| MAR5H7 |
 MAR5H7 Nitrous Nuisance
 Posted: 17:22 - 11 Dec 2012 Post subject: Thundercat Pulling Away Issues - Clutch? |
Ok, Bike has been fine until past few weeks I started noticing something, when ever pulling away from a stand still, there is a horrible grinding noise from below, bottom of the engine and it judders horribly, then when it gets going, the grinding stops and runs like she should, beautifully
Its only at stand stills
Starting her up, shes fine, idles fine, everything is fine, just pulling away, thats why im thinking clutch
Shes at 42k miles, not sure when the plates have been changed (if at all) any help will be highly appreciated
Thanks for hearing me out ____________________ Ex: CBR 125 R 06', ZXR 400 96' (RIP), Bandit 650 06'
Owned: SRAD 600 97'
Current: YZF Thundercat 600 96' |
| Walloper |
 Walloper Super Spammer
| MAR5H7 |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Walloper |
| MAR5H7 |
| dangerousdave |
 dangerousdave Traffic Copper
 Posted: 19:00 - 11 Dec 2012 Post subject: Re: Thundercat Pulling Away Issues - Clutch? |
| MAR5H7 wrote: | Ok, Bike has been fine until past few weeks I started noticing something, when ever pulling away from a stand still, there is a horrible grinding noise from below, bottom of the engine and it judders horribly, then when it gets going, the grinding stops and runs like she should, beautifully
Had a simular problem with the Thunderace, clutch groans when pulling away, especially when pulling away quickly.
Turned out the oil I was using was slightly too thin, went back to the correct weight of gearbox oil and sounded much better. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
| dangerousdave |
| dangerousdave |
| MAR5H7 |
| weasley |
 weasley World Chat Champion
| dangerousdave |
 Posted: 20:29 - 11 Dec 2012 Post subject: Re: Thundercat Pulling Away Issues - Clutch? |
| MAR5H7 wrote: | | dangerousdave wrote: |
Turned out the oil I was using was slightly too thin, went back to the correct weight of gearbox oil and sounded much better. |
Im running Silkolene Semi Synthetic, is that not the right for thundercat's?
And which oil did you change to? ill give it a whirl! |
I used this last time:
https://www.ebay.co.uk/itm/MOTUL-5000-OIL-FILTER-YZF1000-THUNDERACE-1996-2002-/280705467455?pt=UK_Motorcycle_Parts&hash=item415b59843f
Quietened the clutch down a lot when pulling away. I was using a thinner oil before, which made the clutch really noisy. Would make nasty groaning and scraping noises when pulling off the lights in a hurry.
I understand as oil ages in the gearbox also it loses its lubricating properties as it becomes diluted with any combustion by-products. I've changed my oil at least every 12 months, and after each change the engine & clutch sounds much better. When doing high milages I've done changes every 6 months, sometimes down to 3 months between changes. Its good insurance for the engine IMO. ____________________ 1988 Kawasaki KMX 200
| steady eddie |
 steady eddie Nova Slayer
 Posted: 17:41 - 13 Dec 2012 Post subject: |
Have a look on https://www.bikersoracle.com/thunder/forum/forumdisplay.php?f=27&order=desc&page=4
there's a wealth of info on there
I'm sure it's something to do with the grooves on the clutch basket wearing and not releasing the plates properly, mine used to judder / kangaroo / bog down if you tried to pull away with too many revs ____________________ Fz50>Ts185>Rd125Lc>Cb250n Superdream "Deluxe" (!)>Kmx200>Tdr250>Yzf600 Thundercat>
Current bikes: 1997 Fireblade RRV & 1989 KMX200 |
| P.addy |
 P.addy Red Rocket
| MAR5H7 |
| weasley |
| MAR5H7 |
| steady eddie |
The last post was made 13 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
