is my bandit 6 restricted?
Mondeo Man
PostPosted: 16:01 - 16 Dec 2012    Post subject: is my bandit 6 restricted? Reply with quote
I can hit 20 in first, at 5-6k, an it feels like it needs an upshift. Certainlny doesn't fly to 60, like I'd hoped. I have hit 100 private road but it didn't seem as though it was going much past this - saying this, it was an insanely windy/rainy day and I was being a bit of a coward.
It doesn't feel especially faster than my restricted er5, bit disappointed. I know it's not a sports bike, so maybe this is normal.
If people can give me some sort of insight, don't want to embarrass myself taking it back to the dealer if it isn't restricted.
Redoko
PostPosted: 16:07 - 16 Dec 2012    Post subject: Reply with quote
Does it go over 100.
Yes - Not restricted.
No - Restricted.
Go out on your bike.
barrkel
PostPosted: 16:10 - 16 Dec 2012    Post subject: Re: is my bandit 6 restricted? Reply with quote
IMO it should just be starting to wake up around there. Power peaks around 10k. I presume you're not just judging it by the sound, i.e. is it actually running out of puff?
Mondeo Man
PostPosted: 16:12 - 16 Dec 2012    Post subject: Re: is my bandit 6 restricted? Reply with quote
Thanks
How much umph should I get from first gear?
moppy
PostPosted: 16:18 - 16 Dec 2012    Post subject: Reply with quote
My restricted ZZR6 hits an actual 100mph (in 4th gear and after quite a struggle).
U_W v2.0 This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
PostPosted: 16:26 - 16 Dec 2012    Post subject: Reply with quote
Usually_Wrong wrote:
sorry to state the obvious, but why not just pull the carbs and check for restriction washers?
wouldnt it be faster than going back and forth to a forum?
(says the guy who aske on said for about who to call for a water leak lol.)
No,
Bandit mk2 carbs are a fuck fest to get off.
The air box is in the frame through voodoo magic Laughing
Mondeo Man
PostPosted: 16:36 - 16 Dec 2012    Post subject: Reply with quote
Because it's a new used bike (less than 100 miles since got it from dealer) - so why should I be tinkering with it? I will have them look at it, but I need something a bit more substantial than, "i think it might be restricted!"
I need to something to compare it to.
U_W v2.0
PostPosted: 16:38 - 16 Dec 2012    Post subject: Reply with quote
well, ask the dealer you bought it from. they should know if they serviced it or mot'd it prior to selling it.
also, tinkering with it you'd learn its querks for being taken apart and put together again.
MattJ
PostPosted: 16:42 - 16 Dec 2012    Post subject: Reply with quote
From what you've described it definitely sounds restricted.
Dean-J
PostPosted: 16:46 - 16 Dec 2012    Post subject: Reply with quote
whilst not incredibly fast, the bandit should still be able to hit 125/130 indicated. if its not getting at least close to this, she be restricted.
barrkel
PostPosted: 16:54 - 16 Dec 2012    Post subject: Re: is my bandit 6 restricted? Reply with quote
At 5k revs in first gear, the throttle should be starting to get sensitive - sensitive enough that maintaining an exact speed and avoiding accidental acceleration requires very careful throttle control.
My ER6, which is geared slightly differently and has a slightly different power curve (power comes on a little sooner than most IL4 600s), will power wheelie if I quickly chop and reapply the throttle at those revs in 2nd gear, never mind 1st.
It sounds restricted or otherwise hobbled.
First time I got on a big bike while not under supervision of instructor and opened it up, it felt like I was going to topple off the back of the bike.
PostPosted: 16:57 - 16 Dec 2012    Post subject: Re: is my bandit 6 restricted? Reply with quote
What do you mean by it feels like it needs to change up? Buzzy, or just power dropping away? I would expect in first even restricted it manages to keep producing torque long enough past 5~6k to easily accelerate up to double that speed.
If it just feels buzzy then that isn't really going to be restricted / full power related.
PostPosted: 17:08 - 16 Dec 2012    Post subject: Reply with quote
Go hop on the motorway, redline 4th and 5th gear. You will see past 100.
If you don't, then lol. It's either restricted or has my old bandit engine which is pretty much a parallel twin.
U_W v2.0
PostPosted: 17:55 - 16 Dec 2012    Post subject: Reply with quote
hahadumbass why rate my posts as "confusing" and "boring"?
both posts had valid points, but then i guess your still butt hurt from that cyber session you couldnt handle right?
Cunnington
PostPosted: 18:13 - 16 Dec 2012    Post subject: Reply with quote
I found the bandit to have a relatively tame power delivery until I wrung it's neck, when it went a bit more like the scalded cat I expected. +1 for redline it and see what it does.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Noxious89123
PostPosted: 22:11 - 16 Dec 2012    Post subject: Reply with quote
Because you think removing the carbs or getting it dyno'd is a "better" way of figuring out if it's restricted rather than just riding the thing and seeing if it will top 100 when revved harder? Laughing Eh?
dragstaar
PostPosted: 18:16 - 17 Dec 2012    Post subject: Reply with quote
defo sounds like its restricted. I had a bandit 600 MK2 on a restriction, then unrestricted, so i know what both feel like.
restriction has a more obvious affect on acceleration rather than top speed (although there is some). Unrestricted, my bandit would do 0-60 in 1 gear and about 3-4 seconds. Fully nailed.
Restricted, things are a lot more sluggish and the rev meter climbs a lot slower.
Obvious thing is to keep an eye out for a similar 600 and race 'em off the lights. Or just ask them quickly to floor it off the lights so you can compare (if you have enough time to explain at the lights).
c_dug
PostPosted: 18:45 - 17 Dec 2012    Post subject: Reply with quote
Do you live anywhere near London?
If so I'll happily take it for a spin and let you know if it's restricted or not.
goto10
PostPosted: 18:53 - 17 Dec 2012    Post subject: Re: is my bandit 6 restricted? Reply with quote
Mondeo Man wrote:
Thanks
5, possibly 6 umphs.
BigDan1190
PostPosted: 19:04 - 17 Dec 2012    Post subject: Re: is my bandit 6 restricted? Reply with quote
goto10 wrote:
Mondeo Man wrote:
Thanks
Another perfect WINNING comment.
The last post was made 13 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 115.53 Kb
