| pits |
 pits World Chat Champion
 Posted: 19:27 - 05 Dec 2012 Post subject: Any plumbers here? |
Trying to figure something out with my heating in the house.
Got an oil fired boiler out the back, fairly new one which runs the heating and hot water in the house.
On the water system I have master/main pump which appears to move the water from boiler/around the system.
Then I have two other pumps/valves which depending on whether I turn the heating on or the water on with the timer box, opens the valves depending on what I want.
Now that box where I can set the time for it to come on once, twice, constant turns the main water pump on and off, so if I have no heating or water on, the boiler isn't firing so the pump doesn't kick in and pump water around.
When I want heating or water, I flick either or both on, this starts up the pump and boiler and water circulates... I trust you are with me so far.
So now Ihave a warm house and water, I turn them timer off, which turns the boiler and pump off......but here is the problem, the master pump no longer turns off, it just sits there churning away, and the only way to turn it off now is at the plug, but the other problem is, in a month-2 month period I have used like 500 litres of oil.
This is the pump in question
https://www.oilybits.com/grundfos-ups-15-50-selectric-central-heating-circulator-pump/prod_646.html
Any idea as to why it isn't turning off when it should? And why I am using so much god damn oil, no idea what the boiler is, but it is a grade A efficiency boiler, next door haven't used half of what I have used, in a bigger house with a bigger family.
Would speak to landlord but the term chocolate teapot springs to mind ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| stinkwheel |
 Posted: 19:49 - 05 Dec 2012 Post subject: |
Sure someone isn't stealing your oil?
Heating oil theft is rife and it can be as low-tech as someone sneaking into your back garden armed with a hosepipe and a couple of jerry cans every night for a week.
Even if I left my heating on 24/7 (which I don't), I wouldn't use 500l in a month. In fact, I'd query if that was even possible.
So theft or a leak are my two starters for 10.
Could the pump be remaining on because the frost 'stat is kicking in? My outdoor boiler fires itself up and starts circulating through the heat store if the temperature inside the boiler drops below 5 degrees.
Otherwise, get a wiring diagram and chase it through. There will be a very limited number of things that will trip the relay that turns that pump on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pits |
| Stalk |
 Stalk Brolly Dolly
| Kradmelder |
 Kradmelder World Chat Champion
 Posted: 22:46 - 05 Dec 2012 Post subject: Re: Any plumbers here? |
| pits wrote: | Trying to figure something out with my heating in the house.
Would speak to landlord but the term chocolate teapot springs to mind |
It seems like an archaic way to heat water and a home in the sense that oil is so expensive.
A bolier requires constant circulation because of the pressures. To avoid a burst pipe water must circulate, make steam, cool down, and lose energy.
If you turn the burner off, the water must circulate for a bot. Just like a fan in a cage or bike runs when shutting off the engine. To heat the water up again requires a lot of energy. if your system is as efficient as you claim, then you save nothing as the energy to keep it simmering is the same as having to heat it all up again, since energy loss is minimal.
Wouldnt gas be cheaper in the UK? heating is instaneous and no bolier required. Hot water here is electric geyser or gas. Far cheaper. Water has a high latent heat and is very energy intensive to heat up. Hence it takes little heat to keep something simmering, but much energy to bring it to a boil. Now what is the capacity of you bolier? all that water to keep heating up.
I dont heat my house at all. On the Highveld people do. Electric heaters are damn expensive. then there are oil radiators which are electric, fire places, anthracite stoves, and gas heaters. Oil? Just makes arabs rich. ____________________ 2011 KTM 990 Dakar
2009 BMW 1200 GS
| janner_10 |
 janner_10 World Chat Champion
| Kradmelder |
| janner_10 |
| pits |
 Posted: 23:10 - 05 Dec 2012 Post subject: |
Boiler is around the back of the house, will have to check it tomorrow (bit of a walk)
The thing is, there is no oil, so no heating, but the pump wont switch off so no hot spots.
Krad, live out on the country, it is a lot easier to get oil plumbed in and delivered as opposed to gas
Might get a boiler man out to check it all out as shit, as it is just burning through oil at a vast rate of knots ____________________ Stinkwheel: You have no right to free speech
| swampy |
 swampy World Chat Champion
| Kradmelder |
 Posted: 23:21 - 05 Dec 2012 Post subject: |
| pits wrote: | Boiler is around the back of the house, will have to check it tomorrow (bit of a walk)
Might get a boiler man out to check it all out as shit, as it is just burning through oil at a vast rate of knots |
we dont have piped gas. all gas is cylinders. ____________________ 2011 KTM 990 Dakar
2009 BMW 1200 GS |
| Kradmelder |
| stinkwheel |
 Posted: 02:31 - 06 Dec 2012 Post subject: |
Wow Kradmelder. You really have no idea how totally and uneccessarily over-complex it has proven to be possible to make a simple device to heat water using an oil burner for the UK market.
I wouldn't have thought it was necessary to have even ONE microprocessor in such a device. It turns out that even my simple one has at least three, all of which are highly prone to failure.
If a central heating boiler (geyser/water ehating device) lasts five years without requiring a major repair, you're doing well. The water reservoir actually exploded on my dads oil fired one recently. Turns out it was made of cast iron.
In the UK a "geyser" is a very specific and now totally obsolete type of cylinder-shaped gas fired water heater. As history would dictate, almost totally indestructable although there were a few deaths due to carbon monoxide poisoning. My last house had a geyser and it never missed a beat (or went out) in 12 years. My current house has a 4 year old oil combi boiler and it's failed hard three times, each instance requiring a three figure sum or upwards of six hours of my time (which is worth a hell of a lot more) to fix it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pits |
 Posted: 03:14 - 06 Dec 2012 Post subject: |
thought geysers fired 15 feet of shit in the air  ____________________ Stinkwheel: You have no right to free speech
| Flip |
 Flip Super Spammer
| Kradmelder |
| stinkwheel |
| Walloper |
 Walloper Super Spammer
The last post was made 13 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
