Cleaning an outboard compressor
Flatbadger
PostPosted: 10:09 - 09 Dec 2012    Post subject: Cleaning an outboard compressor Reply with quote
I realise there's a few audio engineering types on here, so this is worth a go!
I got a Behringer MDX1600 compressor about 10 years ago - I was a smoker at the time and it got its share. For the past few years it's been more or less out of use, but I've recently dug it out and have started playing with it again.
So there's a fair bit of 'farting' going on where any voltage is having to negotiate a fair layer of crap inside there. Last night I sprayed a bit of WD40 in the inserts in the back, and tried to get a bit through the front - now I'm pushing a nice high signal through there to try and do some electronic trailblazing but progress is slow.
Does anyone have any tips, or is there anyone who specialises in this sort of thing, like having a 'bath' for cleaning electronics?
You're in ISIS
woodall57
PostPosted: 10:36 - 09 Dec 2012    Post subject: Reply with quote
you can buy special contact cleaner for things like ins and outs n stuff but im not to sure about the insides
try www.muffwiggler.com/forum and look on there, they are a nice bunch of people unlike gearslutz haha
cbt:4/7/12 theory:16/7/12 module 1:12/8/12 module 2: ?
Flatbadger
PostPosted: 11:45 - 09 Dec 2012    Post subject: Reply with quote
Ta, I might just go over there.
I'm making headway though, it seems the 'operating level' switches at -10dBV on the back make it better Thinking
You're in ISIS
neil.
PostPosted: 12:04 - 09 Dec 2012    Post subject: Reply with quote
We run a fair few Behringer dynamics processors at work. Use a decent contact cleaner that leaves no residues or oil - NOT WD40. Something like Ambertron by Ambersil. Spray it in all the switches and work them vigorously, same with sockets, plugging and unplugging a cable quickly before it dries out. I've found the switches go intermittent on a lot of Behringer rack gear after a few years. If they have built in LEDs you'll see them flickering etc. Let the unit dry out properly after as the freezing cold temperature of the spray makes moisture form inside.
They don't really get that dirty inside as there aren't any fans pulling air through but you could whip the cover off and blow over everything with a compressed air duster. The units I've had apart are just a toroidal transformer and a PCB with op amps and loads of surface mount stuff - nothing fancy. At the age your one is at, look out for bulging/burst electrolytic capacitors and replace as necessary - Rubycon and Panasonic are decent replacements for them. Very common cause of all sorts of audio nastiness.
Flatbadger
PostPosted: 14:31 - 09 Dec 2012    Post subject: Reply with quote
neil. wrote:
NOT WD40
Uhoh, did I do a Mrs Doyle? It was a brief squirt with the tube in the holes in the back Shifty I'll investigate the Ambertron you mention, thanks.
I have it just on the expander at the moment and it seems OK, but trouble with the compressor on the right channel seems to be linked to the sidechain button thinking it's on, and it needs twiddling.
You're in ISIS
woodall57
PostPosted: 14:50 - 09 Dec 2012    Post subject: Reply with quote
yea also its behringer, your not going to get neve kind of build quality haha
Flatbadger
PostPosted: 15:10 - 09 Dec 2012    Post subject: Reply with quote
Quite, but I don't need one enough to buy another one, particularly a better one! I'm thinking of carrying on transferring old cassettes to digital format, I'll try this then try a software compressor I think..
It seems to be settling down now, I have a bit of Derek & Clive going through at the moment Wink
You're in ISIS
woodall57
PostPosted: 15:30 - 09 Dec 2012    Post subject: Reply with quote
haha
i dont have any outboard, what daw do you use? and what audio interface do you have?
Flatbadger
PostPosted: 15:40 - 09 Dec 2012    Post subject: Reply with quote
I imagine I'll be using a laptop with a (again!) Behringer UCA202, and might try one of my VST compressors. I'd prefer some real-world hardware control while still in the analogue realm though, and get that signal good and high before it goes in the 'pooter.
You're in ISIS
The last post was made 13 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 62.27 Kb
