Fitting hand guards
bridgedino
PostPosted: 19:40 - 10 Dec 2012    Post subject: Fitting hand guards Reply with quote
Has anyone experience of fitting hand guards. The type which attatch to both the bar end and has an adjustable arm to clamp to bars?
Only I see my CRF250L bars have no bar ends fitted. The grips look just like the ones my mountain bike
So how can I attatch the guards to where there are normaly bar ends?
Cheers
waffles
PostPosted: 19:58 - 10 Dec 2012    Post subject: Reply with quote
It depends on your current setup. Do you have any bar ends at all?
You may have to cut the end off your grips so that you can see the bars underneath, I found that loosely fitting the guards then tightening up the clamp that slides inside the bars first worked best. Don't forget to use some locktite or something similar, as the bolts can rattle loose.
bridgedino
PostPosted: 20:13 - 10 Dec 2012    Post subject: Reply with quote
No bar ends at all.
I wonder what's on the end of the bars underneath the rubber grips
boundy
PostPosted: 22:49 - 10 Dec 2012    Post subject: Reply with quote
bridgedino wrote:
No bar ends at all.
A hole.
Cut the end of the grip off and insert end of hand guard.
Check the internal diameter before you buy the fitting kit, they do differ.
bridgedino
PostPosted: 22:56 - 10 Dec 2012    Post subject: Reply with quote
Cheers for the help guys. Much appreciated
The last post was made 13 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Offroad & Supermoto All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 42.82 Kb
