YBR Forks fitting - apparently no, they don't fit
Alpha-9
PostPosted: 10:31 - 05 Dec 2012    Post subject: YBR Forks fitting - apparently no, they don't fit Reply with quote
Does anyone know if forks from a pre fuel injection YBR will fit a 2009 FI model?
They look the same to me, but I notice they make a point of putting what year they've come from so I don't know if they differ?
Someone must know Praying
Fzr-600 1999
J.M.
PostPosted: 10:38 - 05 Dec 2012    Post subject: Reply with quote
Measure them? Same diameter then yes, different diameter then no.
2004 R1 & 2018 XSR900
Alpha-9
PostPosted: 10:46 - 05 Dec 2012    Post subject: Reply with quote
Don't have them to measure, old ones are bent, and fixings may be slightly different
Am trying to have a look but thought someone may know
Fzr-600 1999
J.M.
PostPosted: 11:01 - 05 Dec 2012    Post subject: Reply with quote
The entire things aren't bent. You only need to measure one small part of the stanchion to get the diameter of the thing. Alternatively you could measure the size of the hole in your yokes!
Then just get the person you're buying off to measure as well.
Any stanchions with the same diameter should be fine to use so long as you can attatch your wheel and brake calliper to the fork bottoms.
I can't see why they wouldn't fit to be honest. Unless the bike got redesigned to make it heavier/lighter/faster then they would have had no need to redesign the front end.
The forks on my GS are about twice as old as the bike Thumbs Up
Alpha-9
PostPosted: 11:39 - 05 Dec 2012    Post subject: Reply with quote
I imagine they will fit, but I wanted to be sure..in fact i'll just compare pictures
2006
https://i.ebayimg.com/t/YBR125-YBR-2006-Brand-New-Pair-of-Fork-Legs-/00/s/MzEwWDQwMA==/$(KGrHqF,!okE+3MMs7p)BQJNEhJSnw~~60_12.JPG
2010
https://i.ebayimg.com/t/YAMAHA-YBR-125-2010-FORKS-SUSPENSION-/00/s/NDgwWDY0MA==/$T2eC16RHJH8E9qSEVnvVBQsm+vrj7g~~60_12.JPG
Seem the same Thinking
Fzr-600 1999
J.M.
PostPosted: 11:55 - 05 Dec 2012    Post subject: Reply with quote
You could email the seller asking the diameter of the stanchions just to be safe, but I would be fairly certain that those would fit purely by the fact that there's only 1 year difference between the bikes.
The most noteworthy change on the YBR happened post 2008 when it went FI, but both your bike and that bike are post 2008 so that accounts for the only real change the bike has ever had.
Other than that they introduced the more sporty/off road version in 2010 called the YBR 125 G. Although this change mentions no changes to the forks as a unit, just the mudguard and headlight, etc.
I can't garantee that they'll fit... but personally I'd buy those. On the small chance that they don't fit... put them back on eBay for what you bought them for.
Alpha-9
PostPosted: 12:01 - 05 Dec 2012    Post subject: Reply with quote
Oh you have me mistaken, and 2006 to 2010 is 4 years not 1 Laughing I think you read the 6 upside down Cool
But my bike is 2009 anyway, it was more the before and after FI that I thought would differ as you say, i've bought ignition and bits for pre-FI for mine before that didn't work, after the seller said "Should fit!"
Not sure what year the forks i'm getting are, DMCpro on here is hooking me up, i've asked just waiting for him to get back to me
Gonna go for it anyway as it's a good deal from him Thumbs Up
Fzr-600 1999
J.M.
PostPosted: 12:06 - 05 Dec 2012    Post subject: Reply with quote
Nah I read your bike as being 2009 and presumed you were looking to buy the 2010 ones! Smile
At the end of the day, if they don't fit, forks are very easy to sell as long as they're in good condition. In a crash they always get damaged so always need replacing. But obviously if they're always the damaged part in a crash... not many of the bikes being broken have them so they're always sought after Smile
I'd risk it to be honest and if they don't fit just eBay them for a decent price.
Alpha-9
PostPosted: 12:59 - 15 Dec 2012    Post subject: Reply with quote
Bah, don't seem to fit, is like the tiniest amount out but wont go in at all, can slip the old ones in and out easily Thumbs Down
Has a different bolt on top too, is male rather than female
Fzr-600 1999
J.M.
PostPosted: 13:23 - 15 Dec 2012    Post subject: Reply with quote
Do they fit if you put them in without the bottom-yoke?
Ask Paddy how much of a nightmare my forks were to get back in...
My forks are also more male then female as they were before. It's better though... the bolt on the top can be twisted to adjust the forks harder/softer depending on what you like.
Alpha-9
PostPosted: 13:38 - 15 Dec 2012    Post subject: Reply with quote
Yeah I prefer that bolt, also these forks seem to weigh slightly more, they seem better in general actually
And no couldnt get them in, is awkward though
The bit with the bolt in fits but the actual stanchion that it goes into is like 1mm wider and doesnt go through, if that makes sense
bloody phone didnt come with the USB cable so cant upload pics Rolling Eyes
I thought it was the yokes being closed up so I opened them with a flathead slightly, didn't help, figured if I tried to prise it open too much it'd just derp the circle and make it a crushed oval and I wouldnt be able to get them in
Fzr-600 1999
J.M.
PostPosted: 13:49 - 15 Dec 2012    Post subject: Reply with quote
What you're saying makes sense, yes, but it seems very illogical that the forks on later YBR models would have decreased by 1mm on a bike that really hasn't changed.
Personally I would try prising them open a bit to see if that works. To get the gear lever off of my GS500 I have to hammer a flathead screwdriver the entire way down the gap to widen it enough to come off. Otherwise it gets stuck.
In the art of a bodge job I would do anything to make those forks fit if it really is only 1mm. Even widening the yoke holes.
Alpha-9
PostPosted: 14:53 - 15 Dec 2012    Post subject: Reply with quote
I have widened one quite a lot, the old forks slip in and out super easily but the new don't at all Thumbs Down
Will try and widen them a bit more and have another go, got my mate to help and we still couldn't Crying or Very sad
Fzr-600 1999
Alpha-9
PostPosted: 01:06 - 16 Dec 2012    Post subject: Reply with quote
Pics
The bent forks
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00004_zpsd29c5942.jpg
Old forks on the left, clearly different
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00019_zps72b70ca3.jpg
Get it up a bit so I can pull them out easier, fucked up paint on the engine half scraped off to respray...
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00009_zps44bf5908.jpg
Counter balance with some wood and slabs just incase and for lulz
Whip front wheel off
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00012_zps0f688c17.jpg
Pulled insulation tape out of the front brake pads, wtf
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00014_zps31fe4831.jpg
Bent my spanner getting the brakes off the forks, were solid
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00016_zps080eac8f.jpg
Forks out, bent much, clearer here
https://i2.photobucket.com/albums/y35/a-friend-in-need/IMG-20121208-00017_zps8d8d5989.jpg
As far as I got, couldn't get new forks in Thumbs Down
Looks like so little difference between the forks in size but wont go in for shit
Fzr-600 1999
Alpha-9
PostPosted: 01:13 - 16 Dec 2012    Post subject: Reply with quote
Rob Fzs wrote:
Alpha, you are just unbelievable.
Believe it sunshine Thumbs Up
Fzr-600 1999
J.M.
PostPosted: 01:54 - 16 Dec 2012    Post subject: Reply with quote
Personally I'd get a file/drill out and make those yokes slightly bigger to fit the forks.
Sod safety Mr. Green
I'd offer to come over and take a look... but alas... no bike Thumbs Down And you're much further away than I thought because you moved you arse, and I'm lazy.
barrkel
PostPosted: 03:08 - 16 Dec 2012    Post subject: Reply with quote
Alpha-9 wrote:
Now those are some bent forks.
My GF's SH300 (was my old SH300) has bent forks too, but they are less than 1mm out of true as measured from the centre of the stanchion compared with either end. Not visibly bent, you have to put one up against a straight edge to see anything. It adds up to more than 1mm at the axle though, especially because of how scooter forks attach to the steering stem - the two bolts that grip the fork legs are really close together.
And that scooter has noticeable handling problems going around corners - flops in on one side, wants to run wide on the other. Exacerbated on new tyres, feels better on more worn tyres.
I hope you weren't riding around that bike on those forks. I can only imagine.
covent.gardens
World Clap Champion
PostPosted: 03:27 - 16 Dec 2012    Post subject: Reply with quote
Name and shame that spanner.
Fisty
PostPosted: 08:20 - 16 Dec 2012    Post subject: Reply with quote
Alpha-9
Fatter and faster than Fret
MaybeGuy
PostPosted: 10:08 - 16 Dec 2012    Post subject: Reply with quote
Those forks will straightrn with no drama. Failing that, buy a different yoke.
PostPosted: 10:55 - 16 Dec 2012    Post subject: Reply with quote
Same as my Varadero, done 1000 miles since it happened, makes for lulzy commuting.
Alpha-9
PostPosted: 13:34 - 16 Dec 2012    Post subject: Reply with quote
barrkel wrote:
Laughing Obviously not. I got SMIDSYd and that was the result
I did manage to ride it down the pavement getting it to my parents from the crash site slowly and by holding the bar seriously hard as it pulled to one side, hurt my arm holding it like that Rolling Eyes
They might be able to be bent back into shape but I dunno, I'll ask the garage up the road I guess
DMCpro (the guy who I got the forks off) said he has the yokes if i'm interested, but not sure if they will fit without measuring, need a tape!
And yes it's all well and good saying they should fit, but it was also said these forks 'should fit' Brick Wall
As for the cheese metal spanner...not sure where I got it from, wilkinsons I think, which doesn't surprise me, cheap crap Thumbs Up
Pics help eh Wink
I thought about filing down the current yokes but...sounds dangerous! I don't honestly see what holds forks in that stops them from just sliding through the yokes as there's nothing on top of them to stop it, you could just push them through if the yoke clamps weren't tight enough, and if you overtighten them surely it will crush the fork Neutral
Fzr-600 1999
J.M.
PostPosted: 13:36 - 16 Dec 2012    Post subject: Reply with quote
I did say in the first post to measure them Whistle
The last post was made 13 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 137.47 Kb
