through it, bolted mounting plate on with big bolts and repair washers.
https://i370.photobucket.com/albums/oo141/bramble43/46440069-A512-459C-92A6-C86E52C57C06-4123-000003E23909D68B.jpg
fatjames
PostPosted: 12:43 - 04 Dec 2012    Post subject: Reply with quote
This is a seriously good idea. I'm going to try and find an old pillion seat.
Kris
PostPosted: 13:04 - 04 Dec 2012    Post subject: Reply with quote
Cheers all.
Did you all use the connector plate or does it work with just the seat and the topbox?
The pesky Nonfango plate is huge and the connecting bolts would have to have small allen heads to fit within the recessed adjustment grooves on the top surface... Grrr!
PostPosted: 13:18 - 04 Dec 2012    Post subject: Reply with quote
I used the connector plate - as I sometimes take the top box off.
Don't see any reason you'd need to use it however, but I would certainly use a big bit of metal on a plastic top box if I was expecting a less than smooth ride - ie speeds bumps at speed, only one wheel in contact with the ground, etc.
Marmalade
PostPosted: 13:33 - 04 Dec 2012    Post subject: Reply with quote
I used the plate so that i didn't destroy the box with holes in the bottom and it stays waterproof but if i'm going out without the box i put on the hump or pillion seat that came with the bike.
You could get a givi plate for it since they are the same.
owl10
PostPosted: 15:04 - 04 Dec 2012    Post subject: Reply with quote
Same as marmalde, second hand rear seat bolted directly to it. ZX6R J series so just swap seats when I need to.
El Cheapo bolts from B&Q and some FO big washers. Not had a problem since.
No pics sorry, and bike is a long, long way away at the moment...
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
evoboy
PostPosted: 17:16 - 04 Dec 2012    Post subject: Reply with quote
https://sphotos-f.ak.fbcdn.net/hphotos-ak-ash4/424583_10151168159827250_815799038_n.jpg
APT Motorcycles
The last post was made 13 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 70.68 Kb
