Bar ends for the Bandit
Mr Hammers
PostPosted: 13:32 - 16 Dec 2012    Post subject: Bar ends for the Bandit Reply with quote
Finally got round to making some simple bar ends for the Bandit;
https://www.planetash.net/bandit/barends
Would like to make some a bit cooler/better but these will do for now.
A Guide To Powerbands
PostPosted: 13:52 - 16 Dec 2012    Post subject: Reply with quote
Sweet! You did a nice job of that.
Nice to see the little machine being used. Why not add a pic of the lathe?
Ja7
PostPosted: 14:59 - 16 Dec 2012    Post subject: Reply with quote
Thumbs Up made a good job of that, how much did the material cost ?
ocatoro
PostPosted: 16:09 - 16 Dec 2012    Post subject: Reply with quote
look good those...
might be a dull question, but what do they screw into?
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
Werny
PostPosted: 17:11 - 16 Dec 2012    Post subject: Reply with quote
Nice work there Mr Hammers Thumbs Up
ocatoro wrote:
look good those...
The black bit on the small end is a rubber bush that's compressed - and therefore expands and grips inside the hollow bars - when the bolt is tightened.
https://www.planetash.net/bandit/barends/9.jpg
Mr Hammers
PostPosted: 21:23 - 25 Dec 2012    Post subject: Reply with quote
Spent ages going through all the pics on the pc (over 20,000!) trying to sort them out, and i know the original pics were on there somewhere. Anyway, took a few current ones of it in the meantime..
https://www.planetash.net/bandit/barends/lathe3a.jpg
https://www.planetash.net/bandit/barends/lathe1a.jpg
https://www.planetash.net/bandit/barends/lathe2a.jpg
Thanks Smile The ally bar was 750mm x 30mm and about £20 inc p+p off of ebay. Still got plenty left obviously. The bolts were a few pence, and the rubber is just a bit of petrol pipe.
Exactly. It doesn't work quite as well as I'd hoped, the nut has nothing but friction to stop it turning, but it sort of works and they do tighten enough not to fall out, which is the main thing Very Happy
PostPosted: 21:57 - 25 Dec 2012    Post subject: Reply with quote
I had the same trouble with mine. I made a split collar and they hold in perfectly. The same thing they use for bicycle handlebars and seat posts.
Turn down about 40mm of your ally to the ID of the bar so that it's a close fit. Put a V-pointed lathe tool sideways in the tool holder and use it to score a V-groove down the length of the piece you just turned by holding the piece in the chuck and using the carriage to make the cut with the lathe not running. This is because there's a seam on the inside of the bar - if your bars don't have this then you don't need the groove.
Drill it through at 5mm then tap for M6. Now cut it diagonally at 30-45 degrees with a hacksaw, put one half in the lathe and drill it out 7mm. You can now fit it to the bolt, slide it in and tighten it up solid.
binge
Emo Kiddy
PostPosted: 22:06 - 25 Dec 2012    Post subject: Reply with quote
That lathe is absolutely awesome for things like that.
It's something I quite fancy for my workshop, but at the moment, my best mate Gaz is a tool maker, and has access to Lathes and Mills on a daily basis, so I can get 99% of things done. Only down side is waiting times. And of course, experimenting. I'd like to just get on a lathe, learn the ropes, then just see what I can make up. Fancy wheel spacers, Hubcentric wheel adapters, Axle spacers, Sprocket offset spacers, bar ends etc etc.
Good work on the bar ends, they look really OEM. Thumbs Up
kestrel
PostPosted: 22:56 - 25 Dec 2012    Post subject: Reply with quote
Nice job Mr H, ya can't beat home brewed parts!
Isle of Man.........Road Racing Capital Of The World
DottyDuck
PostPosted: 03:52 - 05 Jan 2013    Post subject: Reply with quote
after seeing what they looked like before you worked your magic! i must say i didn't think they would look half as good as they do Smile
good job Smile
The last post was made 13 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 67.5 Kb
