Gatso's that flash twice
beefcake
PostPosted: 10:34 - 05 Nov 2004    Post subject: Gatso's that flash twice Reply with quote
I was riding home from work last night, doing 30mph in a 30mph zone, passed the same gatso that I pass every day, and it flashes me twice.
What does this mean for me? Will I get a ticket? Will they ignore it? I'm sure my speedo is reading correctly. Has anyone else had this, and what was the outcome?
I'm going for my bike licence soon, and I thought that if you get 6 points in the first 2 years then its bye-bye licence? I can do without a charitable 3 points if that's the case.
Deano Rolling Eyes
Gotta get my knee down...
Adam_P
PostPosted: 10:37 - 05 Nov 2004    Post subject: Reply with quote
If they're taking a picture of you (ie: if you're speeding) they flash twice. It needs two pictures to prove the speed you are traveliing at as it judges distance.
If your speedo says you're doing 30mph though it might be faulty. (Your speedo, or the camera!)
All you can do is sit and wait to see if you get a NIP through the post.
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
r1_lad
PostPosted: 10:38 - 05 Nov 2004    Post subject: Reply with quote
All gatsos flash twice, they take 2 pictures and use the distance you travelled between the 2 pictures to prove your speed in court.
From what i've heard, gatsos trigger at the speed limit + 10% + 2mph (can someone confirm this?), so you'd have to have been going 35mph to trigger it.
Have you changed your sprokets to different teeth? Or changed the size of the wheels from stock? These things can cause the speedo to misread on some bikes.
RS50 -> RS125 -> GSXR600 SRAD -> 02 R1 -> Speed Triple 1050 -> Ducati Streetfighter 1099 -> DRZ400 Superetard
conpants
PostPosted: 10:39 - 05 Nov 2004    Post subject: Reply with quote
theres a lot of ways to get out of fines and points
like sending the form back, filled in but not signing it
aparently
dont quote me on that though
r1_lad
PostPosted: 10:40 - 05 Nov 2004    Post subject: Reply with quote
That loophole has been closed now.
If you don't hear anything in 14 days, you in the clear.
I recommend taking a yogart pot of thermite down to the camera before they take the film out of it Wink
conpants
PostPosted: 10:43 - 05 Nov 2004    Post subject: Reply with quote
oh right, thats cool
stryker
PostPosted: 10:46 - 05 Nov 2004    Post subject: Reply with quote
There was one chap in the news a while back. He was flashed while driving his range rover. He knew he'd loose his license so he used his car to pull over the gatso then proceeded to smash it to bits.
In the end they could only do him for criminal damage. Laughing
Now what?
beefcake
PostPosted: 10:51 - 05 Nov 2004    Post subject: Reply with quote
The bike is totally standard (no change to sprockets). I pass about half a dozen camera's a day. None flashed this morning. I reckon it must be faulty.
I've seen gatso's flash just once before. I thought they only did that if they were out of film? I've seen a gatso flash twice when there was nothing there (I was coming the other direction on a dual carraigeway). I'll contest it if it comes through. Do they send you the picture straight away. or just the fine? If I'd had known I was going to have my picture taken, I would have washed the bike... Wink
PostPosted: 11:17 - 05 Nov 2004    Post subject: Reply with quote
They used to be set up to flash once when they were not loaded, but they realised that this gave the game away so newer ones flash twice whether they are loaded or not.
They must send the NIP so that it would be normally expected to arrive within 14 days (and from memory the law mentions that it must be sent by 1st class post). They have no burden of proof that they did so, and just because it does not arrive does not give you a get out as they can just turn round and say that they sent it and they will be believed.
They are unlikely to send you the pictures. They prefer a bit of terrorism to frighten you into just accepting the ticket. Some will show you the pictures on request, but many will refuse to show you the pictures until you are committed to going to court while also scaring you with promises of higher fines and costs should you dare to go to court.
In all probability the camera was faulty. Although they must legally double check the readings (it is one of the terms of the homologation for Gatso cameras) they rarely do so, so if the camera was live they will probably send you a ticket. In which case if you are lucky they might admit their fault, but expect them to not answer the phone, or to just pick it up and slam it down or to refuse to deal with you on the phone (we had all 3 on various attempts to contact them for a speeding ticket for one of our cars that had not been on the road in about 6 months and had definatly not been where they said).
Dom_
Points Mean Prizes
PostPosted: 11:19 - 05 Nov 2004    Post subject: Reply with quote
My dad received two SP30 fines through the post (in the same day) he appealed against them claiming he wasnt driving and hes got away scot free.
allweatherbik...
PostPosted: 11:35 - 05 Nov 2004    Post subject: Reply with quote
One of the cameras I pass on way to work has flashed twice as I passed it on two occasions within the last week. The first time I may have been slightly over the limit but not by much (32 MPH at the max.) and the second time I was definitely under 30 MPH. On both occasions I was alone on my side of the road but there were cars travelling quite fast on the other side of the dual carriageway although there are no marker lines on that side of the road. I will be rushing to check the mail over the next two weeks. Will keep you posted. Thumbs Up
beefcake
PostPosted: 11:59 - 05 Nov 2004    Post subject: Reply with quote
Cheers people.
kasandrich
PostPosted: 13:01 - 05 Nov 2004    Post subject: Reply with quote
The cameras sometimes flash if someone is speeding in the other direction.
I have had two occassions, one with my caravan on the back, when someone overtook me, the cammera flashed, I was doing 40 (in a 40 limit), the only picture the camera could get was my caravan, but I heard nothing.
The other I was on my bike, went past a camera in a 30, at 30mph, but there was a car coming the other way, speeding, again I heard nothing.
So, if you were behaving I'd say you had nothoing to worry about, in both the above cases I could see myself having to go to court to defend myself. Very Happy
Richard
CBR1000FM
Mal
PostPosted: 13:20 - 05 Nov 2004    Post subject: Reply with quote
I've had that quite a lot. On one of my routes to work there are a couple of cameras, and one is on a 30mph road with 4 lanes. Cars travelling at around 40mph in the opposite direction quite regularly set it off.
Mal
tintin
PostPosted: 14:17 - 05 Nov 2004    Post subject: Reply with quote
I often set one off on the other side of a road on my way home, once I realised I could do it it often did on purpose, one less fine for another road user....
The older I get the better I was
PostPosted: 14:47 - 05 Nov 2004    Post subject: Reply with quote
One more incentive for them to install front facing cameras as well.
Also a good reason for local police to keep an eye out for you.
simon1221
PostPosted: 16:46 - 05 Nov 2004    Post subject: Reply with quote
i am guessing you are talking about a car?
i thought you could not get a ticket on a bike as they do not have numberplates on the front Thinking
ps gatsos? Thinking
mattsmith95
PostPosted: 21:04 - 05 Nov 2004    Post subject: Re: Gatso's that flash twice Reply with quote
Deano Rolling Eyes
It could be a car traveling in the opposite direction that set off
the gatso. Thing is some work in one direction only, some in
both, it doesn't matter which direction they are pointing.
The gatso's on Brixton Rd, (Brixton, south London) work in both
directions, I know this because I am the bugger who sets them
off, hahahahahahhaahhaha! Middle Finger
Retro-Man
PostPosted: 22:12 - 05 Nov 2004    Post subject: Reply with quote
just to clarify the camera is able to detect speed and take that happy license loosing snap, but in theory at least all photo's are double checked by a trained agent.
Those markings on the road are the speed check markings, and I seem to remember that if travelling at 30mph or less it will take 5 seconds to travel from the first marker to the last marker. both photos take show position of the vehicle and the time.
This means that given the formula you can work out your speed by seeing how long it took to pass each mark.
sounds to me like the camera is faulty and hopefully if they spot a large amount of tickets being issued that day, This alone should ring alarm bells with them. Also if they only check a handfull and find errors then the whole film will be junked and the camera rectified.
Retro
https://domharnessphotography.webs.com
Retro-Man
PostPosted: 22:15 - 05 Nov 2004    Post subject: Reply with quote
ps gatsos? Thinking
That why they have started turning the cameras around so that they snap you once you have gone past.
upside is you have a better chance of spotting it and slowing
downside is that even on a bike they can get your reg
Retro
check this site out for information re speedtraps
https://www.ukspeedtraps.co.uk
tintin
PostPosted: 19:11 - 06 Nov 2004    Post subject: Reply with quote
So you've never gone too fast then, or broken the law ever?..or are you just a holier than thou prat? Judging by your picture I would have thought you've suffered form the police, unless you are the police man in the picture?
That's the point, there are no front facing cameras that matter to a bike. It's just a bit of fun, you go past a bit too fast on the other side of the road and get the camera to flash. Perhaps the next time you speed down that road the other way then the camera might be out of film.
Oh sorry I forgot you never speed anywhere....anyway perhaps it might help a real biker out.
PostPosted: 19:34 - 06 Nov 2004    Post subject: Reply with quote
If you keep setting the camera on the other side of the road off then the local police will have a growing pile of pictures of you and thus will be keeping an eye out for you.
John
PostPosted: 20:04 - 06 Nov 2004    Post subject: Reply with quote
So you've never gone too fast then, or broken the law ever? *snip*
Don't think this bloke has met G, do you? Laughing
TT600 neeeeeeeeeeeeeeeeeeowwww!
tintin
PostPosted: 10:56 - 08 Nov 2004    Post subject: Reply with quote
Maybe I haven't met G but it's his "holier than thou attitude" which is wearing a bit thin.
Most camera don't have any film in anyway, so I doubt the police are really interested. If they were and I get caught then that's my own fault. When I set the camera off I just ride at my normal speed anyway, I just move over nearer the central division.
Bikes are about fun and about being a bit of rebel. I'm sure some people might not agree with me but riding a bike does put you slightly to one side of mainstream society - and that's part of the attraction. Going too fast, acceleration, cornering, riding past a traffic jam of cars, on a bike all of these make you feel superior. Yes we could do without the danger of dozy car drivers and poor road conditions AND speed cameras, but a bike is still a great way to travel and if I want to go too fast and I don't endanger other road users then it's my choice.
Lighten up guys...
jonboy
PostPosted: 11:51 - 08 Nov 2004    Post subject: Reply with quote
Quite agree with G to be honest. I don't want to end up having to fit a reg plate to the front of my bike either.
The last post was made 21 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 132.07 Kb
