| J.M. |
 J.M. World Chat Champion
 Posted: 15:41 - 11 Dec 2012 Post subject: Can't get the flywheel off |
Today I tried removing the flywheel on the bike, and have spectacularly failed and gotten stuck. I'd really appreciate some help.
https://cdn.bikechatforums.com/files/img_20120830_142937.jpg
I've removed that bolt in the middle, that was the easy part.
Next Haynes said that I could either use the specialist Suzuki tool or use an alternative method.
The alternative method was to insert a 36mm spacer in to the hole, then use the swing-arm bolt (M16) to tighten up in to the hole. It said to tighten this up then tap it with a hammer and it should come loose.
I've tried that, nothing's happened. I've tried upping the size of the spacer from 36-40mm and still, can't get it to budge.
I've also noticed that one of the magnets was loose and cracked. I'm presuming that it was my doing, but now only 5 out of the 6 magnets are attached to that thing.
I get the impression I've really fvcked up here.
Where do I go from here? ____________________ 2004 R1 & 2018 XSR900 |
| Teflon-Mike |
 Posted: 15:54 - 11 Dec 2012 Post subject: |
RM Motorcycles / Cylinder Rebores Tenlons Road.
Personally, I would pop the motor out the frame, and take it over Tenlons; and let them get the rotor off on a press.
The 'principle' of using the axle bolt is that its larger thread is screwing into the rotor and pressing on the end of the crank to press it away and off the taper, opposite to the rotor bolt that screws into the crank and pulls it on.
Yes; Haynes book of lies way of doing it is great in principle, but the bikes they take apart are under a year old, and still have factory assembly grease on them! We have to deal with rust and siezed stuff!
And after wasting days of my life and giving myself a bald patch scratching my head over this kind of niggledy prob..... over to the pro's and a fiver in the beer fund.... job jobbed, without further deforrestation of the cranium.
Next question, what to do about the rotot and its missing magnet?
New rotor.
Or 2nd hand one. I think I would be tempted to ponder if I could re-attach it, and I am thinking about the high temperature 'gloop' we used to use at Lucas, developed for attaching brake shoe linings and stuff..... which is probably what held the thing on to start with, and is far from the sort of household adhesive you get at Halfords....
But even if I could get some from somewhere, knowing the clerances those magnets are running, and the balence of the rotor... I think I would have to be desperately desperate to go through with it.... its not just risking the rotor if fix fauls but likely to wreck the stator if it does, and any imbalence could harm crank/crank bearings, so I think I would probably bite bullet and cough up for a replacement rotor, just for piece of mind. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| bikenut |
 bikenut World Chat Champion
| J.M. |
| bikenut |
| J.M. |
| cimbian |
 cimbian World Chat Champion
 Posted: 16:22 - 11 Dec 2012 Post subject: |
Stop struggling and get a bigger 'ammer. ____________________ 22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker |
| bikenut |
| J.M. |
| orac |
 orac World Chat Champion
| J.M. |
| orac |
| J.M. |
| lukamon |
 lukamon World Chat Champion
 Posted: 18:52 - 11 Dec 2012 Post subject: |
get a puller. usefull for other such things as car wheel bearings, and well, pulling shit off other shit.
i used mine t pull the flywheel off a 10 year old briggs and stratton lawnmower. by CHRIST was it tight. my engine locking method was to shove some thin nylon rope into the sparkplug hole when on compression stroke - though im not sure if this might harm a more "highly strung" enginbe such as a bike one
seriously though, if you think it wont come off, turn it tighter. make sure you are turning from the centre of the bolt, too. might pay to support the centre of the ratchet with wooden blocks / bricks from the ground so you can belt the end of it with an 'ammer  ____________________ killa wrote: Im an ass man myself |
| Teflon-Mike |
 Posted: 20:19 - 11 Dec 2012 Post subject: |
cylinder rebores took two super-dream rotos off two engines for me for a fiver, Jord. they are good like that.
As said, the thing ought to come off the tapers with a bit of persuasion, using the screw-in method, though you can waste a lot of effort widing up ans tensioning whatever is holding teh rotor from turning before anything starts to happen.
Here, brealer bars or extension poles can be a double edged sword, becouse leverage magnification means that the very small deflection that they make 'loading up' can be quite a lot of a turn on the breaker bar on the other end..
err.. yeah, screw moved like 0.5mm per turn. Now, say you need to take up maybe 0.1mm which is practically bugger all, of 'slack' in the thread, and then another 0.1mm of compression on the end of teh screw before you even START applying pressure, you might have to make half a turn on the breaker before it even starts loading anything.
Now put six foot scaffold pole on the breaker bar, and lifting the thing eight foot probably gets barely a 1/3 turn on the screw.
Now apply similar leverage to the breaker you use as reaction to hold the rotor, and you can easily need to make two full turns on the undoing lever to JUST put tension on everything, before you start applying removal tension.....
And you have about 1/3 of a turn before you are bashing cieling or have to have some-one take over the centre, and then they run out of lever room when it touches the floor.
They also come off with a crack.... the 'sticktion' on the taper means that they dont want to move, dont want to move, but soon as you have put enough force on that they will move, they are 'off' and all the tension comes out of everything with a crack....
Cue flat on face nose paving slab interaction type events, breakers meeting goolies standing on garden rake scenarios....
DO NOT take the engle grinder to it.......
You have done enough damage for one day.......
Its salvageable.... may cost you a new OEM price rotor, but THAT is a darn site cheaper than a new crank, and a full engine rebuild or a new engine... when you end up taking chuks out of the taper on the crank!
And if you are at complete loss.... have you still got Nick's number? Mechanic at end of my street? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| prawny1 |
 prawny1 World Chat Champion
| J.M. |
 Posted: 20:41 - 11 Dec 2012 Post subject: |
OEM price rotor is $250-310 USD. That's at least £150!
So by the time I've fixed the start clutch the bill will be around £200 minimum. That's not using an OEM starter clutch... that's hoping I can repair mine.
That's not even including the engine damage. I have no idea what's wrong with it. It runs, like a bag of nails. This is what I'm dealing with engine wise: https://www.youtube.com/watch?v=XWYIiHPYRhI
That with a black left cylinder spark plug and burning through 1L of oil in the past 3-4 months, I think the engine could be expensive to fix.
I genuinely think that a used replacement engine could be the more financially viable option, that or a cheap run around bike maybe.
I'm keeping an eye out on eBay at the moment before deciding what to do next. If a cheap rotor comes up, I may get it, if a cheap bike becomes available I might get it.
As it stands... I'm thinking replacement bike. Then break mine down in to spares and sell it. ____________________ 2004 R1 & 2018 XSR900 |
| orac |
| J.M. |
| orac |
| J.M. |
| orac |
| J.M. |
| Tristan. |
 Tristan. World Chat Champion
| orac |
The last post was made 13 years, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
