Sidecars - On both sides....
robbieguy2003
PostPosted: 22:12 - 12 Dec 2012    Post subject: Sidecars - On both sides.... Reply with quote
Ok... Random question time. Is it possible to have a sidecar on both sides of a motorbike, i.e. one on the left and one on the right?
Also, is there a reason why they're either on the left or right? It's just a random question that's came up in conversation, and I thought someone on bikechat might know!
I'm either expecting decent replies, a coolstory bro or a picture of nobcat. Surprise me BCF!
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
Timmeh
PostPosted: 22:14 - 12 Dec 2012    Post subject: Reply with quote
https://www.bikechatforums.com/download.php?id=87054
Fisty
PostPosted: 22:17 - 12 Dec 2012    Post subject: Reply with quote
Left and right..... think about where the passenger sits in your car..... then think of a car in france.....
Fatter and faster than Fret
Drworm
PostPosted: 22:35 - 12 Dec 2012    Post subject: Reply with quote
https://motorcycle-74.blogspot.co.uk/2011/02/double-sidecar.html
https://i.imgur.com/5HIRU.jpg
Thumbs Down
Previous Bike: Honda CBF 125, Honda CB600F Hornet
Current Bike: Kawasaki Z750
Teflon-Mike
tl;dr
PostPosted: 22:56 - 12 Dec 2012    Post subject: Reply with quote
Construction & Use regulations.
I believe that the C&U regs were first introduced in the Mid 60's about the same time as the MOT test was introduced, and they specifically prohibited twin side-cars.
It had been implicitly prohibited in the 1930's by taxation rules, that counted wheels.
There was a Brough that used a double rear wheel, to handle the torque of an Austin car engine, even though the tyres were set about 1/2" apart, on a single wheel, the tax department deemed it a 'trike'. Fitted with a side-car, it was then deemed a 'car', because it had four wheels, to stop people buying one and avoiding higher car tax.
Same would have applied if two side-cars were fixed to one bike; it would have been deemed a car and subject to higher tax.
In the 1980's; the C&U regs were revised to demand that the side-car was fitted to the left of a bike.
This was the contension that surrounded the two-wheel drive 'Ural' outfit, the Russian built version of BMW Wiemach blitzen-bike.
The shaft drive crown wheel providing the power take off to power the side-car wheel on the right, for a Left-Hand-Drive 'outfit', and denied practical re-engineering to be converted to a left hand 'chair'; hence UK Urals were single wheel drive.
However, some people tried to get round the C&U regs registering them as trikes, rather than outfits, which ran foul of the MOT regs, as they 'failed' on technicalities such as the symetrical placement of lamps!
NOW, we have the EU Harmonisation rules, that insist that if a vehicle can be registered in one EU Menber-state, bu restriction to movement of goods, it must be registerable in another.... though there are exceptions for certain local requirements.
Which has, I believe left the matter in something of a hyatus, where few have definative answers as to whats technically legal or not!
fatpies
PostPosted: 23:26 - 12 Dec 2012    Post subject: Reply with quote
Well if one side car on each side isn't allowed why not two side cars on the left or the right!!
U_W v2.0
PostPosted: 23:48 - 12 Dec 2012    Post subject: Reply with quote
i think having that much weight would cause steering to be so sevearly affected it would end up going in a spiral.
also it would probably twist the framework
Frost
PostPosted: 00:01 - 13 Dec 2012    Post subject: Reply with quote
On racing outfits you can have it on either side, but it's usually on the left as most tracks are clockwise and therefore have more rights than lefts.
Spudly
PostPosted: 00:03 - 13 Dec 2012    Post subject: Reply with quote
Shocked
...wha...in a spi...
Shocked
The Old Apprentice
U_W v2.0
PostPosted: 00:04 - 13 Dec 2012    Post subject: Reply with quote
Shocked
Shocked
i mean if the power wasnt being delivered to the furthest most wheel as well as the "normal" wheel then the bike might not be able to pull both cars in a straight line and eventually end up spiralling instead of going straight.
make sense?
im not a vehicle engineer so it might work or i might be right.
cimbian
PostPosted: 00:07 - 13 Dec 2012    Post subject: Reply with quote
I used to ride with a Squire chair to get round the car-licence regs. No one told me (and it was before internet) that I had to accelerate to turn left and decelerate to turn right. Once I got the hang of it it was fine, but up on the kerb a few times! Smile
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
recman
PostPosted: 00:15 - 13 Dec 2012    Post subject: Reply with quote
Drworm wrote:
Maybe something a little wider? Rolling Eyes
Teflon-Mike
tl;dr
PostPosted: 01:43 - 13 Dec 2012    Post subject: Reply with quote
They do anyway.
With the powered wheel offset from centre, as cimbian says,
- accelerate and the sidecar wheel acts as a pivot and the bike tries going in a curve around the chair.
- brake, and the side car carries on, and the bike acts as a pivot, making the outfit go in a curve around the bike!
Piloting an 'outfit' is a bit like saling a little dingy; you just CANT go in a straight line, you sort of weave along in a series of 'tacks'.
Right Hand Drive outfit; you get on, start up, engage gear and try acelerating away...... the bike veers strongly to the left.....
You find that you cant actually counter this 'steering' the bike as you would expect, becouse not a solo, it wont 'lean' and counter steering and tilting doesn't work, you have to actually turn the handlebars and turn them a LONG way to actually get some steering effect.
If you haven't already hit it... the kerb is getting rather close, so you roll off the throttle..... and the chair swings back the other way!
which is unfortunate, becouse you have just started to get it steering almost straight, and now its veering off into oncoming traffic quite alarmingly... and OH FUCK..... the inversions in your head are playing havoc with your sense of direction, and you KNOW that to get it to come back your side of the road you need to accelerate again, but staring into oncoming traffic, the veer getting more promounced your instinct is telling you to BRAKE and that's just making it worse!
Brute force chucking yourself against the handlebar makes it steer left... and you bump the kurb... wave appologetically atthe car thats just swerved to avoid you, utter some words of apology to the chap watching anxiousely walking his don on the pavement.....
And GIVE THE FUCKING THING BACK TO ITS RIGHTFUL OWNER....
Who obviousely is completely MAD!
I mean, they MUST be. WHY have a motorbike that cant filter? Cant lean through corners, and weighed down with balest to stop the chair lifting is slower than a Nissan Micra driven by a Granny on Pension day? Has no roof, no heater, no radio; is NOT eccomomical, and makes AA men MAD when you inevitably have to call them out becouse the damn thing is broke, who yell and shout at you "How am I supposed to put THAT on my ruddy tail lift! Paper says MOTORCYCLE, no one fucking told ME it has a side Car! What the fuck am I supposed to do with it!"
I am a pretty perverse and cussid person, and take delight in the contrary....
But, sorry... no..... Side-Cars?
MAD.
MADDER than Maddy Mc Madderson, on a day pass from Maddison Mad-House, wearing a Mad Hatters Mad-Hat and a sandwhich board saying 'Mad as a Box of Frogs on a Black-adder Tuesday!
sickpup
Old Timer
PostPosted: 01:50 - 13 Dec 2012    Post subject: Reply with quote
You could at least quote your source in stuff like this. Clicky.
Yes I do get slightly annoyed when people pass my comments off as their own.
HTH Thumbs Up
covent.gardens
World Clap Champion
PostPosted: 02:05 - 13 Dec 2012    Post subject: Reply with quote
Woah! You mentioned EU harmonisation rules two full years ago, and now expect people to remember to credit you every time they say something similar? Laughing
sickpup
Old Timer
PostPosted: 02:22 - 13 Dec 2012    Post subject: Reply with quote
Yes Wink
BUT only when they make a post that is a completely revolutionary idea that goes against ALL common thinking on a subject. A bit like when Yaigi tried to tell the BCF masses how to deal with the DVLA.
PostPosted: 13:08 - 13 Dec 2012    Post subject: Reply with quote
I do know someone who tried to register a bike with a chair on each side and they were refused saying it was a car and as such had to conform to minimum radius regulations.
Sidec*rs are however the work of the devil and should never be ridden under any circumstances. I have scars to prove it.
A sidec*r is a vehicle that only runs in a straight line due to an opposing and equal sum of instabilities. Everything about them is counter-intuative and a general abomination.
A right hand sidec*r is more of the same, only worse because they try to make you run the chair into oncoming traffic instead of parked cars and you can't see to overtake in them.
Just say AAARRGH FUUUUCCCCK NONONO! to sidec*rs.
Timmeh
PostPosted: 13:19 - 13 Dec 2012    Post subject: Reply with quote
Years ago I saw some article about sidecars, think it was BMW that done one with a tricked-up hydraulic rig so that the car leans over as the bike does, so it corners properly (or close enough)
I wouldn't even dream of riding with one, I'd forget it was there and bin it headfirst into a car or something.
Teflon-Mike
tl;dr
PostPosted: 13:24 - 13 Dec 2012    Post subject: Reply with quote
Reminds me of when I first fitted Hard-Paniers to the VF, and an embaressing moment wedged between parked car and house wall on my drive!
cimbian
PostPosted: 13:26 - 13 Dec 2012    Post subject: Reply with quote
Been done many times. including the Jaymic Sidewinder:
https://i71.photobucket.com/albums/i153/banjodave/Picture-1.jpg
22PlusY
Dan79
PostPosted: 22:57 - 15 Dec 2012    Post subject: Reply with quote
The 1986 Construction & use regs s8, give a maximum width of "any other motor vehicle" that can be used on the highway as 2.5m; would a motorcycle with a side car on each side exceed that limit ?
I guess that such a vehicle might also require relatively softer suspension on the sidecars than that on the driven rear wheel (and perhaps also a heavier than average rider), in order to maintain decent traction on the driven wheel on uneven ground.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
The last post was made 13 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 127.14 Kb
