scootoid crankcase issue
Timmeh
PostPosted: 19:03 - 17 Dec 2012    Post subject: scootoid crankcase issue Reply with quote
Lo peeps
rebuilding a dna50 for a mate.
Have split halves and cleaned crank and bearings. Can get it back together, but as soon as i torque the bolts the crank locks up and cant be turned.
Bit stumped - any ideas chaps?
Ta
timmeh Thumbs Up
andys675
PostPosted: 22:36 - 17 Dec 2012    Post subject: Reply with quote
main bearings aren't in the cases far enough, there was a special tool I used to have that pulled the bearings into the cases properly, if you didn't used it this happened, as I found out when I had a week off from work and someone else tried to do the job without the special tools!
if you haven't got access to the tools the you'll need to stick the cases in a warm oven for a while and the bearings in a freezer, leave them there for a bit and the bearing will then drop into the cases without any force required
Timmeh
PostPosted: 20:36 - 18 Dec 2012    Post subject: Reply with quote
awesome, thanks a lot duder. Thumbs Up
FYI this engine has suffered some hardcore abuse, friend's not-so-clever mate tried to do the job, and got the water and vacuum hose wrong way wrong and flooded the whole engine with water which then consequently rusted. Managed to salvage the crank and brand-new head+piston after washing it with lots of hot water and scrubbing with a toothbrush, then soaking in paraffin overnight.
Main bearings are a still a bit noisy so will be replacing them anyway.
Smile
The last post was made 13 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 36.26 Kb
