Running in Bikes
Ge4orce
PostPosted: 13:48 - 05 Nov 2004    Post subject: Running in Bikes Reply with quote
For how many miles should one ride a bike in?
Honda is the best
PostPosted: 13:51 - 05 Nov 2004    Post subject: Reply with quote
What bike is it?
If its new, you should have a good description in the user manual.
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Ge4orce
PostPosted: 14:03 - 05 Nov 2004    Post subject: Running in Bikes Reply with quote
Hello keith.Any bike I do not really think it does matter what bike it is.Please tell me why you would say it does matter what type of bike it is.
Honda is the best
PostPosted: 14:16 - 05 Nov 2004    Post subject: Reply with quote
It's around 1,000 miles for the first 500 or something not above x rpm and then for the second 500 not about y rpm. The dealer will tell you all this when you buy the bike.
PostPosted: 14:18 - 05 Nov 2004    Post subject: Reply with quote
Well if its a 2 stroke engine, you need to be considerably careful when running it in, long and annoying process. Mad
If your after that Honda, best off asking Titot as I believe he bought a brand new XR a while bike, should be able to offer better advice.
I imagine it'll just be along the lines of running it in low to medium rev over about 500 miles, then taking it for its first service.
Adam_P
PostPosted: 15:30 - 05 Nov 2004    Post subject: Re: Running in Bikes Reply with quote
Beause different manufacturers may have different guidleines to running in engines, especially different types of engine.
So, it does matter what type of bike it is.
Mine was to stay between 6-7000 for the first 500 miles, then bring the revs up a thousand for every hundred miles after. After it had it's first service I gave it more stick as I knew everything should have started to settle in by then anyway.
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
TheShaggyDA
Repost Police
PostPosted: 20:57 - 05 Nov 2004    Post subject: Re: Running in Bikes Reply with quote
Enfield 500, no tacho, so by speed/throttle:-
0-300 miles, 45mph, or 1/3rd throttle
300-600, 55 mph, or 1/2 throttle
600-1000, 65 mph, or 3/4 throttle
Either way it's don't thrash it, and don't labour it. I've had gearing/carb/exhaust mods, so I can push that to 50/60/70. Halfway there now Smile
The Dude
PostPosted: 16:56 - 07 Nov 2004    Post subject: Reply with quote
I can't remember where, but i read somewhere a while back that these dudes built 2 bikes from scratch the exact same. Then they thrashed the life out of one around a race track for hours and run the other one in properly. Then they took the engines apart and checked what the difference was and they found that the one they had thrashed wasn't really in any worse state than the one that was run in properly. But the one that got thrashed put out a little more power. Makes ya think i suppose
PostPosted: 16:59 - 07 Nov 2004    Post subject: Reply with quote
Yeah they also found that the one that was thrashed blew up before the one that was run in properly.
Although I suppose you could argue that suspension and chassis components normally give up the ghost way before engines do, and so it doesn't matter really...
On a superbike I might thrash the thing... on a 4T 125 I might run it in properly! Smile
The Tot
PostPosted: 18:09 - 07 Nov 2004    Post subject: Reply with quote
First 100 miles at 30mph
Next 100 miles at 35-40mph ( or go on a Killspills rally like what happend when i was running it in - not a good idea)
200-300 miles 40-50mph
300-400 - just keep it at 50
400+ Cane it till the top speed - i got 73mph down hill
Then service it. Please DON'T wheelie your bike before you have it serviced or run it - the general idea is to keep your bike at even revs - not to stress it at ultra low revs or screech it to the redline - shortshift through the grears to make use of all 5 gears, even at 30mph.
Do observe these guidlines when running it in as you want to prolong the life of the engine - after it's run in - give it hell Thumbs Up
Do they even have your bike on the UK market as i think it's identical to the XR other than the fact that it has a front drum brake.
Never argue with autism
Fortuna
PostPosted: 02:41 - 08 Nov 2004    Post subject: Reply with quote
I had to run mine in again last summer Sad I did some serious tuning though. Very Happy
PostPosted: 14:00 - 08 Nov 2004    Post subject: Reply with quote
One good reason to run it in is that some clearances will tighten up. For example as the valve clearances tighten up (which is not unlikely on an engine with shimmed valves) then they will start not to close. With the extra heat of being thrashed you stand a fair chance of it dropping a valve.
Ge4orce
PostPosted: 12:16 - 11 Nov 2004    Post subject: Running in Bikes Reply with quote
You see the problem is I will have about 3-4 months to ride it in,because I live 10miles outside the town and I am going to ride with my bike to school and back.Well the minimum speed I will need to go is 62,because it is each side of the road has only one lane and it is quite busy.Where I live however I can ride at low speeds and there is many places I can go.My family is not very rich so I would like to get as many miles out of my bike as possible.
Honda is the best
Rob W
PostPosted: 16:03 - 11 Nov 2004    Post subject: Reply with quote
What Tito said, if I'm right my bike (Derbi Senda SM125) has got the same engine as the XR, and all it says in the manual about the running in period is dont go above 8,000rpm for the first 500km's, and work all the gears as much as possible rather than stressing them, after that it says periodically run it to redline for the next 500km's then your away
PostPosted: 23:48 - 11 Nov 2004    Post subject: Re: Running in Bikes Reply with quote
10 miles each way works out at 20 a day, 100 a week. You will have it run in within a month or so, and I bet you will do loads of extra miles on it once you have access to it.
The last post was made 21 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 88.48 Kb
